[GRASS-dev] Georeferencing
I have been trying to upload and georectify a rasta (*.PNG) file. I create a simple xy location and in that location, upload the rasta using ‘r.in.gdal ‘; but later on when I begin to process the data, get the message:
“(Sat May 11 10:42:35 2013)
r.colors map=NP_source@PERMANENT color=grey
ERROR: Raster map NP_source@PERMANENT not found
(Sat May 11 10:42:35 2013) Command finished (0 sec)”
This problem seems to prevent the process moving to the two-screen georectifying stage. Any suggestions/recommendations?
Colin.
I suspect the input raster file is imported as three rasters (one for each RGB band). After r.in.gdal, check if there are some rasters in the mapset (e.g. NP_source.red, NP_source.green, NP_source.blue) and then combine them using r.composite.
Allar
On 11/05/2013 11:14, Dr Colin Hindmarch wrote:
I have been trying to upload and georectify a rasta (*.PNG) file. I create a simple xy location and in that location, upload the rasta using 'r.in.gdal '; but later on when I begin to process the data, get the message:
    "(Sat May 11 10:42:35 2013)
    ERROR: Raster map <NP_source@PERMANENT> not found
    (Sat May 11 10:42:35 2013) Command finished (0 sec)"
Colin.
grass-dev mailing list
grass-dev@lists.osgeo.org
