[GRASS-dev] georectifier fixes
I just committed a set of fixes to the georectifier. This should fix all
reported bugs. (can't speak for new ones, but hopefully there aren't any).
Please test.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 1 Nov 2006 16:09:09 +0100
To: Michael Barton <michael.barton@asu.edu>
Subject: Re: [GRASS-dev] call for last minute testers
On Wed, 01 Nov 2006 07:53:09 -0700
Michael Barton <michael.barton@asu.edu> wrote:
Thanks. I'll check it out. You can always edit a group by running i.group
from the xy location, but it ought to work from the georectifier.
thanks a lot!
Otto
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 1 Nov 2006 09:32:44 +0100
Cc: <grass-dev@grass.itc.it>
On Tue, 31 Oct 2006 12:18:38 -0700
Otto,
I had sent in the wrong version of a georectifier update last night. I sent
in a new one this morning to Markus, who put it into 6.2. I just added it
to
6.3 a moment ago. I don't know if this fixes the problem you are having,
but
you might test it. Thanks for the info.
Hi Michael,
Thanks for the fix. I just tested it with the new snapshot from
http://grass.itc.it/grass62/source/snapshot/ but with the same error.
And another problem occurs. I am not able to create/edit a group anymore.
The
second button only works for vector rectification but not for raster.
regards,
Otto
Michale
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 31 Oct 2006 14:05:13 +0100
To: <grass-dev@grass.itc.it>
On Tue, 31 Oct 2006 23:40:13 +1300
Hamish <hamish_nospam@yahoo.com> wrote:
Michael & myself have just applied some last minute patches to gis.m to
make it compatible with tcl/tk 8.3. As this will be released with 6.2.0
without much (any) testing, if everyone could quickly update gis.m in
their cvs (6.3 is probably fine, 6.2 branch is better- it's the same),
make, and double check that we haven't broken anything? (main toolbar
and the georectifyer canvas toolbar)
using the "clear all GPC entries" button (in the georectifyer) after
setting
various GCPs only clears the first 2 columns of the first line, but the
forward
and backward errors remain with following error message (command name
below
is the RMS error in line 1 third col):
invalid command name "0.590568"
    while executing
"$fwd_error($gcpnum) delete 0 end"
    (procedure "GRMap::cleargcp" line 14)
    invoked from within
"GRMap::cleargcp"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
    (command bound to event
I tested with the 6.2 snapshot. Maybe someone can reproduce this?
regards,
  Otto
thanks a lot,
Hamish
On Wed, 01 Nov 2006 11:38:19 -0700
Please test.
the "clear all GPC entries" button is working now - thanks a lot!
It deletes all entries. Would it be possible that it depends on wether a GCP is
used (selected) or not? I think that would be useful, after choosing the best
GCPs I could delete the rest very easily.
The second error still exists. The create/edit a group button doesn't work.
kind regards,
Otto
Michael
phone: 480-965-6213
fax: 480-965-7671
> From: Otto Dassau <otto.dassau@gmx.de>
> thanks a lot!
> Otto
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>>> Otto,
sent
> to
> but
>>> Hi Michael,
> The
>>> regards,
>>> Otto
>>>> Michale
>>>> phone: 480-965-6213
>>>> fax: 480-965-7671
>>>>>> Hi,
>>>>> Hi,
> setting
>>>>> forward
> below
>>>>> while executing
>>>>> invoked from within
>>>>> "GRMap::cleargcp"
>>>>> invoked from within
>>>>> "uplevel \#0 $cmd"
>>>>> invoked from within
>>>>> regards,
>>>>> Otto
>>>>>> thanks a lot,
>>>>>> Hamish
Otto,
The idea about clearing all unchecked gcp's is easy to implement and sounds
very useful.
It is odd about the i.group problem. When I click the creat/edit group
button, it switches to the xy location/mapset and runs i.group on my
computer. What happens on yours?
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 1 Nov 2006 20:20:21 +0100
Cc: Hamish <hamish_nospam@yahoo.com>, GRASS developers list
Subject: Re: georectifier fixes
Please test.
is
kind regards,
Otto
On Wed, 01 Nov 2006 12:32:39 -0700
Otto,
very useful.
nothing, not even an error. I have a debian testing and compile GRASS with
--with-tcltk-includes=/usr/include/tcl8.4.
I don't know why it doesn't work. Maybe we should wait for someone else with
debian testing who can try. Maybe I do something wrong.
thanks
  Otto
Michael
phone: 480-965-6213
fax: 480-965-7671
>> Please test.
> is
best
> kind regards,
> Otto
sounds very useful.
what about a "quit georectifier" button to exit?
Hamish
> group button, it switches to the xy location/mapset and runs i.group
> on my computer. What happens on yours?
with --with-tcltk-includes=/usr/include/tcl8.4.
else with debian testing who can try. Maybe I do something wrong.
