[GRASS-dev] G7: v.in.ascii problem with broken lines: Busy SQLITE db
Hi
when importing a (big) file into GRASS GIS 7 with some broken lines in
it, the import gets stuck at some point:
Importing points...
DBMI-SQLite driver error:
Error in sqlite3_prepare():
table occurrence_plantae has 6 columns but 5 values were supplied
ERROR: Unable to insert new record: insert into occurrence_plantae values (
       29222, 4.75738, 51.79876, 'Plantae', 'Bryophyta')
WARNING: Busy SQLITE db, already waiting for 10 seconds...
WARNING: Busy SQLITE db, already waiting for 20 seconds...
WARNING: Busy SQLITE db, already waiting for 30 seconds...
WARNING: Busy SQLITE db, already waiting for 40 seconds...
WARNING: Busy SQLITE db, already waiting for 50 seconds...
WARNING: Busy SQLITE db, already waiting for 60 seconds...
WARNING: Busy SQLITE db, already waiting for 70 seconds...
WARNING: Busy SQLITE db, already waiting for 80 seconds...
WARNING: Busy SQLITE db, already waiting for 90 seconds...
WARNING: Busy SQLITE db, already waiting for 100 seconds...
CTRL-C
The reason is (I think) that it just calls G_fatal_error() in the
points.c file rather than shutting down the DBMI stuff properly,
closing files etc. before.
While at it:
I have started to implement a -i "ignore" flag to simply skip broken
lines. This doesn't fully work yet: "category out of range" but I am
not vector C expert enough to complete that.
We have 180 million lines to import and some are broken, so a -i flag
would be quite handy rather than manually identifying those lines.
Anyone able to help to solve both issues?
thanks,
(attachments)
v.in.ascii_skipflag.diff (2.67 KB)
On Wed, Nov 5, 2014 at 6:14 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi
While at it:
for the record, Markus Metz implemented it all in trunk and relbranch70.
Works nicely, thanks.
