[GRASS-dev] get_proj() python function
Hi all, today I needed a python function for g.proj interface. I
developed it and I think it could integrate in the main core.
In attachment you can find the diff
regards
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
(attachments)
get_proj.diff (1.19 KB)
For parsing, g.proj should be run with -j, e.g.:
def get_proj():
    return grass.parse_command("g.proj", flags='j')
The main reason why this hasn't been added to the library is that it's
barely worth the effort compared to including the code directly in the
script.
For a library function, one minor improvement would be to strip the
leading '+' from the key names, i.e.:
def get_proj():
    kv = grass.parse_command("g.proj", flags='j')
    return dict((k[1:], v) for k, v in kv.iteritems())
2011/6/5 Glynn Clements <glynn@gclements.plus.com>:
You are right but with -p the output contain more values like datum
and units... for this I used -p flag
ciao
Luca
www.lucadelu.org
There are some differences, though:
Gauss-Boaga Fuso 1 example:
GRASS 6.4.2svn (patGB1):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
datum : rome40
datumparams: towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
proj : tmerc
ellps : international
a : 6378388.0000000000
es : 0.0067226700
f : 297.0000000000
lat_0 : 0.0000000000
lon_0 : 9.0
k_0 : 0.9996000000
x_0 : 1500000.0000000000
-PROJ_UNITS------------------------------------------------
unit : Meter
units : Meters
meters : 1
GRASS 6.4.2svn (patGB1):~ > g.proj -j
+proj=tmerc
+lat_0=0.0000000000
+lon_0=9.0
+k_0=0.9996000000
+x_0=1500000.0000000000
+a=6378388
+rf=297
+no_defs
+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
+to_meter=1
The question is if the -p output is "over"described or not.
2011/6/7 Markus Neteler <neteler@osgeo.org>:
not sure, if not, we could add `-g` flag to print proj/units info in
shell script style...
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
2011/6/7 Martin Landa <landa.martin@gmail.com>:
+1 for `-g` flag
Martin
Luca
www.lucadelu.org
2011/6/7 Luca Delucchi <lucadeluge@gmail.com>:
+1 for `-g` flag
done in r46850
Martin
