[GRASS-dev] gis.m: cannot get profile from profile tool
Micheal,
I think I found it: It seems that the tcltk profiling tool does not work in a latlong projections.
I just reprojected the map into a projected location and now it works !
So, if this is confirmed, we will either have to add a warning or find a way to use latlong projections.
Moritz
Michael Barton wrote:
Try this update to profile.tcl. Just drop it into $GISBASE/etc/gm
I found a way to set the max and min elevation according to the region
displayed. This makes more sense. Maybe it will fix your problem too.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
From: Moritz Lennert <mlennert@club.worldonline.be>
Date: Thu, 27 Jul 2006 08:33:11 +0200
To: Michael Barton <michael.barton@asu.edu>
Cc: Grass Developers List <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] gis.m: cannot get profile from profile tool
Hi Moritz,
Did you select a raster to profile?
Yes, as you can see in the screenshot, it says in the bottom left:
"Profile for srtm_be".
Third button from the left on the
profiler toolbar.
Rather like d.profile, the profiler differentiates between
a map you use as a background to the profiling line (what is shown in the
map display) and the map that you actually use to compute profile values.
I understand that, but I still don't get a profile. Actually, I
sometimes do not even get the straight blue line you see in the
screenshot (http://moritz.homelinux.org/grass/gism_profile.png), just an
empty graph.
The min and max of the heights on the y axis seem correct, though.
Moritz
# profile.tcl - Dialog to create profile of raster surface for GRASS GIS Manager
# May 2006 Michael Barton, Arizona State University
# COPYRIGHT: (C) 1999 - 2006 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
namespace eval GmProfile {
  variable pcan
  variable status ""
    variable pmap ""
    variable pmainframe
  variable transect ""
  variable tottransect ""
  variable pcoords ""
  variable pcoordslist ""
  variable profilelist ""
  variable x
  variable y
  variable first 1
    variable firsteast 0.0
    variable firstnorth 0.0
    variable east1 0.0
    variable north1 0.0
    variable east2 0.0
    variable north2 0.0
  variable tlength 0.0
  variable tottlength 0.0
    variable linex1 0.0
    variable liney1 0.0
    variable linex2 0.0
    variable liney2 0.0
    variable array psegment len #
    variable elevrange 0.0
    variable elevmax 0.0
    variable elevmin 0.0
    variable elev 0.0
# select raster map to profile
# select base raster map from list and put name in layer tree node
proc GmProfile::select_rast { } {
  variable pmap
  variable status
  variable elevrange
  variable elevmax
  variable elevmin
        set m [GSelect cell]
    if { $m != "" } { set pmap $m
        #calculate elevation range so all profiles with same window geometry with have
    # same scale. Scale depends on region.
             set input [exec r.describe -rdq map=$pmap]
  regexp -nocase {^([0-9]+) thru ([0-9]+)} $input trash elevmin elevmax
  set elevrange [expr $elevmax - $elevmin]
  # put map name in status bar
    set GmProfile::status [G_msg "Profile for $pmap"]
# create canvas for displaying profile
proc GmProfile::create { mapcan } {
  global gmpath
  global iconpath
    global env
    global bgcolor
  variable pmap
  variable pcan
  if { [winfo exists .profile] } {return}
  set ptitle "Profile Window"
  toplevel .profile
    wm title .profile [G_msg $ptitle]
    wm withdraw .profile
    #wm overrideredirect $txt 1
  # create canvas for profile
  set profilemf [MainFrame .profile.mf \
    -textvariable GmProfile::status]
  set profile_frame [$profilemf getframe]
  set pcan [canvas $profile_frame.can -bg white\
    -borderwidth 0 -closeenough 1.0 \
        -relief ridge -selectbackground #c4c4c4 \
        -width 600 -height 200 ]
         # setting geometry
    place $pcan \
        -in $profile_frame -x 0 -y 0 -anchor nw \
        -bordermode ignore
  # profile control buttons
  set pcan_tb [$profilemf addtoolbar]
  set pcanbb [ButtonBox $pcan_tb.bb -orient horizontal]
  $pcanbb add -image [image create photo -file "$iconpath/gui-profiledefine.gif"] \
    -command "GmProfile::profilebind $mapcan" \
        -highlightthickness 0 -takefocus 0 -relief link -borderwidth 1 \
        -highlightbackground $bgcolor -activebackground $bgcolor\
        -helptext [G_msg "Draw profile transect in map display"] -highlightbackground $bgcolor
