[GRASS-dev] gis.m: font selection in module panels
Michael,
Thanks for the font selection in the module panels, but I have the
following problem. I can select the font the first time, but when I try to
open the font dialog a second time in the same panel, I get:
can't read "env(GRASS_FONT)": no such variable
    while executing
"if {[info exists env(GRASS_FONT)] && $env(GRASS_FONT) != ""} {
      set fontindex [lsearch $fontlist $env(GRASS_FONT)]
      if {$fontindex > -1} {
    (procedure "Gm:DefaultFont" line 26)
    invoked from within
"Gm:DefaultFont dbarscale"
    (procedure "GmBarscale::set_font" line 5)
    invoked from within
"GmBarscale::set_font 1"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .mainframe.frame.pw1.f1.frame.sw.sf.frame.fr.color.d"
    (command bound to event)
Moritz
Real weird. See below
On 5/20/07 6:27 AM, "Moritz Lennert" <mlennert@club.worldonline.be> wrote:
Michael,
OK. GRASS_FONT is not set.
    while executing
This is checking to see if GRASS_FONT is set or not. If not set, the clause
if false and it should move to the else clause. It should not be raising an
error.
Try taking out the 2nd part of this clause && $env(GRASS_FONT) != "" and see
what happens. The 2nd part is sort of redundant anyway.
Michael
    invoked from within
    invoked from within
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
Moritz
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Michael,
to
    while executing
clause
an
error.
see
Doesn't help.
But here is some more info:
1) This is under Windows (tiny detail I forgot to mention before :wink:
2) This does not happen if I start by setting a default font (Config->Set
default display font)
3) If I don't set a default font, I get the problems in several ways
  a) add text layer ; type some text ; display ; click on font selection
button
  b) add text layer ; type some text ; add second text layer ; type some
text; display
  c) idem for any combination of layers containing fonts (e.g. add one
barscale and one grid)
Hope this helps finding the problem.
Moritz
It seems like the issue is that this method to check to see if a variable
has been set won't work under windows.
if {[info exists VAR]} { do something }
Maybe if I wrap it in a catch statement...? Anyone have a suggestion about
this.
If the diagnosis is correct, it is a fairly major projblem. This same method
of testing if a variable exists is sprinkled throughout the GUI code, so we
need to find an alternative. I don't know what it would be at the moment.
Michael
Michael,
to
    while executing
clause
an
error.
see
Doesn't help.
button
text; display
Moritz
phone: 480-965-6213
fax: 480-965-7671
Yes, it does. See attached screenshot.
Must be something else.
But now I need some sleep :wink:
Moritz
(attachments)
Moritz,
For when you get up tomorrow.
Try this for the entire if clause
    if {![info exists env(GRASS_FONT)]} {
        set fontindex -1
    } elseif {$env(GRASS_FONT) != ""} {
            $fontlb selection set $fontindex
            $fontlb see $fontindex
I'm kind of waving a dead chicken, but maybe this syntax will work.
Michael
Michael,
    while executing
    invoked from within
    invoked from within
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
Moritz
phone: 480-965-6213
fax: 480-965-7671
> try to open the font dialog a second time in the same panel, I get:
> while executing
clause if false and it should move to the else clause. It should not
be raising an error.
is it missing
  global env
Hamish
It is in the procedure. Perhaps need to express it as
    global env
    global iconpath
instead of ...
    global env iconpath
Michael
    while executing
is it missing
  global env
Hamish
phone: 480-965-6213
fax: 480-965-7671
this.
In general, it's safer to just try something and catch any errors
which occur than to attempt to predict errors.
FWIW, I would change:
to:
  catch {
BTW, I did find this (dtext.tcl:338):
  if {$currfont == "" && [info exists env(GRASS_FONT]} {
Note the missing closing parenthesis.
Also, it looks as if someone has been editing the code with 4-column
tab stops, so the formatting is screwed up. Again: if you want to use
4-column tabs in your own code, fine, but don't do it in GRASS.
Normally, either GRASS_FONT has been set or it hasn't. It probably won't be
set to "". How is the best way to determine if it has been set or not?
Michael
to:
catch {
phone: 480-965-6213
fax: 480-965-7671
Try to use it and catch any errors.
If the following fails:
then omitting the second half and using just:
  if {[info exists env(GRASS_FONT)]} {
will presumably fail at the point that $env(GRASS_FONT) is used, for
the same reasons.
