[GRASS-dev] G7: parser - suppressing label in scripts
we have a problem with the introduction of labels:
http://trac.osgeo.org/grass/changeset/39886/grass/trunk/lib/gis/parser_standard_options.c
because:
myscript.py help
        vector Name of input vector map(s) used by GRASS script
                  Data source(s) for direct OGR access
... but we don't want the second line.
It would be good to be able to suppress "label" with the a reserved word
like "None" or "NULL":
#%option G_OPT_V_INPUTS
#% key: vector
#% label: NULL
#% description: Name of input vector map(s) used by GRASS script
#% required: no
#%end
to eventually gain:
myscript.py help
Any suggestions how to implement this suppressing "label" in the parser?
Actually, the problem only arose with the addition of standard options
in r47421.
#% key: vector
#% label: NULL
#% required: no
#%end
In parse.c, I suggest adding e.g.:
  static char *xstrdup(const char *arg) {
      return (strcmp(arg, "{NULL}") == 0)
          ? NULL
          : strdup(arg);
and replacing all references to strdup() with xstrdup(). Also,
translate() will need a test for NULL pointers.
Hello Glynn,
thanks for your suggestions. But i think you are two steps ahead from
me, because i am not able to find any strdup() usage in parser*.c.
Are there any steps to do before replacing strdup with your suggested xstrdup?
Thanks and best regards
Soeren
2011/8/10 Glynn Clements <glynn@gclements.plus.com>:
in r47421.
#% key: vector
#% label: NULL
#% required: no
#%end
   static char \*xstrdup\(const char \*arg\) \{
       return \(strcmp\(arg, &quot;\{NULL\}&quot;\) == 0\)
           ? NULL
           : strdup\(arg\);
grass-dev mailing list
grass-dev@lists.osgeo.org
I didn't say parser*.c, I said parse.c, i.e. general/g.parser/parse.c
(in 7.0; the standard option feature hasn't been back-ported to 6.x).
On Fri, Aug 12, 2011 at 8:58 AM, Glynn Clements
Right.
Together with Sören we have implemented all in r47596.
This now works:
#% key: vector
#% label: {NULL}
#% required: no
#%end
