Hi Michael,
I don't know if this is just another manifestation of the changes in g.region, but gis.m crashes when I try to zoom to a map which exists in more than one mapset of the current location.
To reproduce in spearfish, in mapset user1:
1) g.copy rast=bugsites@PERMANENT,bugsites (or any other raster or vector map)
2) display bugsites
3) zoom to selected map
The command used in mapcanvas.tcl is g.region -ugp rast=bugsites. This gives:
GRASS 6.3.cvs (spearfish60):~ > g.region -ugp rast=bugsites
WARNING: 'cell/bugsites' was found in more mapsets (also found in user1).
projection=1
zone=13
datum=nad27
ellipsoid=clark66
n=4928000
s=4914000
w=590000
e=609000
nsres=100
ewres=100
rows=140
cols=190
cells=26600
So I imagine that the WARNING is what causes the problem.
Just as a side note: I have always found it illogical that when I work with the map in mapset user1 (or at least I think I do), the warning tells me that the map _also_ exists in user1, as if it was currently working with the one in PERMANENT.
Does this mean, that being in mapset user1, and launching a command on a map that exists both in user1 and in PERMANENT makes the command work with the version in PERMANENT, or is it just a confusing formulation ?
I have always worked with the idea that it is the second. Any reason for this formulation or could we change this to "map also exists in PERMANENT (or whatever _other_ mapsets than the one you are currently in)" ?
Moritz
