[GRASS-dev] geocoding module
Hi devs,
do you know if a geocoding module for GRASS already exists ?
otherwise I could do it as addons
ciao
Luca
www.lucadelu.org
On Tue, Oct 18, 2016 at 2:54 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi devs,
Hi Luca,
a tool using an address database such as OSM nominatim?
Not that I am aware of..
best
> Hi devs,
Hi Luca,
Slightly out of topic, but in case this helps: there's a bridge between OGR
and a few geocoding services. See
http://download.osgeo.org/gdal/workshop/foss4ge2015/workshop_gdal.html#__RefHeading__6011_1333016408
best
grass-dev mailing list
grass-dev@lists.osgeo.org
Spatialys - Geospatial professional services
http://www.spatialys.com
Hi devs,
Hi Luca,
yes
ok thanks, I will work on it in the days
best
ciao
Luca
www.lucadelu.org
On 18 October 2016 at 16:45, Even Rouault <even.rouault@spatialys.com> wrote:
my idea was to use the python libraries geopy o geocoder, but also OGR
could be a good idea, so there are no external dependencies
Thanks for the suggestion
ciao
Luca
www.lucadelu.org
