[GRASS-dev] gis.m: error message when trying to add layer without open map display
Michael,
Since you have been busy working on error catching in gis.m: I've always found that the error that occurs when you try to add a layer even though there is no open map display quite difficult to understand for newbies:
invalid command name ".mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1"
     while executing
"$tree($mon) selection get"
     (procedure "GmTree::add" line 11)
     invoked from within
"GmTree::add vector"
     ("uplevel" body line 1)
     invoked from within
"uplevel \#0 $cmd"
     (procedure "Button::_release" line 18)
     invoked from within
"Button::_release .mainframe.topf.tb0.bbox2.b0"
     (command bound to event)
Would it be possible to catch this and produce a nicer error message such as: "You need to open a map display first." ?
Moritz
Moritz,
I'll try to see what's going on with this. It probably has to do with the
necessary link between a layer tree and a display. A better error message
would likely be "You need to open a display before adding map layers"
Michael
On 2/8/07 6:11 AM, "Moritz Lennert" <mlennert@club.worldonline.be> wrote:
Michael,
     while executing
     invoked from within
     invoked from within
"uplevel \#0 $cmd"
     invoked from within
Moritz
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Moritz:
> ".mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1" invalid
> while executing
Michael:
the necessary link between a layer tree and a display. A better error
message would likely be "You need to open a display before adding map
layers"
Even better: Don't bother with error messages, do what the user wanted:
open a new display if needed & add the layer.
Hamish
Good idea, but considerably more work to program this.
Michael
On 2/8/07 4:57 PM, "Hamish" <hamish_nospam@yahoo.com> wrote:
Moritz:
     while executing
Michael:
layers"
Hamish
phone: 480-965-6213
fax: 480-965-7671
