[GRASS-dev] G71 errors at startup
just updated GRASS 7.1.svn (r64526), (after make clean, make distclean, svn up etc…)
At start up I get the following:
r.area: Unable to fetch interface description for command ‘r.area’.
Details: ERROR: Module built against version $Revision: 59317 $ but trying to use
version $Revision: 63930 $. You need to rebuild GRASS GIS or
untangle multiple installations.
r.regression.series: Unable to fetch interface description for command ‘r.regression.series’.
Details: ERROR: Module built against version $Revision: 60387 $ but trying to use
r.stream.basins: Unable to fetch interface description for command ‘r.stream.basins’.
r.stream.order: Unable to fetch interface description for command ‘r.stream.order’.
Details: ERROR: Module built against version $Revision: 62060 $ but trying to use
r.stream.snap: Unable to fetch interface description for command ‘r.stream.snap’.
r.stream.stats: Unable to fetch interface description for command ‘r.stream.stats’.
wx.metadata: Unable to fetch interface description for command ‘wx.metadata’.
Details: [Errno 2] No such file or directory
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
On Mon, Feb 9, 2015 at 3:03 PM, Margherita Di Leo <diregola@gmail.com>
wrote:
svn up etc..)
r.area: Unable to fetch interface description for command 'r.area'.
to use
'r.regression.series'.
to use
'r.stream.basins'.
to use
'r.stream.order'.
to use
'r.stream.snap'.
to use
'r.stream.stats'.
to use
'wx.metadata'.
I removed all the addons and now I don't get the error any longer. But
still don't understand why i got this.
Best regards,
Via Fermi, 2749
Ciao Madi,
On 9 February 2015 at 15:11, Margherita Di Leo <diregola@gmail.com> wrote:
I removed all the addons and now I don't get the error any longer. But still
http://osgeo-org.1560.x6.nabble.com/check-on-GRASS-revision-number-td5175139.html
Best regards,
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Luca,
On Mon, Feb 9, 2015 at 3:21 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Ciao Madi,
I removed all the addons and now I don’t get the error any longer. But still
don’t understand why i got this.
Thank you. However it seems to me that the behavior is different. In the case of Michael, he is launching r.flip and getting the error. This has happened to me in the past with some addons, and i have reinstalled them against current version. However in this case, I’m just launching grass, and getting error without calling any addons.
ciao
Luca
www.lucadelu.org
Best regards,
Via Fermi, 2749
2015-02-09 15:11 GMT+01:00 Margherita Di Leo <diregola@gmail.com>:
you need to recompile your addons against your current version of
GRASS. Simply run:
g.extension.all -f
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
On 09/02/15 15:49, Martin Landa wrote:
GRASS. Simply run:
g.extension.all -f
It would be great if the user could just be informed about this instead of seeing all these error messages...
I don't really understand: does GUI startup call these addon-modules ? If yes, why ?
Moritz
On Mon, Feb 9, 2015 at 10:04 AM, Moritz Lennert <
still
GRASS. Simply run:
g.extension.all -f
yes, why ?
It works in the way that when loading toolboxes for the Search module tab,
installed addons are called with --interface-description in order to get
the keywords and description to be searchable in the Search module tab. If
the addon is compiled for different version, previously it failed
silently on Linux/Mac. Now you get errors. On Windows however, even the
previous 'silent' solution was not silent, instead you got an ugly error
dialog "python.exe stopped working" which in the newest version of Windows
8 doesn't allow you to see details about which application actually was not
working. For each not working addon you have to click on the dialog so that
the gui can show up.
So, I would suggest to stop loading metadata for addons, at least on
Windows. The addons would be still available in the Search module tree and
would be searchable by the module name (not by keywords or desc). The
change should be easy.
Anna
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
2015-02-09 16:04 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
I have added such message r64532 (it's hot candidate for backport,
noted on [1]). Martin
[1] http://trac.osgeo.org/grass/wiki/Grass7Planning#Tobebackported
Martin Landa
2015-02-09 16:21 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
+1 for Windows (should be done ASAP). We can work on better solution
later after releasing G700.
Martin
Martin Landa
On Mon, Feb 9, 2015 at 11:44 AM, Martin Landa <landa.martin@gmail.com>
wrote:
and
done in r64533, will backport after testing
Anna
Martin
Martin Landa
