[GRASS-dev] [gdal-dev] git(hub) migration ?
Just to let us think again to git migration :slight_smile:
---------- Forwarded message ----------
Date: 6 September 2017 at 15:14
Subject: [gdal-dev] git(hub) migration ?
To: gdal-dev@lists.osgeo.org
I've heard a few voices speaking/asking/begging for a git/github
migration. At some point we'll certainly have to do it, as SVN vs git
is beginning to feel more and more like CVS vs SVN 15 years ago.
I can see different options :
1) migrate to git, and remain within the OSGeo infrastructure. This is
for example the case of GEOS which uses the Trac git plugin and the
GOGS (or is gitea?) git hosting
(https://git.osgeo.org/gogs/geos/geos.git). gogs/gitea tries to
replicate most github functionalities, but feature parity is still not
there (you cannot comment on a commit e.g). We could still offer
github as a mirror, which would ease contributions a bit compared to
the current git->svn situation, but the "Merge" button from github
couldn't (shouldn't) be used.
2) migrate code to github, accept pull requests (PR) directly there.
Tickets still managed in Trac. But then we have no automated link
between Trac and github (unless there's a Trac plugin for that). A few
other OSGeo projects are in a similar situation: QGIS with Redmine for
tickets and github for PR&code, GeoServer with JIRA for tickets and
github for PR&code. I've some experience with the QGIS situation:
Redmine can include github commit references if the git commit message
includes the ticket number. But, of course, the other way doesn't
work: from github UI, the #XXXX link doesn't work (or would point to a
unrelated PR with same number). So this is middly satisfactory, and a
regression from our current situation.
3) migrate code and tickets to github. I guess this would match most
(especially occasional) contributor wishes regarding the "social"
aspect. What would be needed is Trac -> github ticket migration.
Thomas Bonfort did it for MapServer at some point, but he lost the
script if I remember well (I can see in
https://stackoverflow.com/questions/6671584/how-to-export-trac-to-github-issues
a number of possibilities listed). One issue also is we have numbers
taken by existing github pull requests, so there would be collisions
on import (we could decide either to sacrifice colliding Trac tickets,
as there are really old, currently the colision appear for tickets
older than 2003, or move them to an available github ticket number. Or
to sacrifice existing PR, but there are a few pending ones)
There's also the valid concern about being tied with github.com
regarding tickets. Recently I found
https://github.com/josegonzalez/python-github-backup
which can backup code, issues, pull requests, etc.. using the github API.
Quickly tested it on their own repo. Seems to work (**), although a
bit slow ( requires 2 GET per issue / pull request to retrieve extra
details that are not retrieved by the global request you showed
above). It has an incremental mode though which should make it
efficient.
My synthetic view of the situation:
1) is a pure free sofware & free hosting approach. Relies on SAC being
appropriately man and machine powered (same as with SVN / Trac
currently)
2) mixed solution. we still have ownership on all our data (code &
tickets). but the separation between a ticket system and code+PR isn't
ideal from a usability point of view
3) offers probably the best contributor experience. We loose a bit of
control, but a backup(*) strategy exists (at least for now). I'd tend
to favor this approach.
I'm not sure if the current git mirror shouldn't be re-done from
scratch. Its main drawback is that svn tags are reported as git
branches, instead of git tags. I probably mis-configured things when I
initiated the mirror a few years ago. Not completely sure this is
worth the effort though. We can probably live with those existing
mis-created tags, and use proper git tags for the future.
The release procedure / script would also have to be updated. Probably
other things too.
There's also the question of the Trac Wiki, although this one might be
defered for a later stage.
So this email is mostly to say I'm open to the idea, but I'd
appreciate if someone else could take the lead on this. I'd be happy
to help. A RFC to formalize the move would be needed.
Even
(*) Backup might not be the inappropriate term, since this implies
that you can easily restore things. If github closes or requires
(insane) fees for open source projects, those saved tickets will have
to be re-injected in some to-be-defined alternative, but at least
their content is readable (json)
(**) steps:
1) pip install github-backup
2) in github UI, create a personnal access token, so as to be able to
use authenticated requests to github API, to bypass the rate limit of
unauthenticated requests (you can use it even for repositories that
you don't own)
3) github-backup -i -R python-github-backup josegonzalez --issues
--issue-comments --issue-events --pulls --pull-comments --pull-commits
-t ${your_github_token}
Spatialys - Geospatial professional services
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
ciao
Luca
www.lucadelu.org
2017-09-06 15:35 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
yes, such experience (GDAL migration) will be highly valuable for us.
I feel it's topic for Bonn code sprint. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Wed, Sep 6, 2017 at 8:25 PM, Martin Landa <landa.martin@gmail.com> wrote:
Yes, we need to discuss it thoroughly then because it is a complex topic.
@all: please read Even's email:
https://lists.osgeo.org/pipermail/gdal-dev/2017-September/047060.html
If there are talks about migration to git, I would strongly suggest to
evaluate also GitLab as an option. I haven't been migrating Trac to
GitLab thus can not comment how easy that would be, still google
search shows some options (i.e.
https://github.com/moimael/trac-to-gitlab).
Keep in mind - migrating to git is not so straight forward as CVS to
SVN. We will need to come up with git usage pattern that fits us the
best and some of them are not easy to understand at the first moment
:wink:
Māris.
2017-09-06 21:51 GMT+03:00 Markus Neteler <neteler@osgeo.org>:
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Personally, I have no opinion about it as it does not matter for me (cause I am no real developer).
So only for the record, this has been discussed extensively (again) also among PostGIS devs:
https://lists.osgeo.org/pipermail/postgis-devel/2017-August/026268.html
Tendency there seems to be that there is a significant interest in moving to git / github, but that at the end the decision is not to take any action (now) because of lack of consensus and the amount of work involved.
Yet, maybe it`s just procrastination...? Maybe also an argument that only moving to some git will stop the discussion from popping up again and again?
Stefan
-----Original Message-----
From: grass-dev [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Maris Nartiss
Sent: torsdag 7. september 2017 10.36
To: Markus Neteler <neteler@osgeo.org>
Cc: Martin Landa <landa.martin@gmail.com>; GRASS-dev <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] Fwd: [gdal-dev] git(hub) migration ?
If there are talks about migration to git, I would strongly suggest to evaluate also GitLab as an option. I haven't been migrating Trac to GitLab thus can not comment how easy that would be, still google search shows some options (i.e.
Keep in mind - migrating to git is not so straight forward as CVS to SVN. We will need to come up with git usage pattern that fits us the best and some of them are not easy to understand at the first moment
:wink:
Māris.
