[GRASS-dev] georect.py
Hello list,
working on grass6.5.0 (revision 36499), I met a problem with the
geo-rectify tool.
After pointing the first tic, when trying to navigate in the image to be
rectified, the display freezes. The following message appears right at
the moment we click the first tic :
          File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/ma
        pdisp_window.py", line 1007, in MouseActions
        self.OnLeftUp(event)
        pdisp_window.py", line 1737, in OnLeftUp
        self.UpdateMap(render=False, renderVector=False)
        pdisp_window.py", line 725, in UpdateMap
        self.parent.GetLayerManager().georectifying.DrawGCP(coordtyp
        e)
          File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/ge
        orect.py", line 881, in DrawGCP
        5]})
        pdisp_window.py", line 983, in DrawCross
        pdctype='text', coords=coord)
        pdisp_window.py", line 366, in Draw
        pdc.DrawText(img['text'], coords[0], coords[1])
          File "/usr/local/grass-6.5.svn/etc/wxpython/vdigit/grass6_
        wxvdigit.py", line 372, in DrawText
        def DrawText(*args): return
        _grass6_wxvdigit.PseudoDC_DrawText(*args)
        TypeError
        in method 'PseudoDC_DrawText', argument 3 of type 'int'
        e)
        5]})
        TypeError
        pdisp_window.py", line 1702, in OnLeftUp
        self.UpdateMap(render=True)
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        e)
        5]})
        TypeError
        pdisp_window.py", line 999, in MouseActions
        self.OnMouseWheel(event)
        pdisp_window.py", line 1057, in OnMouseWheel
        self.UpdateMap()
        e)
        5]})
        TypeError
        self.UpdateMap()
        e)
        5]})
        TypeError
Could the source of this problem be my configuration of wxpython ? (no
errors detected at compilation)
Vincent.
2009/3/28 Vincent Bain <bain@toraval.fr>:
   pdctype=&#39;text&#39;, coords=coord\)
     File &quot;/usr/local/grass\-6\.5\.svn/etc/wxpython/gui\_modules/ma
   pdisp\_window\.py&quot;, line 366, in Draw
try to put before this line
print type(coords[0]), type(coords[1])
<type 'int'> <type 'int'> should be printed.
   pdc\.DrawText\(img\[&#39;text&#39;\], coords\[0\], coords\[1\]\)
     File &quot;/usr/local/grass\-6\.5\.svn/etc/wxpython/vdigit/grass6\_
   wxvdigit\.py&quot;, line 372, in DrawText
   def DrawText\(\*args\): return
   \_grass6\_wxvdigit\.PseudoDC\_DrawText\(\*args\)
   TypeError
   in method &#39;PseudoDC\_DrawText&#39;, argument 3 of type &#39;int&#39;
It's related to the local copy of PseudoDC from vdigit. BTW, which
version of swig are you using?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Le samedi 28 mars 2009 à 14:29 +0100, Martin Landa a écrit :
modified the file the way you suggest, but the command now returns <type
'float'> <type 'float'> instead.
swig -version :
1.3.36
VB
Hopefully fixed in r36503.
M.
Thank you Martin, it is fixed !
again in the georectify module, a display error occurs when trying to
resume a previous referencing session (ie when some gcp where already
defined for a given raster) -- not crucial in fact.
The error message is the following :
          File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py",
        line 361, in OnGeorectify
        georect.GeorectWizard(self)
        orect.py", line 196, in __init__
        self.gcpmgr.SetMapDisplay(self.xy_mapdisp)
        orect.py", line 792, in SetMapDisplay
        self.list.LoadData()
        orect.py", line 1292, in LoadData
        self.gcp.ReadGCPs()
        orect.py", line 990, in ReadGCPs
        sourceMapWin.UpdateMap(render=False, renderVector=False)
        e)
        orect.py", line 858, in DrawGCP
        wxCol = wx.Colour(col[0], col[1], col[2], 255)
          File "/usr/lib/python2.5/site-
        packages/wx-2.8-gtk2-unicode/wx/_gdi.py", line 114, in
        __init__
        _gdi_.Colour_swiginit(self,_gdi_.new_Colour(*args,
        **kwargs))
        TypeError
        in method 'new_Colour', expected argument 1 of type 'byte'
Vincent
