[GRASS-dev] [gdal-dev] shapelib 1.5.0 release
Hi devs,
we still have an older copy of shapelib in
lib/external/shapelib/
Is that still needed/wanted for the upcoming 7.8.0 release?
If yes, to be updated?
---------- Forwarded message ---------
Date: Thu, Feb 28, 2019 at 5:14 PM
Subject: [gdal-dev] shapelib 1.5.0 release
To: <shapelib@lists.osgeo.org>
Cc: <gdal-dev@lists.osgeo.org>
(CC'ing gdal-dev as well, since shapelib@lists.osgeo.org has likely lower
audience)
I've released shapelib 1.5.0
The main change is the removal of the 'shpproj' contrib utility and thus PROJ
dependency.
The tarballs are available at:
http://download.osgeo.org/shapelib/shapelib-1.5.0.tar.gz
http://download.osgeo.org/shapelib/shapelib-1.5.0.zip
The log of changes since 1.4.1 is:
2019-02-28 Even Rouault <even.rouault at spatialys.com>
        * shpopen.c: resync with GDAL internal shapelib to avoid being dependent
        on correctness of file size field in .shp. Fixes
        https://lists.osgeo.org/pipermail/gdal-dev/2018-October/049218.html
        * contrib/shpgeo.h/.c: Remove PROJ.4 dependency and functionality,
         causing removal of SHPProject(), SHPSetProjection() and
SHPFreeProjection()
        * contrib/shpproj.c: removed
2018-08-16 Even Rouault <even.rouault at spatialys.com>
        * shpopen.c, dbfopen.c, shptree.c, sbnsearch.c: resyc with GDAL
        internal shapelib. Mostly to allow building those files as C++
        without warning. Also add FTDate entry in DBFFieldType
        (see https://github.com/OSGeo/gdal/pull/308). And some other
        code cleanups
        * dbfopen.c: fix a bug where the end of file character was
        written on top of the first character of the first field name
        when deleting a field on a .dbf without records.
        Fixes https://github.com/OSGeo/gdal/issues/863
2018-06-15 Even Rouault <even.rouault at spatialys.com>
        * safileio.c: remove duplicate test. Patch by Jaroslav Fojtik.
        Fixes http://bugzilla.maptools.org/show_bug.cgi?id=2744
Even
Spatialys - Geospatial professional services
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
On Sat, Apr 13, 2019 at 7:24 PM Markus Neteler <neteler@osgeo.org> wrote:
Hi devs,
GRASS is only using the dbf driver of shapelib. Updating is not not needed but would be nice to keep in sync with upstream. I can do it in the next few days.
Markus M
(CC’ing gdal-dev as well, since shapelib@lists.osgeo.org has likely lower
audience)
I’ve released shapelib 1.5.0
The main change is the removal of the ‘shpproj’ contrib utility and thus PROJ
dependency.
  • contrib/shpgeo.h/.c: Remove PROJ.4 dependency and functionality,
    SHPFreeProjection()
  • contrib/shpproj.c: removed
  • shpopen.c, dbfopen.c, shptree.c, sbnsearch.c: resyc with GDAL
    code cleanups
  • dbfopen.c: fix a bug where the end of file character was
Even
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
