Hello,
I've been working with gvSIG's georeferencing module lately, and I have to say that it rocks ! It allows you to see where you put your GCP's not only on the image to reference, but also on your base map and you can zoom into the points and move them around as needed in both maps. This allows for very precise georeferencing. You can also place and resize your image as you want in the same canvas as the reference map. Etc...
It would be great to have something like this in GRASS if it is in any way feasible. So, maybe an inspiration for someone who has the time and feels inspired. Or for next years Google Summer of Code ?
Moritz
On 23/05/08 15:47, Markus Neteler wrote:
Hi Moritz,
could you post some (links to) screenshots?
http://geog-pc40.ulb.ac.be/grass/misc/georef_gvSIG.pdf
This is an extract of the gvSIG user manual with the chapter on the georeferencer. It contains screenshots + explanations.
Moritz
On Fri, May 23, 2008 at 2:06 PM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
Hello,
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
Moritz:
chapter on the
[sorry about the linewraps, broken yahoo webapp..]
see also i.vpoints for neat features like click-a-point on source and target left/right panel images, and test reverse-projection of vector layers from target location over source image.
I would be nice to have the "auto" and "3d" i.points updated+moved from grass5 incoming / contrib code into grass6 addons, or at least well summarized for grass5 on a wiki page or so. the idea is to have a full plate of good ideas with demonstration code available while building the new wxGUI georeferencing app, thus a stronger roadmap of where we want it to go and what features to include.
Hamish
Hamish,
which code do you mean? We have there grassaddons/imagery/i.points.auto.
The draft imagery roadmap is (see TODO file in main - should go into the Wiki):
TODO Image libraries:
A)
- lib/imagery/: standard lib, in use (i.* except for i.points3, i.rectify3)
- imagery/i.ortho.photo/libes/: standard lib, in use
(i.ortho.photo, photo.*)
B)
- lib/image3/: never finished improvement which integrated the
standard lib and
the ortho lib. Seems to provide also ortho rectification for
satellite data (i.points3, i.rectify3)
TODO Image modules:
- merge of i.points, i.vpoints, i.points3
- merge of i.rectify and i.rectify3
- addition of new resampling algorithms such as bilinear, cubic convolution
(take from r.proj?)
- add other warping methods (maybe thin splines from GDAL?)
- implement/finish linewise ortho-rectification of satellite data
- Add support for > 8bit colors (only 0-255 supported currently)
Markus:
oh, right. it's already on the table.
A)
B)
integrated the standard lib and
ortho rectification for satellite data (i.points3, i.rectify3)
TODO Image modules:
(take from r.proj?)
GDAL?)
satellite data
my main point was to raise the awareness that we have all this neat rectification code sitting in the corners which can be drawn upon when it comes to improving the new wxGUI tool. The more we can learn from gvSIG, QGIS, gdal_translate+gdalwarp, and old i.*points*, i.ortho.photo ideas+code while still in the design phase, the better the end result will be. Even if we don't implement it all at once.
meta,
Hamish