  $pcanbb add -image [image create photo -file "$iconpath/gui-profiledraw.gif"] \
    -command "GmProfile::pdraw" \
        -helptext [G_msg "Draw profile"] -highlightbackground $bgcolor
  $pcanbb add -image [image create photo -file "$iconpath/element-cell.gif"] \
    -command "GmProfile::select_rast" \
        -helptext [G_msg "Select raster map to profile"] -highlightbackground $bgcolor
  $pcanbb add -image [image create photo -file "$iconpath/gui-erase.gif"] \
    -command "GmProfile::perase $mapcan" \
        -helptext [G_msg "Clear profile"] -highlightbackground $bgcolor
  $pcanbb add -image [image create photo -file "$iconpath/file-save.gif"] \
    -command "GmProfile::psave" \
        -helptext [G_msg "Save profile to EPS file"] -highlightbackground $bgcolor
            # add a menu button to set preferences?
  pack $profilemf -expand yes -fill both -padx 0 -pady 0
  pack $pcan -fill both -expand yes
  pack $pcanbb -side left -anchor w
    $profilemf showstatusbar status pack $profilemf -fill both -expand yes
  BWidget::place .profile 0 0 at 500 100
    wm deiconify .profile
      # bindings for closing profile window
  bind .profile <Destroy> "GmProfile::cleanup %W $mapcan"
# save profile to eps file
proc GmProfile::psave { } {
  variable pcan
  global env
  set types {
    {{EPS} {.eps}}
  if { [info exists HOME] } {
    set dir $env(HOME)
    set path [tk_getSaveFile -filetypes $types -initialdir $dir \
      -defaultextension ".eps"]
  } else {
    set path [tk_getSaveFile -filetypes $types -defaultextension ".eps"]
  $pcan postscript -file "$path"
  return
# procedures for marking profile location
# bindings for drawing profile transect
proc GmProfile::profilebind { mapcan } {
  variable measurement_annotation_handle
  variable tlength variable tottlength
    variable linex1 variable liney1
    variable linex2
    variable liney2
    variable first
    global mon
  global GmProfile::msg
  # Make the output for the measurement
  set measurement_annotation_handle [monitor_annotation_start $mon "Measurement" {}]
      if {[info exists linex1]} {unset linex1}
  if {[info exists liney1]} {unset liney1}
  if {[info exists linex2]} {unset linex2}
  if {[info exists liney2]} {unset liney2}
  bind $mapcan <1> "GmProfile::marktransect $mapcan %x %y"
  bind $mapcan <B1-Motion> "GmProfile::drawtransect $mapcan %x %y"
  bind $mapcan <ButtonRelease-1> "GmProfile::getcoords $mapcan"
    set GmProfile::msg "Draw profile transect with mouse"
  MapCanvas::setcursor $mon "pencil"
  set tlength 0
  set tottlength 0
# start profile transect
proc GmProfile::marktransect {mapcan x y} {
  variable transect
    variable linex2
    variable liney2
    variable first
    variable firsteast
    variable firstnorth
    variable pcoords
        #start line
    if { ![info exists linex1] } {
      set linex1 [$mapcan canvasx $x]
      set liney1 [$mapcan canvasy $y]
  if { $first == 1 } {
    set firsteast [MapCanvas::scrx2mape $linex1]
    set firstnorth [MapCanvas::scry2mapn $liney1]
    set pcoords "$firsteast,$firstnorth"
  set first 0
  #check for click with no drag
    if { ![info exists linex2] } {
    set linex2 $linex1
    if { ![info exists liney2] } {
    set liney2 $liney1
    $mapcan delete transect
# draw profile transect
proc GmProfile::drawtransect { mapcan x y } {
  variable transect
    variable linex2
    variable liney2
    variable pcoords
        set scrxmov $x
  set scrymov $y
  set eastcoord [eval MapCanvas::scrx2mape $x]
  set northcoord [eval MapCanvas::scry2mapn $y]
  set coords "$eastcoord,$northcoord"
  set xc [$mapcan canvasx $x]
  set yc [$mapcan canvasy $y]
  # draw line segment
  if {($linex1 != $xc) && ($liney1 != $yc)} {
    $mapcan addtag transect withtag \
      [$mapcan create line $linex1 $liney1 $xc $yc \
      -fill red -arrow last -width 2]
    set linex2 $xc
    set liney2 $yc
# get coordinates for transect nodes and endpoints
proc GmProfile::getcoords { mapcan } {
  variable transect
    variable linex2
    variable liney2
    variable pcoords
    variable firsteast
    variable east1
    variable north1
    variable east2
    variable north2
    variable pcoords
  # draw cumulative line
  $mapcan addtag tottransect withtag \
    [$mapcan create line $linex1 $liney1 $linex2 $liney2 \
    -fill blue -arrow last -width 2]
  # get line endpoints in map coordinates
  set east1 [MapCanvas::scrx2mape $linex1]
