[GRASS-dev] grass 6.3, wxpython, g.parser
just compiled the GRASS 6.3 at ubuntu 8.10, there is a problem with the wx-gui:
$ grass63 -wxpython
GRASS>
# try to add raster layer to map, int the command line, I get:
*** buffer overflow detected ***: g.parser terminated
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb7e5e558]
/lib/tls/i686/cmov/libc.so.6[0xb7e5c680]
/lib/tls/i686/cmov/libc.so.6[0xb7e5bd68]
/lib/tls/i686/cmov/libc.so.6(_IO_default_xsputn+0xc8)[0xb7dd1a18]
/lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0xf4a)[0xb7da48da]
/lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa7)[0xb7e5be17]
/lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb7e5bd5d]
g.parser(main+0x3ac)[0x80491dc]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb7d7a685]
g.parser[0x8048ca1]
======= Memory map: ========
08048000-0804a000 r-xp 00000000 08:01 336155 /usr/lib/grass/bin/g.parser
0804a000-0804b000 r--p 00001000 08:01 336155 /usr/lib/grass/bin/g.parser
0804b000-0804c000 rw-p 00002000 08:01 336155 /usr/lib/grass/bin/g.parser
089d3000-089f4000 rw-p 089d3000 00:00 0 [heap]
b7cfe000-b7d0b000 r-xp 00000000 08:01 35096 /lib/libgcc_s.so.1
b7d0b000-b7d0c000 r--p 0000c000 08:01 35096 /lib/libgcc_s.so.1
b7d0c000-b7d0d000 rw-p 0000d000 08:01 35096 /lib/libgcc_s.so.1
b7d24000-b7d63000 r--p 00000000 08:01 263529
/usr/lib/locale/cs_CZ.utf8/LC_CTYPE
b7d63000-b7d64000 rw-p b7d63000 00:00 0
b7d64000-b7ebc000 r-xp 00000000 08:01 50431
/lib/tls/i686/cmov/libc-2.8.90.so
b7ebc000-b7ebe000 r--p 00158000 08:01 50431
b7ebe000-b7ebf000 rw-p 0015a000 08:01 50431
b7ebf000-b7ec2000 rw-p b7ebf000 00:00 0
b7ec2000-b7ee6000 r-xp 00000000 08:01 50439
/lib/tls/i686/cmov/libm-2.8.90.so
b7ee6000-b7ee7000 r--p 00023000 08:01 50439
b7ee7000-b7ee8000 rw-p 00024000 08:01 50439
b7ee8000-b7efc000 r-xp 00000000 08:01 240697 /usr/lib/libz.so.1.2.3.3
b7efc000-b7efe000 rw-p 00013000 08:01 240697 /usr/lib/libz.so.1.2.3.3
b7efe000-b7eff000 rw-p b7efe000 00:00 0
b7f0d000-b7f0e000 r--p 00000000 08:01 428699
/usr/lib/locale/cs_CZ.utf8/LC_MESSAGES/SYS_LC_MESSAGES
b7f0e000-b7f15000 r--s 00000000 08:01 678852
/usr/lib/gconv/gconv-modules.cache
b7f16000-b7f1d000 r-xp 00000000 08:01 428446
/usr/lib/grass/lib/libgrass_datetime.6.3.0.so
b7f1d000-b7f1e000 r--p 00006000 08:01 428446
b7f1e000-b7f1f000 rw-p 00007000 08:01 428446
b7f1f000-b7f6a000 r-xp 00000000 08:01 428459
/usr/lib/grass/lib/libgrass_gis.6.3.0.so
b7f6a000-b7f6b000 r--p 0004b000 08:01 428459
b7f6b000-b7f6c000 rw-p 0004c000 08:01 428459
b7f6c000-b7f74000 rw-p b7f6c000 00:00 0
b7f74000-b7f8e000 r-xp 00000000 08:01 32723 /lib/ld-2.8.90.so
b7f8e000-b7f8f000 r-xp b7f8e000 00:00 0 [vdso]
b7f8f000-b7f90000 r--p 0001a000 08:01 32723 /lib/ld-2.8.90.so
b7f90000-b7f91000 rw-p 0001b000 08:01 32723 /lib/ld-2.8.90.so
bfa7c000-bfa91000 rw-p bffeb000 00:00 0 [stack]
GRASS>
# when I want to select any raster map, only available mapset names
are listed, but NO maps
$ python
import wx
wx.__version__
'2.8.8.0'
any hint?
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
$ grass63 -wxpython
GRASS>
This doesn't actually look like a wxgui issue, but an issue with
g.parser. It would help if you could figure out which script is
triggering this.
2008/11/1 Glynn Clements <glynn@gclements.plus.com>:
$ grass63 -wxpython
GRASS>
triggering this.
sorry,
it appears, when I try to add raster map to monitor, the error
popusup, right before the "d.rast [display]" window, for raster map
name selection, is rendered. when I try to pick one map from the the
list of layers,
only mapsets are listed, but no maps
jachym
Jachym Cepicky
