[GRASS-dev] getting from DBF to SQLite
I have some vector files with attribute tables in DBF format. I would like to copy them and move their tables into SQLite. How is the easiest way to do that.
I thought I could just set db.connect to sqlite and copy the vectors, but that doesn’t seem to work.
Michael
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Corporation for Atmospheric Research
303-497-2889 (voice)
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
2012/3/26 Michael Barton <Michael.Barton@asu.edu>:
that doesn't seem to work.
in which sense it doesn't work?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Thanks Martin,
Here is what happens. Perhaps this does not work in GRASS 6.4.3? I just noticed that the sqlite selection in the GUI for db.connect does not do anything.
GRASS 6.4.3svn (Spain_utm_ed50z30):~ > db.connect driver=sqlite
GRASS 6.4.3svn (Spain_utm_ed50z30):~ > g.copy vect=alcala_subsect@Alcala_vectors,alcala_subsect_sqlite
Copy vector <alcala_subsect@Alcala_vectors> to current mapset as
<alcala_subsect_sqlite>
DBMI-SQLite driver error:
Unable to open database: unable to open database file
WARNING: Unable to open database
         </Users/Shared/grassdata/Spain_utm_ed50z30/SAA2012/dbf/> by driver
         <sqlite>
no database is open
WARNING: Unable to copy table <alcala_subsect_sqlite>
WARNING: Cannot copy <alcala_subsect@Alcala_vectors> to current mapset as
Michael
Martin
Martin Landa <landa.martin gmail.com> * Studijní program Geodézie a kartografie – GeoWikiCZ
_____________________
C. Michael Barton
you need to define also database (file). Typically
`$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db`
Martin
I thought I did that, but will try again with your line copied exactly. Thanks
Michael
Martin
C. Michael Barton
This worked. I must have specified it incorrectly the first time.
Thanks
Martin
C. Michael Barton
