On Fri, Nov 22, 2019 at 1:01 AM Veronica Andreo <veroandreo@gmail.com> wrote:
El jue., 21 nov. 2019 18:40, Markus Neteler <neteler@osgeo.org> escribió:
I have successfully imported a series of Sentinel-2 scenes using
i.sentinel.download and i.sentinel.import (with the recent fixes yet
manually patched into it).
Now I want to register them:
t.create type=strds temporaltype=absolute \
output=openeo_bolzano_S2 \
title="Sentinel-2 scenes Bolzano" \
description="Dataset with Sentinel-2 scenes covering Bolzano"
# created by i.sentinel.import
head /mnt/geodata/openeo_bolzano/s2_t_register.csv
T32TPS_20180618T101021_B12|2018-06-18 10:17:33.781000|S2_12
T32TPS_20180618T101021_B04|2018-06-18 10:17:33.781000|S2_4
T32TPS_20180618T101021_B09|2018-06-18 10:17:33.781000|S2_9
T32TPS_20180618T101021_B08|2018-06-18 10:17:33.781000|S2_8
T32TPS_20180618T101021_B8A|2018-06-18 10:17:33.781000|S2_8A
T32TPS_20180618T101021_B06|2018-06-18 10:17:33.781000|S2_6
T32TPS_20180618T101021_B01|2018-06-18 10:17:33.781000|S2_1
T32TPS_20180618T101021_B03|2018-06-18 10:17:33.781000|S2_3
T32TPS_20180618T101021_B11|2018-06-18 10:17:33.781000|S2_11
T32TPS_20180618T101021_B07|2018-06-18 10:17:33.781000|S2_7
# here I updated successfully the existing TGRASS DB with the yet unmerged
# t.upgrade script (https://github.com/OSGeo/grass/pull/130)
t.register input=openeo_bolzano_S2
file=/mnt/geodata/openeo_bolzano/s2_t_register.csv
So far so nice, but:
t.rast.list openeo_bolzano_S2
name|mapset|start_time|end_time
T32TPS_20180606T102019_B01|openeo_bolzano|2018-06-06 10:25:12.692000|None
T32TPS_20180606T102019_B02|openeo_bolzano|2018-06-06 10:25:12.692000|None
T32TPS_20180606T102019_B03|openeo_bolzano|2018-06-06 10:25:12.692000|None
... the band names are gone - can anyone confirm?
I am using a recent G79.
I haven't tested, but are you sure t.rast.list now lists band references by default if they exist? Because that looks like a normal t.rast.list output to me
What if you use:
t.rast.list openeo_bolzano_S2 columns=name,band_reference,start_time
Does that work?
Unfortunately not:
GRASS 7.9.dev (utm32n_32632):~ > t.rast.list openeo_bolzano_S2
ERROR: Value <band_reference> out of range for parameter <columns>
Legal range:
id,name,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,nsres,ewres,cols,rows,number_of_cells,min,max
Indeed, that column isn't foreseen as an answer to columns:
https://grass.osgeo.org/grass79/manuals/t.rast.list.html
And what does t.info openeo_bolzano_S2 give?
+-------------------- Space Time Raster Dataset -----------------------------+
+-------------------- Basic information -------------------------------------+
| Id: ........................ openeo_bolzano_S2@openeo_bolzano
| Name: ...................... openeo_bolzano_S2
| Mapset: .................... openeo_bolzano
| Creator: ................... root
| Temporal type: ............. absolute
| Creation time: ............. 2019-11-21 21:24:17.024278
| Modification time:.......... 2019-11-21 21:25:05.446855
| Semantic type:.............. mean
+-------------------- Absolute time -----------------------------------------+
| Start time:................. 2018-06-06 10:25:12.692000
| End time:................... 2018-06-21 10:23:16.629000
| Granularity:................ 1 second
| Temporal type of maps:...... point
+-------------------- Spatial extent ----------------------------------------+
| North:...................... 5200020.0
| South:...................... 5090220.0
| East:.. .................... 709800.0
| West:....................... 600000.0
| Top:........................ 0.0
| Bottom:..................... 0.0
+-------------------- Metadata information ----------------------------------+
| Raster register table:......
raster_map_register_b9c38e48a9074528a0c5d928ccd9c8aa
| North-South resolution min:. 10.0
| North-South resolution max:. 60.0
| East-west resolution min:... 10.0
| East-west resolution max:... 60.0
| Minimum value min:.......... 0.0
| Minimum value max:.......... 1929.0
| Maximum value min:.......... 1600.0
| Maximum value max:.......... 28002.0
| Aggregation type:........... None
| Number of registered bands:. 13
| Number of registered maps:.. 91
| Title:
| Description:
| Command history:
| # 2019-11-21 21:24:17
| t.create type="strds" temporaltype="absolute"
| output="openeo_bolzano_S2" title="Sentinel-2 scenes Bolzano"
| # 2019-11-21 21:25:05
| t.register input="openeo_bolzano_S2"
| file="/mnt/geodata/openeo_bolzano/s2_t_register.csv"
--> Number of registered bands:. 13!
So, adding the "band_reference" to the option makes it work:
name|band_reference|start_time
T32TPS_20180606T102019_B01|S2_1|2018-06-06 10:25:12.692000
T32TPS_20180606T102019_B02|S2_2|2018-06-06 10:25:12.692000
T32TPS_20180606T102019_B03|S2_3|2018-06-06 10:25:12.692000
T32TPS_20180606T102019_B04|S2_4|2018-06-06 10:25:12.692000
I addressed the issue in
https://github.com/OSGeo/grass/pull/206
Thanks for pointing that out
Probably we should also change the default output to
old: #% answer: name,mapset,start_time,end_time
suggestion: #% answer: name,band_reference,mapset,start_time,end_time
Best,
