[GRASS-dev] GDAL write support
I have committed preliminary, minimal, experimental, barely-tested
support for creating new maps via GDAL (i.e. like r.external, but in
the opposite direction).
The feature is enabled with r.external.out, which allows you to
optionally set the format (default GeoTIFF), extension (default none;
use e.g. extension=.tif to set it), directory where output files are
stored (default: <mapset>/gdal/) and any creation options (passed
directly to the driver).
Thereafter, any new raster maps will be generated via GDAL. The maps
should automatically be available to GRASS, as if they had been linked
with r.external.
Running "r.external.out -r" will revert to creating maps natively.
Maps previously created via GDAL should still work.
Limitations include (but probably aren't limited to):
1. The data type for integer maps is determined by
G_set_cell_format(), meaning that it will normally be Int32. Unlike
r.out.gdal, we don't know the range of the data when the output file
is opened.
2. If the driver for the format doesn't support direct writing, the
data will intially be written via the memory driver, then copied to
the file upon close. I'm guessing that this requires the map to fit
into memory. r.external.out should print a warning if you choose such
a driver.
3. If you write data type which the format can't handle (e.g. writing
Float64 to PNG), you lose.
4. Colour tables aren't included in the file. GRASS treats colour
tables as distinct entities; the code which creates the raster data
doesn't know about the colour table, or if one will even be created.
Colour tables are normally only written after the map is closed, at
which point it may be too late to add it to the image file.
5. Projection information isn't written either. The code which would
need to do this is in lib/gis, which can't use e.g. GPJ_grass_to_wkt()
from lib/proj because of circular dependency issues. I suppose that I
could make r.external.out create a WKT version of the projection data,
but then you run into problems if the projection is subsequently
changed.
6. You can't store multiple maps in a single multi-band file.
On Sat, Dec 6, 2008 at 10:27 AM, Glynn Clements
This sounds great!
Small suggestion: Perhaps rename to
r.in.external
r.out.external
r.in.external
r.out.external
I'm a bit unsure about naming. In particular, they aren't especially
symmetrical. r.external makes a specific existing GDAL dataset appear
as GRASS map, while r.external.out is a global switch.
[Having to "pre-link" output maps before each command would have been
a nuisance to use.]
r.external was chosen for equivalence with v.external. r.external.out
was chosen because I couldn't really think of a better name.
My main goal with this is with regard to making incompatible changes
to the raster format (e.g. storing all files for a map in a single
directory, as with vectors). If maps can be read via GDAL, and GDAL
includes support for the legacy GRASS formats, it wouldn't be
necessary to natively support both the old and new formats
simultaneously.
with r.external.
Wish: could a flag the added to print the current state? Say, I am
activating it in a mapset, then stop working and reuse the mapset
after some month, I hardly remember how things were...
I have tested the module today:
r.external terra_lst1km20030314.LST_Day_1km.tif out=modis_celsius
# define output directory for GRASS calculation results:
r.external.out $HOME/gisoutput/
# do something (here: extract pixels > 20°C), write output directly as GeoTIFF:
r.mapcalc "warm.tif = if(modis_celsius > 20, modis_celsius, null() )"
# use the result elsewhere
qgis $HOME/gisoutput/warm.tif
The resulting map, unfortunately is all NULL:
gdalinfo -mm $HOME/gisoutput/warm.tif
Band 1 Block=3264x1 Type=Int32, ColorInterp=Gray
    Computed Min/Max=-2147483648.000,-2147483648.000
  NoData Value=2147483648
It works ok with integer:
r.mapcalc "myint.tif = col()"
gdalinfo -mm myint.tif
Band 1 Block=34x27 Type=Int32, ColorInterp=Gray
    Computed Min/Max=1.000,34.000
Another FLOAT test:
r.mapcalc "myfloat.tif = 0.5 / col() "
qgis myfloat.tif
-> partially broken as nodata strips appear
is opened.
As I understand it, we cannot know the map type a priori. Is it changed
on the fly in case of float maps?
a driver.
Is this test reasonable?
    if( GDALGetDriverByName( "MEM" ) != NULL )
        G_warning(_("MEMORY driver is used which can lead to swapping"));
... this should also apply to r.out.gdal, right?
changed.
IMHO a WKT file would be better than losing the information completely.
Not a severe problem since GDAL tools are available for that conversion.
The module will be very attractive to those who want to use GRASS as
GIS backbone while keeping the data outside of GRASS in common
formats.
> with r.external.
Done in r41521.
Another FLOAT test:
qgis myfloat.tif
If I use:
  r.external.out
  r.mapcalc 'foo = float(elevation.dem)'
The resulting map works within GRASS:
  Driver: GTiff/GeoTIFF
  Files: /opt/grass-data/spearfish57/glynn/gdal/foo
  Size is 1899, 1398
  Coordinate System is `'
  Origin = (590010.000000000000000,4928000.000000000000000)
  Pixel Size = (10.000000000000000,-10.000000000000000)
  Image Structure Metadata:
    INTERLEAVE=BAND
  Corner Coordinates:
  Upper Left ( 590010.000, 4928000.000)
  Lower Left ( 590010.000, 4914020.000)
  Upper Right ( 609000.000, 4928000.000)
  Lower Right ( 609000.000, 4914020.000)
  Center ( 599505.000, 4921010.000)
  Band 1 Block=1899x1 Type=Float32, ColorInterp=Gray
    NoData Value=nan
> is opened.
It's decided at open time.
For integer maps, it's GDT_Byte, GDT_UInt16 or GDT_Int32, as set by
G_set_cell_format(), defaulting to GDT_Int32.
For FP maps, it's GDT_Float32 for FCELL and GDT_Float64 for DCELL (the
choice is determined by Rast_set_fp_type(), defaulting to DCELL if
$GRASS_FP_DOUBLE exists and FCELL otherwise).
> a driver.
The code already prints a message if it uses the memory driver;
lib/raster/gdal.c, lines 448-455:
    /* If not - create MEM driver for intermediate dataset.
     * Check if raster can be created at all (with GDALCreateCopy) */
    else if ((*pGDALGetMetadataItem) (driver, GDAL_DCAP_CREATECOPY, NULL)) {
  GDALDriverH mem_driver;
  G_message(_("Driver <%s> does not support direct writing. "
        "Using MEM driver for intermediate dataset."),
      st->opts.format);
It applies to anything; I don't know how r.out.gdal itself handles it.
> changed.
I'm not sure that you understood what I wrote. The code to convert
GRASS' projection information to WKT cannot be used by lib/raster,
only by modules, so it cannot be used at the point that a raster map
is written via GDAL.
A WKT version could be created by r.external.out then simply copied
into the output at creation time. But if you change the projection,
the WKT data will then be out of sync. If you want to be able to write
maps with projection information via GDAL, g.proj really needs to be
changed to maintain a WKT version of the projection information as
well as the GRASS version.
