[GRASS-dev] [geos-devel] GEOS 3.8.0 Beta 1
FYI
---------- Forwarded message ---------
Date: Sun, Sep 29, 2019 at 7:01 PM
Subject: [geos-devel] GEOS 3.8.0 Beta 1
To: GEOS Development List <geos-devel@lists.osgeo.org>
Hi all GEOS people,
The 3.8 release is coming soon, and in support of that we would like
your help testing out the final project. You’ll find that there are
lots of performance improvements, we hope, and improved reliability in
common operations.
http://download.osgeo.org/geos/geos-3.8.0beta1.tar.bz2
Please report any issues you find in building or running tests on the
GEOS ticket tracker https://trac.osgeo.org/geos/ or to this list.
- New things:
  - CAPI: GEOSBuildArea (#952, Even Rouault)
  - CAPI: GEOSMakeValid (#952, Even Rouault)
  - CAPI: GEOSPolygonize_valid (#727, Dan Baston)
  - CAPI: GEOSCoverageUnion (Dan Baston)
  - CAPI: GEOSCoordSeq_setXY, GEOSCoordSeq_setXYZ,
          GEOSCoordSeq_getXY, GEOSCoordSeq_getXYZ (Dan Baston)
  - CAPI: GEOSMinimumBoundingCircle (#735)
  - CAPI: GEOSGeom_createPointFromXY (Dan Baston)
- Improvements:
  - Improve overall performance by reducing of heap allocations (Dan Baston)
  - Improve performance and robustness of GEOSPointOnSurface (Martin Davis)
  - Improve performance of GEOSPolygonize for cases with many potential
    holes (#748, Dan Baston)
  - Support extended precision calculations (ttmath) and port JTS
    improvements related to extended precision (Paul Ramsey, Mateusz Loskot)
  - Improve performance of GEOSPolygonize for cases with many or complex
    shells (Dan Baston, Martin Davis)
  - Improve performance of Delaunay triangulations / Voronoi Diagrams
    (Dan Baston)
  - Improve performance of prepared geometry operations (Dan Baston)
  - Improve robustness of Delaunay triangulations (Paul Ramsey, Martin Davis)
  - Improve performance of unary union for lines (Dan Baston)
  - Improve general predicate, overlay, and buffer performance (Dan
Baston, Paul Ramsey)
  - Improve cascaded union performance (Paul Ramsey, Martin Davis)
  - Allocate default GeometryFactory singleton on the stack (Sandro Mani)
  - Harmonize XML tests with JTS and harmonize cmake/autoconf
    test running (Paul Ramsey)
  - CMake modernization (Mateusz Loskot, Paul Ramsey, Dan Baston)
  - Return unique_ptr from most methods that produce a new geometry (Dan Baston)
- Changes:
  - Constructive geometry functions in CAPI now preserve SRID
    of input arguments in output (#896)
