[GRASS-dev] GIF -> PNG
would it be possible to use PNG for logo in HTML manual pages
instead of GIF? That only means to convert the logo
and modify Html.make.
Qt is not compiled with GIF support by default because of
patent problems.
Thanks
Radim
On Fri, Sep 22, 2006 at 02:25:42PM +0200, Radim Blazek wrote:
Many more files were affected, but done.
patent problems.
AFAIK the patent is expired. Anyway, PNG is fine
and now used.
> patent problems.
and now used.
For the record, TclTk doesn't like PNG. e.g. the NVIZ help browser won't
load PNG help graphics in the nviz man pages. I consider the fix for
this to be dropping that help browser altogether & in general dropping
tcltk...
Hamish
Hamish wrote on 09/27/2006 12:36 PM:
patent problems.
and now used.
Cool :frowning:
We should change the NVIZ help browser to the standard HTML browser. The
limited
tcltk based browser isn't that fancy at all.
yes. The code could be taken from
gis.m -> Help -> GRASS help.
It also needs to be updated in the startup GUI.
& in general dropping tcltk...
This will take some more time.
Cool :frowning:
limited tcltk based browser isn't that fancy at all.
Done (startup GUI) & done (nviz). Also for 6.2-release branch.
Any other places?
Please test...
> > won't load PNG help graphics in the nviz man pages.
> Cool :frowning:
> The limited tcltk based browser isn't that fancy at all.
Any other places?
$ grep -rI help.tcl * | grep -v locale/po | cut -f1 -d: | uniq
No, only those two used it.
If we remove GRASS's visualization/nviz/html/help.tcl web browser,
that's 120k less source to distribute!
Please test...
with this set in ~/.grass.bashrc:
  export GRASS_HTML_BROWSER=dillo
it works fine from NVIZ, but the startup GUI defaults to using klunky
old mozilla as .grass.bashrc hasn't been sourced yet(?). Also is there
any way to get rid of or minimize the residual xterm window?
Hamish
> > Cool :frowning:
> Any other places?
please go ahead :slight_smile:
> Please test...
I observed the same problem but have no idea.
You can always set it in your normal ~/.bash_profile etc.
Also is there
Yes; just don't use an xterm, i.e. change:
  exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e $env(GRASS_HTML_BROWSER) \
  file://$env(GISBASE)/docs/html/helptext.html >@stdout 2>@stderr &;
to:
  exec -- $env(GRASS_HTML_BROWSER) \
I don't see why an xterm should be necessary. If you want to use
lynx/links, you can set GRASS_HTML_BROWSER to a script which starts
lynx/links in an xterm, e.g.:
  #!/bin/sh
  exec xterm -e lynx "$@"
> Also is there
to:
thanks, fixed (also 6.2).
> klunky old mozilla as .grass.bashrc hasn't been sourced yet(?).
well yes, but that's sloppy. my thought was: should ~/.grass.[*]rc be
processed earlier, perhaps even in bin.i686-pc-linux-gnu/grass63 ?
Hamish
processed earlier,
~/.grass.*rc are sourced into the interactive session shell. If your
$SHELL is e.g. csh, you probably aren't going to have a
~/.grass.bashrc, and you aren't going to be able to source a
~/.grass.cshrc into a bash script such as Init.sh.
Even if your $SHELL is bash, ~/.grass.bashrc may contain commands
which don't make sense outside of an interactive shell.
There wouldn't be any point. The grass63 script sets $GISBASE then
runs Init.sh; anything useful that could be done in grass63 can be
done equally well in Init.sh.
