Just did an update from the svn release branch this morning and am testing GRASS 6.4.1
There is a piece of left over testing code in toolbox.tcl from v.digit (line 55) that puts the button number to the screen. Can I just remove it and commit or do I need to do something special with respect to RC1?
Also, it seems like the tcltk digitizer is not making areas. I can create the boundary and add a centroid, but it does not turn into an area when saved. Perhaps I’m missing something here and someone else might want to test this.
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
so far everything goes well except for
Add shaded relief map
run from wxgui - it says
Warning
Map <elevation_shade@PERMANENT> not found
but it runs when the relevant command
d.his h_map=elevation i_map=elevation_shade
is pasted into command console
Helena
Also, it seems like the tcltk digitizer is not making areas. I can create the boundary and add a centroid, but it does not turn into an area when saved. Perhaps I'm missing something here and someone else might want to test this.
Michael
____________________
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
2011/1/6 Helena Mitasova <hmitaso@unity.ncsu.edu>:
Warning
fixed in r44896. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Martin,
thanks for the quick fix - I found few more instances of a similar problem:
d.grid runs from command console, when trying to add it through the GIS manager
it says Map <grid> not found
d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30 runs from command console
but when running it through GUI Add RGB... it cannot find the maps
Search module > Import vector data > common import formats fails to open GUI panel,
when run from GIS manager it opens GUI panel properly
same for Import raster data in common formats
GUI for raster import does not see .img for Erdas Imagine images (img files are grayed out),
it runs OK through the command dialog
Helena
On Jan 6, 2011, at 5:18 AM, Martin Landa wrote:
Warning
2011/1/7 Helena Mitasova <hmitaso@unity.ncsu.edu>:
these issues should be also fixed.
Seems to work on my machine. Can you post the traceback to ML?
Seems to work, choosing file/directory and format 'img', the files are
loaded properly.
Martin
On Jan 7, 2011, at 5:02 AM, Martin Landa wrote:
here it is ( same error also for DXF, E00, and for raster for common formats,
everything else works)
File
"/Users/Shared/src/GRASS/grass-6.4.1RC1-snow/dist.i386
-apple-darwin10.5.0/etc/wxpython/gui_modules/ghelp.py", line
311, in OnItemActivated
self.OnRun(None)
File
287, in OnRun
eval(handler)(event = None, cmd = data['command'].split())
TypeError
OnImportOgrLayers() got an unexpected keyword argument 'cmd'
Helena
loaded properly.
Martin
2011/1/11 Helena Mitasova <hmitaso@unity.ncsu.edu>:
hopefully fixed in r45018.
Martin