[debian/stable (sarge)]
the problem I got: gis.m file->georectify "2. Create edit group"
switches to source location/mapset, but then switches back to original
mapset right away, so i.group runs in the target mapset instead of
source mapset. if you had already created a group in the source mapset
you can continue, but otherwise you're stuck.
If I modify the source, adding "after 5000" to have the Tcl sleep for
5sec after running i.group, I can get i.group to act in the source
mapset for a fleeting moment, but if I then cancel & reclick the folder
icon I then see the available groups in the originial (target) mapset.
That is what happens with 6.2.0. With the latest 6.3, clicking the "2."
button does nothing (although mapset changes fly by in the output
window).
Hamish
Hamish
Date: Thu, 2 Nov 2006 15:41:55 +1300
To: Otto Dassau <otto.dassau@gmx.de>
Cc: <michael.barton@asu.edu>, <grass-dev@grass.itc.it>
I "fixed" this by having i.group run modally. The georectifier script should
not continue until you close i.group
This won't work, as you noted.
window).
i.group is running as a modal command under x11 on my Mac. Obviously it is
not running modally on your Debian system. Maybe Glynn or someone can offer
a clue.
I am running it in TclTk as ...
Set cmd "i.group"
Catch {exec -- $cmd}
[I use catch because closing the i.group dialog generates a non-meaningful,
non-fatal, but annoying TclTk error message]
phone: 480-965-6213
fax: 480-965-7671
On Thu, 2 Nov 2006 15:41:55 +1300
window).
changing line 347 as proposed by Michael in $GISBASE/etc/gm/georect.tcl
# catch {exec -- $cmd}
      exec -- $cmd
sais sth. like:
Error: Parameter <group> not set:
maybe this helps: In GRASS 6.2.0RC3 it worked.
  Otto
      exec -- $cmd
sais sth. like:
try
exec -- $cmd --ui
to force GUI mode.
but is that running in current mapset (wrong) or switched to target
mapset (correct)?
Hamish
On Thu, 2 Nov 2006 21:11:25 +1300
> exec -- $cmd
> sais sth. like:
try
exec -- $cmd --ui
to force GUI mode.
now it works. Clicking on the edit/create button opens the i.group window.
mapset (correct)?
what do you mean here, it is running in current mapset. I list my procedure,
maybe I missunderstand:
- I start GRASS in spearfish/PERMANENT
- I Import a not geocoded map (topographic map)
- I start georectifier
- I choose mapset PERMANENT
- I choose a new group and the map I want to rectify
- When I close the i.group window following message appears, but it still works:
child process exited abnormally
    while executing
"exec -- $cmd --ui"
    (procedure "GRMap::group" line 17)
    invoked from within
"GRMap::group"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
"Button::_release .grstart.mf.frame.group.a"
    (command bound to event)
and set GCPs
- Then I select the group a just created
- I select the map to rectify
- I start to set my GCPs and rectify.
- The result is ok and in stored the current mapset PERMANENT.
BTW: Is it intended that there are two ways to use the module?
a) I set GCPs and fill in the appropriate coordinates in the 2nd column
manually.
b) I set GCPs and fill in the appropriate coordinates interactively opening a
second monitor with a reference map where I click in the map to find
the right coordinates. The coordinates are inserted in the rectifier then...
regards,
Otto
Hamish
I'm a bit confused. Could clarify the following.
1. Did the new georect.tcl work -- the one in the 6.3 head? This one
*should* switch to the source mapset, run i.group, and wait until you're
done before switching back to the target mapset.
2. If it did not work, did you get the following error with the newest
georect.tcl?
This is an i.group error that suggests this grass command failed for some
reason
3. If the newest version (i.e., in the 6.3 head) works with adding the --ui
switch, that's fantastic. But I need to know if that actually fixes it for
you guys or if it was already fixed without this.
MIchael
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 2 Nov 2006 10:11:33 +0100
To: Hamish <hamish_nospam@yahoo.com>
exec -- $cmd
sais sth. like:
try
exec -- $cmd --ui
to force GUI mode.
mapset (correct)?
works:
    while executing
"exec -- $cmd --ui"
    invoked from within
"GRMap::group"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
and set GCPs
manually.
regards,
Otto
Hamish
On Thu, 02 Nov 2006 06:22:56 -0700
yes, it works in the 6.3 head here. I rectified a map this morning using the
georectifier in 6.3 head.
georect.tcl?
reason
the i.group window opens, but when I close the "error" message below appears,
but I can still go on rectiifying.
     while executing
"exec -- $cmd --ui"
     invoked from within
"GRMap::group"
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
and set GCPs
is it clearer now?
regards,
Otto
PS: currently I am only online from time to time - sorry.
> works:
MIchael
phone: 480-965-6213
fax: 480-965-7671
>>> exec -- $cmd
>>> sais sth. like:
>> try
>> exec -- $cmd --ui
>> to force GUI mode.
>> mapset (correct)?
> works:
> while executing
> "exec -- $cmd --ui"
> invoked from within
> "GRMap::group"
> invoked from within
> "uplevel \#0 $cmd"
> invoked from within
> and set GCPs
> manually.
a
> regards,
> Otto
>> Hamish
It sounds like you just need to put it back the way it was before. That is,
put the "catch {exec -- $cmd}" back in.
