[GRASS-dev] GRASS 6.2.3RC1 published
GRASS 6.2.3RC1 has been published today:
http://grass.itc.it/grass62/source/
(on the mirrors soon).
This is a release candidate for the 6.2.3 bugfix release.
Bug fixes:
    * gis.m: georectifier tool documented (Markus Neteler)
    * r.out.bin: fixed too short buffer which would sometimes crash R-GRASS interface (Roger Bivand)
    * v.db.update: backported fixes for numeric value types (Debian #434897) (Markus Neteler)
    * GUI crash of g.region with accented characters (non English locale) (Maris Nartis, Hamish Bowman)
    * gis.m: maptool crash fixed (Moritz Lennert)
    * silently ignore --quiet and --verbose command line switches (Hamish Bowman)
Please add, if missing, more items at
http://grass.gdf-hannover.de/wiki/GRASS_6.2_Feature_Plan#6.2.3cvs
And please *test* this release candidate.
cheers,
Bug fixes:
Could this be backported to 6.2.3:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/gis/color_hist.c.diff?r1=2.3&r2=2.4
It doesn't look very intrusive, but sure is helpful. Without it the grey.log rule in r.colors distributes the colors between 0 and 255 and not between min and max values of the map.
Moritz
[Actually, the old version maps 1 -> black and max -> white.]
That patch will work on its own, but it amounts to an incompatible
change to the behaviour of r.colors.
Even if the existing behaviour is undesirable, suddenly changing it in
a minor revision may be more undesirable. There are cases where the
existing behaviour is "adequate" (i.e. where min/max is small), and
the incompatibility would be a nuisance (e.g. having to re-do existing
graphics to maintain consistency).
Bug fixes:
Another fix which should be backported to 6.2.3 IMHO:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/gui/tcltk/gis.m/gmtree.tcl.diff?r1=1.16&r2=1.17
At least the part concerning opening a Map Display automatically if none is open. AFAICT, this is just the following small change:
RCS file: /home/grass/grassrepository/grass6/gui/tcltk/gis.m/gmtree.tcl,v
retrieving revision 1.16
retrieving revision 1.17
diff -u -r1.16 -r1.17
--- grass6/gui/tcltk/gis.m/gmtree.tcl 2007/02/11 20:04:41 1.16
+++ grass6/gui/tcltk/gis.m/gmtree.tcl 2007/02/19 00:07:45 1.17
@@ -287,6 +287,10 @@
      global new_root_node
      global mon
+ # Create new tree, if none exists
+ if { [array size GmTree::tree] < 1 } {
+ Gm::startmon
      if { [catch {match string {} $new_root_node}] } {
      set new_root_node root
Moritz
I have backported this one.
> Bug fixes:
FreeGIS.org
      global mon
+ Gm::startmon
Moritz
