[GRASS-dev] Gaining write privileges to usr/local and subdirectories
Is there a way I can give myself privileges in my own usr/local to write to it and its subdirectories?
In following the directions to build grass7_trunk, I put the source under /usr/local/src/grass7_trunk, and now everything I do which modifies anything must be preceeded with sudo. I would like to eliminate this requirement for day-to-day work.
Thanks.
  • Paul
2017-05-23 17:12 GMT+02:00 Paul Schrum <paul.schrum@gmail.com>:
day-to-day work.
chown [1], chmod [2]. Martin
[1] http://www.linfo.org/chown.html
[2] http://man.cat-v.org/plan_9/1/chmod
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On 23/05/17 17:21, Martin Landa wrote:
day-to-day work.
Even though these commands do the job, I would not recommend it. Just put your entire src tree somewhere into your $HOME directory. No need to have it in /usr/local.
Moritz
to
here on my debian, I put the grass source code in my /home/ directory [1]
and do there all my coding and compiling. maybe not the best practice, but
no chown/chmod needed.
[1] https://wiki.debian.org/FilesystemHierarchyStandard
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321498.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
I started off trying to build it in a directory under my home directory using the instructions here, but I could not get it to build. The only part of those instructions that I was not following were the path. So I started using the paths indicated in those instructions and then it would build. That is why my copy of the source is where it is.
Based on yall’s comments, I now think it was something other than the path where I was storing the source code, but I have no idea what.
On Tue, May 23, 2017 at 11:33 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
day-to-day work.
Moritz
&lt;https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies&gt;,
Based on yall's comments, I now think it was something other than the path
please post here your steps and error (?)/warning(?) messages of compiling.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321504.html
Going by https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS and focusing on GRASS GIS 7 trunk:
  1. Last week I did
svn co [https://svn.osgeo.org/grass/grass/trunk](https://svn.osgeo.org/grass/grass/trunk) grass7_trunk
On a directory under my ownership.
  1. Today in that same directory I ran
svn up
  1. I ran the large statement which begins with
CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
Here is where the problem is. It seems to go into an infinite loop.*
Also note that when I run it from /usr/local/src/grass7_trunk – where I was running it when I started this thread – it succeeded. It did not go into the infinite loop.
  • When the process starts, the first few lines read:
    ./configure: 229: ./configure: Cannot fork
    ./configure: 300: ./configure: Cannot fork
There is a lot more I could send but have not, including the last lines before it restarts at the top of the loop.
Please let me know what more information to five you or what changes I should make.
  • Paul
<https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies&gt;,
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Wed, May 24, 2017 at 1:28 PM, Paul Schrum <paul.schrum@gmail.com> wrote:
Going by
1. Last week I did
svn co https://svn.osgeo.org/grass/grass/trunk grass7_trunk
2. Today in that same directory I ran
svn up
3. I ran the large statement which begins with
The backslash there means that the command continues on the next line,
you should copy the entire command.
This is my configure command for example:
CFLAGS="-ggdb -O0 -Werror-implicit-function-declaration -Wall" ./configure \
--enable-largefile=yes \
--with-nls \
--with-cxx \
--with-readline \
--with-pthread \
--with-proj-share=/usr/share/proj/ \
--with-geos=/usr/local/bin/geos-config \
--with-wxwidgets \
--with-cairo \
--with-opengl-libs=/usr/include/GL \
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
--with-postgres=yes --with-postgres-includes="/usr/include/postgresql" \
--with-sqlite=yes \
--with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
--with-odbc=no \
--with-netcdf \
--with-lapack \
--with-blas \
--with-omp \
--with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
Also note that when I run it from /usr/local/src/grass7_trunk -- where I was
running it when I started this thread -- it succeeded. It did not go into
the infinite loop.
* When the process starts, the first few lines read:
should make.
- Paul
> that
> indicated
> the
> path
compiling.
best regards
Helmut
user@osgeolive:~/ALL/SourceModules/cpp/grass7_trunk$ CFLAGS=“-O2 -Wall” LDFLAGS=“-s” ./configure --enable-largefile=yes --with-nls --with-cxx --with-readline --with-pthread --with-proj-share=/usr/local/share/proj/ --with-geos=/usr/local/bin/geos-config --with-wxwidgets --with-cairo --with-opengl-libs=/usr/include/GL --with-freetype=yes --with-freetype-includes=“/usr/include/freetype2/” --with-postgres=yes --with-postgres-includes=“/usr/include/postgresql” --with-sqlite=yes --with-mysql=yes --with-mysql-includes=“/usr/include/mysql” --with-odbc=no --with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
Sorry I didn’t post the whole thing. It is the same as what is on the go-by webpage, “GRASS GIS 7 example configuration”
On Wed, May 24, 2017 at 1:40 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
Going by
  1. Last week I did
    svn up
  2. I ran the large statement which begins with
CFLAGS=“-O2 -Wall” LDFLAGS=“-s” ./configure \
CFLAGS=“-ggdb -O0 -Werror-implicit-function-declaration -Wall” ./configure
–enable-largefile=yes
–with-nls
–with-cxx
–with-readline
–with-pthread
–with-proj-share=/usr/share/proj/
–with-geos=/usr/local/bin/geos-config
–with-wxwidgets
–with-cairo
–with-opengl-libs=/usr/include/GL
–with-freetype=yes --with-freetype-includes=“/usr/include/freetype2/”
–with-postgres=yes --with-postgres-includes=“/usr/include/postgresql”
–with-sqlite=yes
–with-mysql=yes --with-mysql-includes=“/usr/include/mysql”
–with-odbc=no
–with-netcdf
–with-lapack
–with-blas
–with-omp
–with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
the infinite loop.
should make.
  • Paul
that
indicated
the
path
compiling.
best regards
Helmut
Paul Schrum wrote
Going by
1. Last week I did
svn up
was running it when I started this thread -- it succeeded. It did not go
should make.
- Paul
On Tue, May 23, 2017 at 11:44 AM, Helmut Kudrnovsky &lt;
hellik@
that
indicated
the
path
compiling.
best regards
Helmut
grass-dev@.osgeo
grass-dev@.osgeo
no configure/compiling guru here on my side, googling
e.g. configure + "Cannot fork"
may show some issues with too many processes in your computer.
as your issue has changed from "Gaining write privileges to usr/local and
subdirectories" to some other, maybe changing the subject line of the thread
to get more devs involved.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321772.html
Helmut,
My GSoC mentor (Vashek) just now helped me work through this.
I turns out that in my newbie confusion I was calling ./configure from ./configure, so it wasn’t an endless loop, it was an endless recursion.
Thank you very much for your help.
  • Paul
On Thu, May 25, 2017 at 3:58 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
Paul Schrum wrote
Going by
  1. Last week I did
    svn up
should make.
  • Paul
hellik@
Ubuntu#Dependencies>,
that
indicated
the
path
compiling.
best regards
Helmut
grass-dev@.osgeo
grass-dev@.osgeo
e.g. configure + “Cannot fork”
as your issue has changed from “Gaining write privileges to usr/local and
subdirectories” to some other, maybe changing the subject line of the thread
best regards
Helmut
./configure, so it wasn't an endless loop, it was an endless recursion.
good to hear that's working now.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gaining-write-privileges-to-usr-local-and-subdirectories-tp5321487p5321982.html