  set north1 [MapCanvas::scry2mapn $liney1]
  set east2 [MapCanvas::scrx2mape $linex2]
  set north2 [MapCanvas::scry2mapn $liney2]
  # coordinates for use in r.profile
  append pcoords "," $east2 "," $north2
  # x distance off each transect segment
  # First convert map coordinates to profile screen coordinates
  # Then add the profile screen coordinates to the profile coordinates list. # Only add east1 and north1 the first time; # continue to add east2 and north2 until ready to draw profile
  # calculate line segment length and total length
  set tlength [expr {sqrt(pow(($east1 - $east2), 2) + pow(($north1 - $north2), 2))}]
  set tottlength [expr {$tottlength + $tlength}]
  lappend pcoordslist $tottlength
  monitor_annotate $measurement_annotation_handle " --segment length\t= $tlength\n"
  monitor_annotate $measurement_annotation_handle "cumulative length\t= $tottlength\n"
  set linex1 $linex2
  set liney1 $liney2
# draw profile
proc GmProfile::pdraw {} {
  variable pcan
  variable pmap
  variable tottlength
  variable elevrange
  variable elevmax
  variable elevmin
    variable firsteast
    variable firstnorth
    variable east1
    variable north1
    variable east2
    variable north2
    variable pcoords
  $pcan delete all
  set profilelist ""
  # calculate screen length and width
  set w [winfo width $pcan]
  set h [winfo height $pcan]
  #calculate graph box and scale extents
  set top [expr 0.10 * $h]
  set bottom [expr 0.80 * $h]
  set height [expr $bottom - $top]
  set left [expr 0.2 * $w]
  set right [expr 0.9 * $w]
  set width [expr $right - $left]
  set yscaleright [expr $left - 10]
  set xscaletop [expr $bottom + 10]
  # create y axis (from 20%x10% to 20%x80% - top to bottom)
  $pcan create line $left $top $left [expr $bottom + 5]
  # add scale to y axis
  $pcan create text $yscaleright $top \
    -text $elevmax \
    -anchor e \
    -justify right
  $pcan create text $yscaleright $bottom \
    -text $elevmin \
    -anchor e \
    -justify right
  # create x axis (from 20%x80% to 90%x80% - left to right)
  $pcan create line [expr $left - 5] $bottom $right $bottom
  # add scale to x axis
  $pcan create text $left $xscaletop \
    -text "0" \
    -anchor n \
    -justify center
  $pcan create text $right $xscaletop \
    -text "$tottlength" \
    -anchor n \
    -justify center
  # add tick marks
  $pcan create line $right $bottom $right [expr $bottom + 5]
  $pcan create line [expr $left - 5] $top $left $top
  # add transect segment markers
  foreach {x} $pcoordslist {
    set segx [expr $left + (($x * $width) / $tottlength)]
    $pcan create line $segx $bottom $segx $top -fill grey
  # run r.profile
  # convert dist elev (stdout) to xy coordinates of profile line
     if {![catch {open "|r.profile input=$pmap profile=$pcoords" r} input]} {
    while {[gets $input line] >= 0} {
      if { [regexp -nocase {^([0-9].*) ([0-9].*)$} $line trash dist elev] } {
        set pelev [expr $bottom - ($height * ($elev - $elevmin) / $elevrange)] set pdist [expr $left + (($dist * $width) / $tottlength)]
        lappend profilelist $pdist $pelev }
    catch close $input
  # draw profile line
  if { [llength $profilelist] > 3 } {
    $pcan create line $profilelist -fill blue
# erase profile and clear transects
proc GmProfile::perase { mapcan } {
  variable pcan
  variable pmap
  variable transect
  variable tlength
  variable tottlength
  variable pcoords
  variable first
  variable linex1
  variable liney1
  variable elevrange
  variable elevmax
  variable elevmin
  $pcan delete all
  $mapcan delete tottransect
  set tlength 0.0
  set tottlength 0.0
  set pcoords ""
  set pcoordslist ""
  set profilelist ""
  set first 1
  if { [info exists linex1] } {
    unset linex1
  if { [info exists liney1] } {
    unset liney1
    #recalculate elevation range in case region has changed
proc GmProfile::cleanup { destroywin mapcan } {
  # cleanup procedures on closing profile window
  variable pcan
  variable transect
  variable tlength
  variable tottlength
  variable pcoords
  variable first
  variable linex1
  variable liney1
  global mon
  set tlength 0.0
  set tottlength 0.0
  set pcoords ""
  set pcoordslist ""
  set profilelist ""
  set first 1
    unset linex1
    unset liney1
  MapCanvas::restorecursor $mon
Moritz,
I found the problem and fixed the profiler so that it works in latlon
regions now. I just committed it to the cvs.
