I’m building GDAL 1.5.0 with GRASS support;
it gives the following error:
In file included from grass57dataset.cpp:45:
C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:23:22: proj_api.h: No such file or directory
C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:36: error: ISO C++ forbids declaration of projPJ' with no type C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:36: error: expected
;’ before ‘*’ token
make[2]: *** […/o/grass57dataset.o] Error 1
make[2]: Leaving directory /usr/local/src/gdal-1.5.0/frmts/grass' make[1]: *** [grass-install-obj] Error 2 make[1]: Leaving directory
/usr/local/src/gdal-1.5.0/frmts’
make: *** [frmts-target] Error 2
proj_api.h is present in /usr/local/include, while /usr/local/grass-6.3.0RC5/include/grass has gproj_api.h
should I force GRASS code to include gproj_api.h instead of proj_api.h or walk around the problem adding /usr/local/include to PATH before launch make command?
Thanks
Marco
Problem fixed
needed only to add --with-local=/usr/local in configure
Marco
Da: grass-dev-bounces@lists.osgeo.org [mailto:grass-dev-bounces@lists.osgeo.org] Per conto di marco.pasetti@alice.it
Inviato: martedì 4 marzo 2008 18.03
A: grass-dev@lists.osgeo.org
Oggetto: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
;’ before ‘*’ token
Thanks
Marco
Hi Marco,
please don't build GDAL with direct GRASS support but use the plugin instead
(way easier...). See
http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
cheers
On Tue, Mar 4, 2008 at 9:24 PM, Marco Pasetti <marco.pasetti@alice.it> wrote:
Problem fixed
Marco
I'm building GDAL 1.5.0 with GRASS support;
forbids declaration of `projPJ' with no type
`;' before '*' token
make[2]: *** [../o/grass57dataset.o] Error 1
make[2]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts/grass'
make[1]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts'
command?
Thanks
Marco
grass-dev mailing list
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
Hi Markus,
I already checked it out... but it seems that there's still not a
grass-plugin for latest gdal release (1.5.0); the last I found is for gdal
1.4.3
Marco
-----Messaggio originale-----
Da: neteler.osgeo@gmail.com [mailto:neteler.osgeo@gmail.com] Per conto di
Markus Neteler
Inviato: martedì 4 marzo 2008 22.41
A: Marco Pasetti
Cc: grass-dev@lists.osgeo.org
Oggetto: Re: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
Hi Marco,
AL/OGR_Plugin
cheers
wrote:
Problem fixed
Marco
I'm building GDAL 1.5.0 with GRASS support; it gives the following
error:
proj_api.h: No such file or directory In file included from
C++ forbids declaration of `projPJ' with no type
expected `;' before '*' token
/usr/local/grass-6.3.0RC5/include/grass has gproj_api.h should I force
command?
Thanks
Marco
Hi Marco,
(cc Frank)
I assume that the plugin for gdal 1.4.3 also works for gdal 1.5.0.
On Tue, Mar 4, 2008 at 10:51 PM, Marco Pasetti <marco.pasetti@alice.it> wrote:
Hi Markus,
1.4.3
Marco
Markus Neteler
A: Marco Pasetti
Hi Marco,
AL/OGR_Plugin
cheers
wrote:
> Problem fixed
> Marco
> Hi,
> error:
> command?
> Thanks
> Marco
Has anyone had success with the grass-gdal plugin an MinGW?
For me, it just always produced Linux style .so files.
Benjamin
Markus Neteler wrote:
Hi Marco,
(cc Frank)
Hi Markus,
1.4.3
Marco
Markus Neteler
A: Marco Pasetti
Hi Marco,
AL/OGR_Plugin
cheers
wrote:
> Problem fixed
> Marco
> Hi,
> error:
> command?
> Thanks
> Marco
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
benjamin.ducke@oxfordarch.co.uk
