[GRASS-dev] github / travis sync - push file to grass-gis/homebrew-grass-dev repo when grass-gis is synsed to svn?
Hi
Would it be possible to push a file containing e.g. the time to
grass-gis/homebrew-grass-dev?
The content of the file does not matter, but e.g. the time would be
fine.
I have just created a travis-ci test for the homebrew-grass-dev repo and
if it would be possible to push a file to this repo whenever the github
grass-gis/grass-ci is updated, we would have tests of the Mac build via
homebrew which is separate from the test for Linux.
Rainer
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
fine.
That would be a big workaround IMO. I think using daily cron jobs on travis
is a better option (if it works). I enabled them and now we need to wait to
see if that works (Travis CI has currently large backlog on Mac builds,
https://www.traviscistatus.com/).
Vaclav