I'd like to improve it a bit so that it scales the vertical axis according
to height values visible in the display rather than according to the entire
map. r.describe seemed like just the module to do this, but I found that its
output format varies according to whether 1) the map is a latlon or
non-latlon region, 2) if all the values are positive or negative, or 3) some
of the raster values are negative and some are positive. This makes it
impossible to parse easily and use in a GUI script like profile.tcl
IMHO, it should output its results in the same format regardless of the map
characteristics.
Here is what it does:
1) r.describe format for latlon
r.describe map=srtm -1rqd
387.000000-831.000000
r.describe map=srtm rqd
2) r.describe format for non latlon with all positive or all negative values
r.describe -1rqd map=elevation_dem
1066
1840
r.describe -rqd map=elevation_dem
1066 thru 1840
r.describe -1rqd map=elevation_neg
-1840
-1066
-1840 thru -1066
3) r.describe format for non latlon with some positive and some negative
values
r.describe -rqd map=elevation_neg2
-640 thru -1
0
1 thru 134
r.describe -1rqd map=elevation_neg2
-640
-1
0
1
134
Michael
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 27 Jul 2006 14:40:41 +0200
Micheal,
Moritz
Michael
phone: 480-965-6213
fax: 480-965-7671
Hi Moritz,
profiler toolbar.
empty graph.
Moritz
Manager
# for details.
variable pcan
variable status ""
    variable pmap ""
    variable pmainframe
variable pcoords ""
variable x
variable y
variable first 1
    variable east1 0.0
    variable north1 0.0
    variable east2 0.0
    variable north2 0.0
    variable linex1 0.0
    variable liney1 0.0
    variable linex2 0.0
    variable liney2 0.0
    variable elev 0.0
variable pmap
variable status
variable elevrange
variable elevmax
variable elevmin
    if { $m != "" } {
        set pmap $m
have
global gmpath
global iconpath
    global env
    global bgcolor
variable pmap
variable pcan
toplevel .profile
    # setting geometry
    place $pcan \
        -bordermode ignore
$bgcolor
$bgcolor
variable pcan
global env
set types {
    {{EPS} {.eps}}
set dir $env(HOME)
} else {
return
variable tlength
variable tottlength
    variable linex1
    variable liney1
    variable linex2
    variable liney2
    variable first
    global mon
"Measurement" {}]
set tlength 0
set tottlength 0
variable transect
variable tlength
variable tottlength
    variable linex1
    variable liney1
    variable linex2
    variable liney2
    variable first
    variable firsteast
    variable firstnorth
    variable pcoords
    #start line
set first 0
set linex2 $linex1
set liney2 $liney1
variable transect
variable tlength
variable tottlength
    variable linex1
    variable liney1
    variable linex2
    variable liney2
    variable pcoords
set scrxmov $x
set scrymov $y
# draw line segment
set linex2 $xc
set liney2 $yc
variable transect
variable tlength
variable tottlength
    variable linex1
    variable liney1
    variable linex2
    variable liney2
    variable pcoords
    variable firsteast
    variable east1
    variable north1
    variable east2
    variable north2
    variable pcoords
2))}]
$tlength\n"
$tottlength\n"
set linex1 $linex2
set liney1 $liney2
# draw profile
variable pcan
variable pmap
variable tottlength
variable elevrange
variable elevmax
variable elevmin
    variable firsteast
    variable firstnorth
    variable east1
    variable north1
    variable east2
    variable north2
    variable pcoords
$pcan delete all
set profilelist ""
-text $elevmax \
-anchor e \
-justify right
-text $elevmin \
-anchor e \
-justify right
-text "0" \
-anchor n \
-justify center
-anchor n \
-justify center
# add tick marks
# run r.profile
catch close $input
# draw profile line
variable pcan
variable pmap
variable transect
variable tlength
variable tottlength
variable pcoords
variable first
variable linex1
variable liney1
variable elevrange
variable elevmax
variable elevmin
$pcan delete all
set tlength 0.0
set tottlength 0.0
set pcoords ""
set pcoordslist ""
set profilelist ""
set first 1
unset linex1
unset liney1
variable pcan
variable transect
variable tlength
variable tottlength
variable pcoords
variable first
variable linex1
variable liney1
global mon
set tlength 0.0
set tottlength 0.0
set pcoords ""
set pcoordslist ""
set profilelist ""
set first 1
unset linex1
unset liney1
Moritz,
Thanks, now it works great !
Moritz
