Hello,
I don't know if this is a problem with just my installation (compiled Debian 6.2.2 package with source code from Debian site) but it seems that that an important bug which (AFAIK) is fixed in 6.3, is still present in 6.2.2:
In spearfish:
1) g.copy vect=fields@PERMANENT,fields
2) Select 'fields' as vector file to display and in Map Display "Zoom to selected map".
=> gis.m crashes and in terminal you see:
WARNING: 'vector/fields' was found in more mapsets (also found in user1).
If another bugfix release of 6.2 is foreseen can this be backported ?
Moritz
Re-launching this question since we will begin GIS classes soon with 6.2.2 and I would like to resolve this before.
Can someone confirm this bug ? If yes, could someone point me to the fix in 6.3, so that I can at least locally backport it to 6.2.2 ?
Moritz
On 12/10/07 19:16, Moritz Lennert wrote:
Hello,
In spearfish:
Moritz
grass-dev mailing list
grass-dev@grass.itc.it
Moritz,
no big deal to make a 6.2.3 release.
I am afraid that you need to use gdb or ddd (see Wiki for instructions)
to debug a bit.
Moritz
> Hello,
> present in 6.2.2:
> In spearfish:
> selected map".
> Moritz
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
On 16/10/07 11:40, Markus Neteler wrote:
Moritz,
to debug a bit.
No this is a tcltk gis.m issue. I think I found it now (at least it seems to work here):
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/gui/tcltk/gis.m/mapcanvas.tcl.diff?r1=1.72&r2=1.73
But maybe Michaal can just confirm, and more generally say which gis.m bugfixes in CVS should go to a 6.2.3 release.
Moritz
On 16/10/07 13:58, Maris Nartiss wrote:
sorry, but You are wrong. There two sides of this problem:
1) lib/gis/find_file.c prints warning but it shouldn't (it also
affects other places - d.m; g.remove et.al.)
Why shouldn't it print a warning ?
We had a discussion concerning this warning on the dev list, but I currently don't have the time to go looking for it.
2) gis.m (and d.m) unproperly handle errors.
My suggestion - first - fix find_file.c after line 58 and only then
look for tcl interface errors.
Well, I think that the tcl-side correction is much less invasive and corrects a real problem with gis.m, i.e. that the whole gui crashes just because it encounters this warning. As we don't know if there might be other such warnings which might cause the same problem, I prefer fixing gis.m, as the discussion concerning whether the warning should be printed or not seems more fundamental to me.
But thanks for all your help !
Moritz
> present in 6.2.2:
> In spearfish:
> selected map".
In mapcanvas.tcl, proc MapCanvas::zoom_gregion:
6.2.2:
if {[catch {close $input} error]} {
puts $error
exit
CVS:
Gm::errmsg $error [G_msg "Error setting region"]
The quickest fix is to change "exit" to "return" (Gm::errmsg ends with
"uplevel 1 return", which causes its caller to return).
BTW, I note that the top of gm.tcl has been modified to catch errors
and call Gm::errmsg. But Gm::errmsg hasn't been defined at that point.
This bug is a combination of TclTk and non-TclTk issues. The proximate
'cause' is that TclTk treats all data sent to stderr as real errors.
The current fix in 6.3 involves select.tcl (which now adds @[mapset] to all
selected items -- I don't know if this would or would not break other things
in 6.2), changes to quiet extraneous messages like the one below in some of
the GRASS modules, and changes to mapcanvas.tcl (and many other modules) to
greatly improve error trapping. The latter involves new error trapping
routines in gm.tcl.
I agree with Glynn that the easiest fix is to replace exit with return. This
will simply output the "error" message to the terminal and continue on.
I'm not sure how to put this into 6.2.2. Can you do it Moritz?
Michael
present in 6.2.2:
In spearfish:
selected map".
6.2.2:
puts $error
exit
CVS:
Director of Graduate Studies
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
selected items
Failure to add the @mapset probably results in a bug in the handling
of the case where the current mapset isn't the first one in the mapset
search path (an unqualified map name refers to the first map found
with that name, not necessarily the one in the current mapset).
Moritz,
to debug a bit.
Moritz
Fixed for 6.2.3 as
http://grass.itc.it/pipermail/grass-commit/2007-October/030589.html
which differs from above mentioned patch.
Hope this right now.
View this message in context: http://www.nabble.com/GRASS-6.2.2%3A-gis.m-crashes-when-there-are-more-than-one-map-with-same-name-in-path-tf4614950.html#a13330618
Sent from the Grass - Dev mailing list archive at Nabble.com.
