I try to help to compile 7.0 on an Ubuntu box 14.04. We fail to compile OGSF:
alba@alba:~/source_code/grass70_release$ cd
/home/alba/source_code/grass70_release/lib/ogsf
alba@alba:~/source_code/grass70_release/lib/ogsf$ make
gcc -g -O2 -fPIC
-I/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include
-I/usr/include/gdal -I/usr/include -DPACKAGE=\""grasslibs"\"
-I/usr/include/postgresql -I/usr/include/libavcodec
-I/usr/include/libavformat -I/usr/include/libswscale
-I/usr/include/libavutil
-o OBJ.x86_64-unknown-linux-gnu/GK2.o -c GK2.c
In file included from /usr/include/x86_64-linux-gnu/sys/stat.h:105:0,
from
/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64,
from
/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:636,
from GK2.c:21:
/usr/include/x86_64-linux-gnu/bits/stat.h:91:21: error: field
‘st_atim’ has incomplete type
struct timespec st_atim; /* Time of last access. */
/usr/include/x86_64-linux-gnu/bits/stat.h:92:21: error: field
‘st_mtim’ has incomplete type
struct timespec st_mtim; /* Time of last modification. */
/usr/include/x86_64-linux-gnu/bits/stat.h:93:21: error: field
‘st_ctim’ has incomplete type
struct timespec st_ctim; /* Time of last status change. */
/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64:0,
from
from GK2.c:21:
/usr/include/x86_64-linux-gnu/sys/stat.h:365:31: error: array type has
incomplete element type
const struct timespec __times[2],
/usr/include/x86_64-linux-gnu/sys/stat.h:372:54: error: array type has
extern int futimens (int __fd, const struct timespec __times[2]) __THROW;
make: *** [OBJ.x86_64-unknown-linux-gnu/GK2.o] Error 1
Something is overriding the time definition. I found
http://stackoverflow.com/questions/14947691/c-system-file-bits-stat-h-suddenly-breaks-with-error-field-st-atim-has-inc
but dunno what to do next.
Any Ubuntu user who knows the trick?
thanks
I tested compiling on Ubuntu 14.04 several times recently. Here is what is needed.
There is already a ticket for “ogsf compilation error”
http://trac.osgeo.org/grass/ticket/2017
Where I say in the comment
–with-ffmpeg=no
http://trac.osgeo.org/grass/ticket/2017#comment:17
Perhaps, we should update “GRASS Wiki Comapile and Install Ubuntu” accordingly.
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
See also recent notes on that topic in:
[GRASS-dev] Updates of wiki page for compiling on Ubuntu
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069334.html
http://lists.osgeo.org/pipermail/grass-dev/2014-June/069371.html
This should help. I don’t know what ffmpeg is now for.
Vaclav
On Wed, Jun 25, 2014 at 11:04 AM, Markus Neteler <neteler@osgeo.org> wrote:
gcc -g -O2 -fPIC
-I/usr/include/gdal -I/usr/include -DPACKAGE="“grasslibs”"
from
from
from GK2.c:21:
struct timespec st_atim; /* Time of last access. /
struct timespec st_mtim; / Time of last modification. /
struct timespec st_ctim; / Time of last status change. */
from
from GK2.c:21:
thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