Using the "catch" statement traps this annoying error message.
Do you need the --ui flag?
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 2 Nov 2006 19:40:48 +0100
Cc: Hamish <hamish_nospam@yahoo.com>, <grass-dev@grass.itc.it>
georect.tcl?
reason
     while executing
"exec -- $cmd --ui"
     invoked from within
"GRMap::group"
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
and set GCPs
is it clearer now?
regards,
Otto
works:
MIchael
phone: 480-965-6213
fax: 480-965-7671
exec -- $cmd
sais sth. like:
try
exec -- $cmd --ui
to force GUI mode.
mapset (correct)?
works:
    while executing
"exec -- $cmd --ui"
    invoked from within
"GRMap::group"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
and set GCPs
manually.
a
regards,
Otto
Hamish
Otto and Hamish,
I got a student here with Debian Ubuntu (Mepis) to try the --ui switch for
the i.group command in georectify.tcl. It seems to solve the problem of
i.group flashing on and off.
Thanks very much Hamish for suggesting it. It's in the cvs now. I'm copying
Markus so that he can backport it to 6.2.1
Michael
phone: 480-965-6213
fax: 480-965-7671
georect.tcl?
reason
     while executing
"exec -- $cmd --ui"
     invoked from within
"GRMap::group"
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
and set GCPs
is it clearer now?
regards,
Otto
works:
MIchael
phone: 480-965-6213
fax: 480-965-7671
exec -- $cmd
sais sth. like:
try
exec -- $cmd --ui
to force GUI mode.
mapset (correct)?
works:
    while executing
"exec -- $cmd --ui"
    invoked from within
"GRMap::group"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
and set GCPs
manually.
a
regards,
Otto
Hamish
Michael, all,
I have backported the today's changes to gis.m in 6.2-cvs.
Also re-done the CVS snapshot for easy testing:
On Thu, Nov 02, 2006 at 03:40:02PM -0700, Michael Barton wrote:
Otto and Hamish,
Michael
phone: 480-965-6213
fax: 480-965-7671
www: Sign in ・ Cloudflare Access
> Hi,
>> georect.tcl?
>> reason
> while executing
> "exec -- $cmd --ui"
> invoked from within
> "GRMap::group"
> invoked from within
> "uplevel \#0 $cmd"
> invoked from within
> and set GCPs
> is it clearer now?
> regards,
> Otto
>>> works:
>> MIchael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>>>> exec -- $cmd
>>>>> sais sth. like:
>>>> try
>>>> exec -- $cmd --ui
>>>> to force GUI mode.
>>>> mapset (correct)?
>>> works:
>>> while executing
>>> "exec -- $cmd --ui"
>>> invoked from within
>>> "GRMap::group"
>>> invoked from within
>>> "uplevel \#0 $cmd"
>>> invoked from within
>>> and set GCPs
>>> manually.
> a
>>> regards,
>>> Otto
>>>> Hamish
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
for the i.group command in georectify.tcl. It seems to solve the
problem of i.group flashing on and off.
I have just updated to the latest CVS and the georectifier is now
working properly (AFAIU), running i.group from the other side of the
looking glass & all.
great!
copying Markus so that he can backport it to 6.2.1
in 6.2.0 the "2. create a group" button now is a no-op for me (note I'm
currently at 100% cpu + 80% RAM for a modelling task, so race-for-
resource errors might be different). Not a big deal, but we'll have to
answer the question of how to set the group up in another grass session
eventually. If this is the only last-minute 6.2.0 breakage I'll be very
happy.
Otto:
> appears, but I can still go on rectiifying.
> while executing
> "exec -- $cmd --ui"
> invoked from within
> "GRMap::group"
> invoked from within
> "uplevel \#0 $cmd"
> invoked from within
> and set GCPs
No harm in it, AFAIK, just normal termination(?). The "catch" statement
hides this error message. Unfortunately the "catch" was also catching a
genuine error (expecting command line options; thus it needs a --ui GUI
[why is that?]).
From what I've heard here the Tcl return test is bogus so there is no
way to test a good exit from a bad one?
perhaps gis.m could use a global DEBUG 0/1 setting like the start of the
nviz2.2_script has. With it changed to 1 it could disable the catches,
etc. or maybe better it could test on startup if the gisenv DEBUG was >
0 to set a global DEBUG var.
Hamish
On Fri, 3 Nov 2006 20:00:38 +1300
great!
happy.
Otto:
> > while executing
> > "exec -- $cmd --ui"
> > invoked from within
> > "GRMap::group"
> > invoked from within
> > "uplevel \#0 $cmd"
> > invoked from within
> > and set GCPs
[why is that?]).
ok, thanks a lot for your help and fixes. I tested the current cvs version Grass
6.3 head and the georectifier is working very well now - great!!
thanks a lot
Otto
Hamish