Thanks.
Michael
the same reasons.
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
On Mon, May 21, 2007 04:46, Michael Barton wrote:
Moritz,
        set fontindex -1
Doesn't work, but I'm getting closer to identifying the problem:
Going back to the original version and just erasing the second part of the
if clause, I now notice (a bit more awake than yesterday) that I still get
an error message, but not the same:
    while executing
"lsearch $fontlist $env(GRASS_FONT)"
    (procedure "Gm:DefaultFont" line 27)
    invoked from within
    (procedure "GmDtext::set_font" line 5)
    invoked from within
"GmDtext::set_font 1"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
"Button::_release .mainframe.frame.pw1.f1.frame.sw.sf.frame.fr.fontopt1.b"
So actually the problem is not the 'if exists' clause, but it's
'$env(GRASS_FONT)'. For some reason, it seems like it does not recognize
env() as the function it is, but rather it tries to get the content of a
variable name 'env(GRASS_FONT)'. GRASS_FONT is recognized as existing,
since it passes the test 'if {[info exists env(GRASS_FONT)]}'.
I cannot reproduce this directly in tclsh, though, so I am a bit lost.
Changing the way env is declared as global at the beginning of the
function does not help either.
Chicken still just as dead.
Moritz
Michael
Michael,
to
    while executing
    invoked from within
    invoked from within
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
Moritz
phone: 480-965-6213
fax: 480-965-7671
> set fontindex -1
    while executing
    invoked from within
    invoked from within
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
I can only conclude that "info exists ..." doesn't do what you want
when applied to array elements.
You could try catching the error, and dumping out "env" with
"array get env" to see if that provides any clues.
I'll just have to put a catch around it. But it bothers me not knowing why
this is a problem with Windows TclTk.
Michael
        set fontindex -1
    while executing
    invoked from within
    invoked from within
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
phone: 480-965-6213
fax: 480-965-7671
Hello all
I returned to this problem because I noticed there was still some unpredictable behaviour on Windows and we never really solved it.
Yes indeed. After a bit more web searching I found some discussion of a specific problem with using "info exists" on the env array on Windows. Seemingly related to the fact that Windows handles the unsetting of an environment variable by setting it to an empty string, and the way Tcl maps the env array directly to the environment on the system it is running on gets confused by this.
this.
Yes, exactly! That was the workaround that was suggested in the discussion thread I found:
Change
to
![catch {set env(GRASS_FONT)}]
This works because set env(GRASS_FONT) tries to read the variable - if it doesn't exist, throws an exception, which is caught by the catch command. And if there is no catch (! negation operator used), then it means the variable does actually exist.
It seems the problem is specifically related to using info exists on the env array on Windows. So not too widespread. I have changed all the occurences in gis.m to the workaround and committed it to CVS.
I also changed the text of the font selection box from "Select default font for GRASS displays" to "Select GRASS display font", as the former text was quite confusing seeing as the font select box is also used in the widgets for d.text, d.histogram etc. to select a temporary fault to override the default. I also found a related bug there, which I now know how it's caused but don't know enough Tcl/Tk to fix it:
When clicking the font button in d.histogram for example, it will default to having the default font (loaded from the GRASS_FONT environment variable) selected, not the last font that was selected for d.histogram - a little confusing there, but not a big deal. However the main problem is that if you just click OK here, you would expect the font that was displayed as selected in the select box to be set as the font for d.histogram to use. But it is not, unless you first go and click on it (and nothing *appears* to change, because it was already selected). Very confusing. The reason seems to be that the command that sets the font to the one selected is bound to the <<ListboxSelect>> event, which is only triggered when the font selection is *changed*. Clicking on it again triggers this event, but it's not reasonable to expect users to do that when it already is selected. I think it would be more logical (and solve this problem) if the command that sets the font from the select box was instead bound to the OK button, but I don't know enough to see how to change this...
Paul
Thanks for this really insightful diagnosis of a difficult problem. I'm just
returned and am going to be delving back into the TclTk GUI for a few more
fixes soon. I'll try to see what can be done about the font selection
bindings.
Michael
On 7/27/07 7:31 AM, "Paul Kelly" <paul-grass@stjohnspoint.co.uk> wrote:
Hello all
this.
Change
to
change this...
Paul
Director of Graduate Studies
phone: 480-965-6213
fax: 480-965-7671
