[GRASS-dev] [gdal-dev] GDAL 3.0.0 is released
FYI. Maybe of interest…
Fra: gdal-dev gdal-dev-bounces@lists.osgeo.org på vegne av Even Rouault even.rouault@spatialys.com
Sendt: torsdag 9. mai 2019 12.54
Til: gdal-dev@lists.osgeo.org; gdal-announce@lists.osgeo.org; news_item@osgeo.org
Emne: [gdal-dev] GDAL 3.0.0 is released
On behalf of the GDAL/OGR development team and community, I am pleased to
announce the release of GDAL/OGR 3.0.0. GDAL/OGR is a C++ geospatial
data access library for raster and vector file formats, databases and
web services. It includes bindings for several languages, and a variety
of command line tools.
http://www.gdal.org/
The 3.0.0 release is a new feature release with the following highlights:
  • DAAS: read driver for Airbus DS Intelligence Data As A Service
  • TileDB: read/write driver for https://www.tiledb.io (#1402)
  • New OGR drivers:
  • MongoDBv3: read/write driver using libmongocxx v3.4.0 client (for MongoDB
= 4.0)
  • Improved drivers:
  • FITS: read/write support for scale, offset and CRS
  • netCDF: read support for groups
  • PDF: add a COMPOSITION_FILE creation option to generate a complex
    document
  • PDS4: subdataset creation support, read/write table/vector support
  • Support for minimal builds on Unix (#1250)
  • Add a docker/ directory with Dockerfile for different configurations
  • Continued code linting
More complete information on the new features and fixes in the 3.0.0
release can be found at:
http://trac.osgeo.org/gdal/wiki/Release/3.0.0-News
The release can be downloaded from:
The migration guide can be found at :
https://github.com/OSGeo/gdal/blob/release/3.0/gdal/MIGRATION_GUIDE.TXT
Best regards,
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
Gdal 3.0, Proj 6, Python 3 only. Would this be sufficient change for an 8.0 release?
Doug
Doug Newcomb - Cartographer
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
__NOTE: This email correspondence and any attachments to and from this sender is subject to the Freedom of Information Act (FOIA) and may be disclosed to third parties.__​
