Hello,
Would it be possible to create a kind of Wizard to assist
download/install of extensions with GEM?
1-locate GEM enabled extensions (http://wiki…)
2-Download in ~/tmp
3-run gem on it
Yann
Hello,
2-Download in ~/tmp
3-run gem on it
Yann
I guess it wouldn't be too much trouble. GEM already has all that's
needed for this: zipped extension packages can be downloaded (using
wget), unzipped (to system's temp dir) and installed automatically.
There is just one catch: since all files are installed into system-wide
locations, the wizard will probably need superuser rights. So a tcl/tk
based install wizard needs to provide a way to get the superuser
password and run system commands with elevated rights.
It would be a cool thing to have, I agree.
Ben
Yann wrote:
Hello,
download/install of extensions with GEM?1-locate GEM enabled extensions (http://wiki…)
2-Download in ~/tmp
3-run gem on itYann
grass-dev mailing list
grass-dev@grass.itc.it
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
Thanks Ben,
Is there anybody that knows abit a tcltk that could add info about where it
should go coding wise?
Yann
password and run system commands with elevated rights.It would be a cool thing to have, I agree.
Ben
Yann wrote:
> Hello,
> 2-Download in ~/tmp
> 3-run gem on it
> Yann
Yann Chemin
Sainte-Anne d'Auray, France
Ben,
is GEM installing "Xtns" in wxPython GUI?
Yann
Ben
Yann wrote:
> Hello,
> 2-Download in ~/tmp
> 3-run gem on it
> Yann
Yann Chemin
No, I don't have a version of GRASS that support wxPython and the new
GUI, yet. Just never had the time to get that new stuff running.
I am waiting for the wxPython stuff to stabilize and reach beta level,
before I put lots of time into doing this. Right now, it's hard for me
to judge where the new GUI is headed and what would be the best way to
integrate GEM-generated menus ...
Yann wrote:
Ben,
Yann
Ben
Yann wrote:
Hello,
2-Download in ~/tmp
3-run gem on itYann
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
I'm not following GEM development and thus have two silly questions:
1) isn't possible to install additional modules via GEM into user's
home directory (as option)? Thus it could be made as easy as
installing some addons to Firefox.
2) if getting superuser support for GUI right is lot of work, could
some GUI wizard just generate some commandline expression that could
be just pasted into terminal by user as last step to run it via su or
sudo?
Just my 0.02.
Maris.
2007/5/21, Benjamin Ducke <benjamin.ducke@ufg.uni-kiel.de>:
Ben
Yann wrote:
> Hello,
> 2-Download in ~/tmp
> 3-run gem on it
> Yann
Archäoinformatik
D 24098 Kiel
GermanyTel.: ++49 (0)431 880-3378 / -3379
www.uni-kiel.de/ufg_______________________________________________
A last question:
Which Extensions are GEM "certified" so far and where can we download them?
thanks
Yann
integrate GEM-generated menus ...Yann wrote:
> Ben,
> Yann
>> Ben
>> Yann wrote:
>>> Hello,
>>> 2-Download in ~/tmp
>>> 3-run gem on it
>>> Yann
Yann Chemin
As far as I am aware, there are only a few extensions that I have
created that actually make use of GEM, so far (sniff).
Most importantly, spatial predictive modelling (which includes a generic
Dempster-Shafer Theory framework for evidence-based modelling with
raster data) and some advanced viewshed modelling with cumulative
viewshed analysis. The newest version of GEM is already included in the
GRASS 6.3 CVS and the executable is called "gem6".
Everything can be downloaded here:
http://www.uni-kiel.de/ufg/ufg_BerDucke.htm (bottom of page).
However, I am currently hard at work migrating the code to Win32, doing
a lot of bugfixing, etc. which is all made more complicated by a number
of issues that currently exist in the Win32 version of GRASS (argh!).
So I cannot currently support these versions of my extensions, due to a
lack of time. As soon as the Win32 stuff has been smoothed out, I will
substantially update my code base, documentation etc.!
There is also a pretty flexible territorial modelling tools in the pipeline.
Best,
Benjamin
Yann wrote:
A last question:
thanks
Ben,
Yann
Ben
Yann wrote:
Hello,
2-Download in ~/tmp
3-run gem on itYann
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
These modeling tools seem interesting!
thanks Ben, I'll try to check that out.
Yann
GRASS 6.3 CVS and the executable is called "gem6".Everything can be downloaded here:
http://www.uni-kiel.de/ufg/ufg_BerDucke.htm (bottom of page).However, I am currently hard at work migrating the code to Win32, doing
substantially update my code base, documentation etc.!There is also a pretty flexible territorial modelling tools in the
pipeline.Best,
Benjamin
Yann wrote:
> A last question:
> them?
