[GRASS-dev] git merge mess on master
Hi devs,
ok, I made a mess on master:
https://github.com/OSGeo/grass/commit/2604e476c54d78dc271ba189877d4d592da4e32a
How to revert that? Of course someone had to run into this at some
point, so seems I "volunteered" to be the first :((
sorry and help welcome,
rebase and force push.
Kind Regards,
Bas
Thanks - we investigated further with two local git gurus, it seems
that nothing happened and things are indeed ok.
Best
point, so seems I “volunteered” to be the first :((
Well, there is “Merge branch ‘master’ of github.com:OSGeo/grass” commit which happens when your local repo was not up to date, you did a commit, and you did git pull for Git to allow you to do git push.
While commits like “Merge pull request #2 from pmav99/t3844” seems equally messy, they 1) include only the relevant changes and 2) they tell us when the changes were merged into master. “Merge branch ‘master’ of github.com:OSGeo/grass” commit contains all sorts of changes and what it tells us is when you updated your local repository clone which is comparatively less useful information.
Commits like “Merge branch ‘master’ of github.com:OSGeo/grass” are unavoidable with pushing directly to master unless you use rebase when catching up with upstream changes. Unless you are careful and do rebase every time (or set your Git to do that), this will happen every time you are out of sync with upstream changes, so potentially once for every commit. Thus, we should be using forks and PRs (every time) until we decide otherwise.
If something happened or not depends on if we want a commit like “Merge branch ‘master’ of github.com:OSGeo/grass” in the history. In our lab repos, we have plenty of these commits because in most cases we don’t care about clean commit history and often only one person works on the repo content at one time (so no sync is needed). Anyway, this commit does not show in the individual file history or blame on GitHub. I don’t know about git bisect, but since you would operate over whole repository, I assume it would show up which might be quite confusing if it is indeed the case.
Vaclav
https://github.com/OSGeo/grass/commits/master/README.md
https://github.com/OSGeo/grass/blame/master/README.md
The commit “Merge pull request #14 from neteler/master” [1] is from master branch, not from dedicated branch as specified in HowToGit. I don’t know for sure, but I think will get messy now when you will try to make more changes.
  1. There is probably a smart way to resolve it. Something along the lines of what Bas suggested to the situation before but you can also backup diffs for all you changes (if any), delete fork and delete your local clone and start over.
  2. Follow the guidelines (you wrote :slight_smile:
  3. When in doubt, use the trick of Git rookies: Have your work/repo also in a separate directory on the side before executing Git commands (no shame in that).
  4. Note that randomly generated Git man pages are so close to real ones that they actually need to explicitly say that it is not a real documentation [2].
Vaclav
[1] https://github.com/OSGeo/grass/commit/2ff8d1e762d646dd8be82b8da483d12c2a772c26
[2] https://git-man-page-generator.lokaltog.net/
Vaclav
