[GRASS-dev] GRASS 6.4 Windows issues
In addition to the v.type.sh issue, there are at least 2 more places where commands don't work in Windows.
v.patch won't start. Maybe it is not getting a bat version or something?
v.rast.stats will not work because it calls another script v.db.addcol and calling a bash script from within a bash script in Windows seems to be a problem. (note that calling v.db.addcol from the tcltk command processor works OK).
Can any of you windows folks check and find a way to fix these? I can have people test in my lab.
Michael
Works for me (mingw/msys build on vista), v.patch and v.rast.stats all
work in develbranch_6.
However, they fail when tested on trunk.
The v.patch window opens but then crashes when I run it.
v.rast.stats gives this errror:
  File "C:\MinGW\msys\local\grass-7.0.svn\etc\wxpython\gui_m
odules\mapdisp_window.py", line 536, in OnIdle
self.UpdateMap(render=True)
odules\mapdisp_window.py", line 661, in UpdateMap
self.Draw(self.pdc, self.img, drawid=id)
odules\mapdisp_window.py", line 289, in Draw
pdc.DrawBitmap(bitmap, wx.Point(coords[0], coords[1]), True)
# draw the composite map
  File "c:\MinGW\Python\lib\site-packages\wx-2.8-msw-
unicode\wx\_gdi.py", line 7438, in DrawBitmap
return _gdi_.PseudoDC_DrawBitmap(*args, **kwargs)
TypeError
in method 'PseudoDC_DrawBitmap', expected argument 3 of type
'int'
  File
"C:/MinGW/msys/local/grass-7.0.svn/etc/wxpython/wxgui.py",
line 521, in OnMenuCmd
menuform.GUI().ParseCommand(cmd, parentframe=self)
odules\menuform.py", line 1732, in ParseCommand
xml.sax.parseString( getInterfaceDescription(cmd[0]),
handler )
odules\menuform.py", line 1673, in getInterfaceDescription
raise IOError, _("Unable to fetch interface description for
command '%s'.") % cmd
IOError
Unable to fetch interface description for command
'v.rast.stats'.
-Colin
On Wed, Mar 18, 2009 at 2:37 PM, Michael Barton <michael.barton@asu.edu> wrote:
works OK).
Michael
grass-dev mailing list
grass-dev@lists.osgeo.org
I think that the reason that it works for you is that you is that you built this on Vista. I'd bet that the OSGEO4W GRASS 6.4RC3 is built on XP.
It looks like we need both XP and Vista versions unless the Vista version works equally well on both.
Michael
TypeError
'int'
File
handler )
IOError
'v.rast.stats'.
-Colin
works OK).
Michael
grass-dev Info Page
