On Sep 23, 2007, at 7:40 PM, Michael Barton wrote:
(and could change if we decide
on a GRASS_XTN_PATH base path instead of multiple GRASS_ADDON_* vars)
I'd recommend keeping the xtnmenu.dat file in GRASS_ADDON_ETC because that
is already an existing GRASS environmental variable.
I'd also recommend using GRASS_ADDON_PATH for the same reason. Anything
listed in GRASS_ADDON_PATH will automatically run from the command line and
from in scripts (like the GUI) without an explicit path specification.
I don't mean the actual location of xtnmenu.dat would change, just the env variable used to locate it. Currently we have:
GRASS_ADDON_PATH - been around a while, should be left as is
GRASS_ADDON_ETC - fairly new addition
but will probably need soon:
GRASS_ADDON_HELP
And with the possibility of use the makefile fragments for building and installing extensions (I'm close), we will need to know where scripts/ and lib/ are.
My suggestion is to have one base for all this: GRASS_XTN_PATH (stil multiple paths). Then the various places that need them use subfolders (bin, lib, docs, etc, scripts) from there.
And, for the cases where people do install addons in the GRASS
installation, you might want to check for xtnmenu.dat in GISBASE.
No. This is the idea of a standard--so we don't have to check all the places
that people *might* try to put a menu file. If it is not in the standard
local (which is anywhere, but must be a place specified in GRASS_ADDON_ETC),
then it won't show up in the GUI.
Just a thought.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
