GRASS 7.0 GUI keeps printing a bunch of non-fatal messages to the terminal, like these (it took me 1 minute to collect them with typical operations like add&query a raster layer etc.):
GRASS 7.0.0svn (spearfish60):~/aur/grass70-svn > /opt/grass70-svn/etc/gui/wxpython/gui_core/goutput.py:234: wxPyDeprecationWarning: Call to deprecated item 'SetVirtualSizeHints'.
self.outputSizer.SetVirtualSizeHints(self.panelOutput)
(wxgui.py:5163): Gtk-CRITICAL **: IA__gtk_widget_set_size_request: assertion 'width >= -1' failed
(wxgui.py:5163): Gtk-CRITICAL **: IA__gtk_widget_set_size_request: assertion 'height >= -1' failed
I know these are no huge problem as such. But could they be avoided at some low cost? They are annoying, if you use terminal.
Maciej Sieczka
http://www.sieczka.org
Thanks for the report. Actually, there are tickets for this already.
https://trac.osgeo.org/grass/ticket/2028
https://trac.osgeo.org/grass/ticket/2160
https://trac.osgeo.org/grass/ticket/2027 (similar)
The first is not trivial but some day it will be hopefully fixed. The
second is really annoying and it seems that it is more wxWidgets problem
but it is unclear.
Vaclav
Maciej Sieczka
grass-dev mailing list
grass-dev@lists.osgeo.org
