[GRASS-dev] GRASS 6.3.0 release preparation
Hi Michael
yes you're right it is my mistake
apologize me for this!
i'm uploading the cvs code using a bash script
in it i added a line that rename the gmmenu.tcl to
gmmenu_old.tcl and copy a local file "gmmenu.tcl" from
the previouse release in to the new
...really bud idea...
(this to preserve many changes that i done in the
gmmenu to add some script)
obviously i need to change this method :-/
thanks for the advice!
Massimo.
--- Michael Barton <michael.barton@asu.edu> ha
scritto:
Massimo,
I checked into these 2 GUI issues.
#4) Works for me. It opens an xmon and a terminal
with a prompt to pick a
vector network map. Your description of the menu
entry suggests that you are
using an old version. I changed this menu entry
several months ago when I
shortened all menus and changed menu nesting to more
more than 2 subentries
deep. Now it should be vector->network
analysis->display shortest route. Try
updating to a current version and see if it fixes
it. If not, we need to
find out why the TclTk procedure guarantee_xmon is
not producing a valid
list of xmons using d.mon -L. Try this command and
see what happens.
#5) I have the same problem. It stems from the TclTk
window being opened to
exactly the pixel height that bisects the last
checkbox control. I don't
know why it is not opening a bit further by default.
This is part of the
autogenerated TclTk dialogs for GRASS commands. I
only very generally know
how this works. So I'm not sure how to fix it. I'll
see if I can figure out
what is setting the window height.
Michael
      ___________________________________
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail: http://it.docs.yahoo.com/nowyoucan.html