> thanks
> Yann
>> Yann wrote:
>>> Ben,
>>> Yann
>>>> system-wide locations, the wizard will probably need superuser rights.
>>>> So a tcl/tk based install wizard needs to provide a way to get the
>>>> superuser password and run system commands with elevated rights.
>>>> Ben
>>>> Yann wrote:
>>>>> Hello,
>>>>> 2-Download in ~/tmp
>>>>> 3-run gem on it
>>>>> Yann
Yann Chemin
Could you keep those of us working on the win port informed about your problems and your advances ? Just so that we coordinate efforts a bit.
Moritz
Sure,
just got back from the Windows PC lab with some new testing results.
Will post a more verbose mail in a moment ...
Benjamin
substantially update my code base, documentation etc.!Could you keep those of us working on the win port informed about your
problems and your advances ? Just so that we coordinate efforts a bit.Thanks,
Moritz
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
I've been meaning to ask about this root/external mod issue - is there any plan to support installation of GEM modules in a user dir? More than just a problem of HOW to run this as root in the GUI, it's also a bit of a security problem and a platform standardization issue.
On OSX, installing extras into an application binary is not the way things are done. They should be installed in a standard plugin/extension location for the application - /Library so it is globally available to users, or ~/Library to make it available only for a single user.
These locations act as extra GIS_BASEs, in effect - they have bin, lib, etc, doc... subfolders. By use of standard GRASS env vars, they are easily included into the GRASS environment, and I recently added similar env vars and functions to locate external etc/ support files for modules that need it.
For the OSX application build I've set [~]/Library/GRASS/$version/Modules as the global/user locations. For now I have a separate module build template, much like GEM, but built modules must then be manually copied to one of these locations, since I'm too lazy to figure out alternate install targets in the makefiles.
It would be nice to have GEM able to install in these locations at least, if not also arbitrary locations. We would need to figure out good standard locations for other platforms also.
On May 21, 2007, at 5:53 AM, Maris Nartiss wrote:
sudo?Just my 0.02.
Maris.2007/5/21, Benjamin Ducke <benjamin.ducke@ufg.uni-kiel.de>:
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
imho something like GRASS_ADDONS (so GRASS_GEM) path would solve this.
And it is IMHO another reason for $HOME/.grass/ configuration directory
Jachym
William Kyngesburye píše v Po 21. 05. 2007 v 15:27 -0500:
also a bit of a security problem and a platform standardization issue.On OSX, installing extras into an application binary is not the way
single user.These locations act as extra GIS_BASEs, in effect - they have bin,
for modules that need it.For the OSX application build I've set [~]/Library/GRASS/$version/
figure out alternate install targets in the makefiles.It would be nice to have GEM able to install in these locations at
good standard locations for other platforms also.On May 21, 2007, at 5:53 AM, Maris Nartiss wrote:
> Hi,
> sudo?
> Just my 0.02.
> Maris.
>> wide
>> tcl/tk
>> password and run system commands with elevated rights.-----
http://www.kyngchaos.com/"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."- Hitchhiker's Guide to the Galaxy
Jachym Cepicky
e-mail: jachym.cepicky@gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
On May 21, 2007, at 4:08 PM, Jachym Cepicky wrote:
Right now, my etc/ find uses GRASS_ADDON_ETC. It might be nice to consolidate the various env vars. Assuming that they all always coincide with the same root.
Jachym
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
Actually, it's not much of a problem to introduce a new default and/or
optional install prefix in GEM. The real trouble lies in two different
areas, as far as I can think of right now:
1. The HTML man pages for the newly installed modules should be
integrated into main HTML index. Currently, GEM manipulates the main
HTML index in the install dir to do so. Of course, this requires
superuser rights. The ideal solution would be to have a placeholder in
the global HTML frontpage that will point to a subindex page present in
the user's local extension directory. No idea how to do that in HTML
2. Many people like to have new GUI menu entries in gis.m when they
install additional modules. This means that gis.m has to be prepared to
look for additional menu entries in the current user's extension
directory. This should not be too hard to do.
In principle, I agree that it would be much better to have locally
installed extension. This could simplify the logics behing GEM a lot,
too. It would also be possible to keep both the global and local
installation schemes side-by-side, as a system-wide extension management
would probably also have its merits.
Benjamin
a single user.These locations act as extra GIS_BASEs, in effect - they have bin, lib,
I'm too lazy to figure out alternate install targets in the makefiles.It would be nice to have GEM able to install in these locations at
sudo?Just my 0.02.
