[GRASS-dev] gdal-grass plugin or support in gdal for GRASS 7
What is the status / plans / time line for support in gdal, directly or through the gdal-grass plugin, for GRASS 7 vector layers? I had seen some emails on building gdal with GRASS 7 support with some success, but can’t find those emails nor any further news.
Hei Paolo,
This is the relevant GDAL ticket:
http://trac.osgeo.org/gdal/ticket/2953
The GRASS plugin on http://download.osgeo.org/gdal/ has not been updated yet, but in the meantime you can rebuild GDAL against GRASS 7.
Workflow would be:
Build GDAL 1.11 without GRASS Support
Build GRASS (7) against GDAL 1.11
Build GDAL 1.11 with GRASS 7 support
Using that workflow, GDAL managed to read GRASS 7 raster data on my Ubuntu 12.04 LTS Server. However, I am not sure if the fixes by hcho have been merged into the 1.11 release (or the latest code yet). So maybe reading GRASS data using only GDAL could give incorrect results (incorrect window read?)…
Others please correct me if I am wrong…
Stefan
On Tue, May 20, 2014 at 9:11 AM, Blumentrath, Stefan
<Stefan.Blumentrath@nina.no> wrote:
Hei Paolo,
Workflow would be:
You find that documented also here:
http://grasswiki.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin
Thanks, I know (I read) how to do this, but wasn’t sure it is actually working with GRASS 7. Happy to hear at least somebody managed :-). I will give it a try then.
[<Stefan.Blumentrath@nina.no>](mailto:Stefan.Blumentrath@nina.no) wrote:
Hei Paolo,
[http://trac.osgeo.org/gdal/ticket/2953](http://trac.osgeo.org/gdal/ticket/2953)
The GRASS plugin on [http://download.osgeo.org/gdal/](http://download.osgeo.org/gdal/) has not been updated
Workflow would be:
[http://grasswiki.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin](http://grasswiki.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin)
