[GRASS-dev] GRASS 6.2.0RC3 released
Dear all,
the hopefully final release candidate GRASS 6.2.0RC3 has
been published. The following fixes have been done:
    * r.le.setup fixes (Glynn, Hamish)
    * default color map range (bug #5212) (Glynn)
    * fix v.digit/toolbox.tcl for tcl8.3 (Hamish)
    * update to EPSG 6.11.1 (Markus)
    * close GRASS after creating new location from file (Markus)
    * Fine tune intro text when launching GRASS in text mode (Paul)
    * gis.m zooming in mapcanvas.tcl (Michael)
    * missing Polish EPSG codes (Frank, Maciej)
    * initial Arabic translation (A. Masoud)
See also:
http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#RC3
Please continue to test, especially gis.m. This release candidate
should be very close (or even almost identical) to the final
release of GRASS 6.2.0.
Thanks to all contributors - coders and testers!
I have build Fedora FC4 RPMs on OSGeo's telascience machine
which are hopefully compliant to other 32bit distros:
http://grass.itc.it/grass62/binary/linux/
For easier installation, I have also put PROJ4, GEOS, GDAL
and GRASS-GDAL-OGR plugin RPMs there.
cheers
On Tue, Oct 24, 2006 at 12:43:01AM +0200, Markus Neteler wrote:
Dear all,
See also:
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hi again,
I have updated the RPMS to the official PROJ4-4.5.0
and also uploaded the SPEC files.
On Wed, Oct 25, 2006 at 12:36:13AM +0200, Markus Neteler wrote:
cheers
On Wed, 2006-10-25 at 00:36 +0200, Markus Neteler wrote:
Thanks!
M
P.S. FC6, aka Zod, was just released yesterday.
Alas, will definitely need to be repackaged for FC6, due to x11
reorganization.
M
> Hi,
reorganization.
We hope for a volunteer... (say, I hoped that it would be within
FC6 - maybe an earlier version is?).