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
You might want to take a look at what I did in the OSX app build - macosx/app/build_html_user_index.sh and build_gui_user_menu.sh. Both are run at startup. They could easily be made to work for all platforms. The nice thing about these is that less configuration needs to be done at install time, since they are dynamic.
areas, as far as I can think of right now:1. The HTML man pages for the newly installed modules should be
The user html index is separate from the main index. The GUI would have to have a dynamic menu item for it so that it would have the full path to the user's home. I initially tried ~ in the <a href> and strangely it worked, but it turned out to be a Safari-only thing. The global addon index is easy eanough, since it would not change with the logged-in user.
I still need to work on g.manual and the non-GUI command dialogs (ie when run without params) - they don't see the user help files yet.
I don't think Michael has a user help menu item in the GUI yet, but the help index is still available in OSX since I have also integrated it with the system help mechanism.
The script creates GEM-like menu files for the user commands. For scripts I simply test for the #% Module tag, and for compiled modules I use 'file' to check for binary executables (I assume a binary in these locations is made for GRASS).
I mentioned this to Michael, but he hasn't worked it into the TclTk GUI yet (I don't know any TclTk to try this). It should be just as simple to do for the Python GUI.
Just to make sure we're on the same wavelength, when I say 'global', I mean a system location still external to the installed GRASS application. Global just means all users can access it.
In effect, it's just like having in the installed GRASS, but on OSX at least it's really preferable to have a separate global addon location. I don't know what that would be in Windows, but on Linux it might be something like /usr/local/share.
So, that would be 3 install location choices: application, global and user.
All generalizations are dangerous, even this one.
On 5/22/07 12:01 AM, "Benjamin Ducke" <benjamin.ducke@ufg.uni-kiel.de>
the user's local extension directory. No idea how to do that in HTML2. Many people like to have new GUI menu entries in gis.m when they
directory. This should not be too hard to do.In principle, I agree that it would be much better to have locally
would probably also have its merits.Benjamin
Why not try to solve these issues one at a time. Having a simple way to
create, install, and manage extensions would be a real plus and could
stimulate use of the GEM system. IMHO, we should focus on getting this right
and worry about the help files and menus a bit later.
To make life easier, why not simply keep the html help files with the
extensions and have all extensions, by default, look for help files in the
default extensions directory? Also, people can manually look at help files
if they are in an easily accessible directory. A bit of an inconvenience,
but users will be installing extensions of their choice and will have some
idea of what they want.
I'm a big fan of GUI's and having commands listed on a menu so you don't
have to remember them. BUT, getting extensions listed on the existing GUI
menu system is a pain. To get the rest of the system in general operation,
maybe just skip this. Since any extension will be installed by a user, who
presumably will know what she/he installed, calling one or two from the
command line won't be that much of a burden.
We can then think about better ways to get extensions into the menu. The
menu system is being rethought anyway with the switch to wxPython, so we
could design it with the possibility of extensions in mind if they become
widely used and the details of how and where to install them get ironed out.
For example, the menu could simply have an empty place holder for
extensions. A menu-building function could then scan the default extensions
directory to see if a menu file exists and use it to fill in the
place-holder.
Michael
sudo?Just my 0.02.
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Since my time to work on GEM is very limited at the moment (basically none):
As far as menu entries are concerned, I'd opt for doing from the ground
up with the new wxPython GUI and just leave it the way it is for gis.m.
The ideal solution would be a directory-based inclusion mechanism: if a
directory exists in a certain place, then it will be scanned for menu
entries to add to the extensions menu.
HTML pages: with a built-in HTML Python widget, we could easily solve
the issue of global vs. local indices. For now, I'd just skip the HTML
installation and let users locate the manpages themselves.
Now, the only remaining question is where to store all extension files
(by default). We need a directory that work cross-platform (or at least
a unified way to figure out a user home directory on all supported
platforms; possible as a new function in the C API).
wrote:Actually, it's not much of a problem to introduce a new default and/or
and worry about the help files and menus a bit later.To make life easier, why not simply keep the html help files with the
idea of what they want.I'm a big fan of GUI's and having commands listed on a menu so you don't
command line won't be that much of a burden.We can then think about better ways to get extensions into the menu. The
place-holder.Michael
sudo?Just my 0.02.
Arizona State Universityphone: 480-965-6213
fax: 480-965-7671
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
+1
place-holder.
Yann Chemin
I'd prefer something that is appropriate for the platform. ie the /Library/GRASS and ~/Library/GRASS I'm using for the OSX app build.
The simple way to solve the choice is to use env vars, like the rest of GRASS. That way the mechanism is there and the user or packager can decide what is appropriate, and the user can add to it at runtime if needed. (I set some user dirs in the OSX app startup script, before init.sh is run, to handle this)
Note - there is a libgis function to get a user's home: G_home(). It should work on all platforms (it has a mingw special case, but maybe it doesn't work on the Win native build?). It would be handy to have a command equivalent to use in scripts, like g.home.
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
