[GRASS-dev] gis.m: last line duplicated in the Output panel
When running "any" commands from gis.m, I get duplicated last lines in
the Output window. In lib/gtcltk/gronsole.tcl,
proc Gronsole::readout {path ci mark fh} {
        set lines {}
        while {[gets $fh line] >= 0} {
                lappend lines $line
        if {[llength $lines] != 0} {
                Gronsole::add_data_tag $path $ci out
        foreach line $lines {
                Gronsole::output_to_gronsole $path $mark $ci [list cmd$ci cmd$ci-out] "$line\n"
        set last [lindex $lines end]
        if {$last != {}} {
                Gronsole::output_to_gronsole $path $mark $ci [list cmd$ci cmd$ci-out] $last
The above if clause unnecessarily outputs the last line *again* after all the
output is sent to gronsole. Do we need to omit the newline from the last line?
Huidae Cho
Will it work if you just take out the last line display clause? (beginning
with set last [lindex...).
Michael
        set lines {}
                lappend lines $line
        if {$last != {}} {
cmd$ci-out] $last
line?
Huidae Cho
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Yes, that will work for me.
Huidae Cho
Michael
> set lines {}
> lappend lines $line
> if {$last != {}} {
> cmd$ci-out] $last
> line?
> Huidae Cho
phone: 480-965-6213
fax: 480-965-7671
