[GRASS-dev] GRASS 6.4.2 release
it's about week since RC3 has been released. It would be nice to
release final 6.4.2 within next few days. We have still one blocker
[1] which is hopefully solved. Anything else need to be solved before
releasing (only urgent issues which have some probability that someone
will fix them)?
Thanks, Martin
[1] http://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&group=type&order=priority&priority=blocker&priority=critical&milestone=6.4.2&milestone=6.4.1&milestone=6.4.0
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
would be nice to release final 6.4.2 within next
few days.
it would be good to write up a more formal release
announcement like:
http://grass.osgeo.org/announces/announce_grass641.html
http://grass.osgeo.org/announces/abstract_grass641.txt
usually I'd help with that but I'm just heading off
to sea for a while.
(+ extended errata for things like r.nulls on wingrass if that doesn't get fixed in time)
thanks,
Hamish
2012/1/19 Hamish <hamish_b@yahoo.com>:
announcement like:
I have added initial draft to SVN (basically copy of 6.4.1 text)
http://trac.osgeo.org/grass/changeset/50363
Feel free to improve...
Martin
2012/1/19 Martin Landa <landa.martin@gmail.com>:
I would suggest to postpone final release for few days due to recently
introduced switch from Python 2.5 to 2.7 in OSGeo4W framework.
Martin
2012/1/24 Martin Landa <landa.martin@gmail.com>:
I would raise discussion about releasing 6.4.2. No blockers reported
[1], no other critical bug reported related to py2.7. I would vote for
releasing 6.4.2 in few next days.
Martin
tested a lot wingrass here on my winvista32-box with python 2.7., works
quite nicely and a lot faster than with python 2.5.
+1 for releasing it soon.
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-6-4-2-release-tp3991919p4365560.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
everything seems to be working here as well, except for a small issue just found by a student in wingrass
and confirmed in freshly compiled release on mac:
when saving image from map display that includes scale and legend, everything is saved correctly
when the default setting is used,
but when a template (pre-set image size) is used scale and legend either is not included
http://skagit.meas.ncsu.edu/~helena/grasswork/saveimg_test4.png
http://skagit.meas.ncsu.edu/~helena/grasswork/saveimg_test5.png
or it is not scaled properly
Helena
Helmut
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
This was already reported by Antonio in November:
http://lists.osgeo.org/pipermail/grass-user/2011-November/062577.html
and
http://lists.osgeo.org/pipermail/grass-user/2011-November/062601.html
(and following)
However, there never seems to have been a bug report about this.
Moritz
2012/2/6 Moritz Lennert <mlennert@club.worldonline.be>:
and
(and following)
right it's quite know issue, but not reported AFAIR. I would assume
that it's probable to fix it for 6.4.3 (different wxGUI code base). In
other words it's not blocker for 6.4.2.
Martin
