[GRASS-dev] GRASS 6.5 GEOS build fails
hi,
any clue how to compile 6.5 with GEOS support? Vlib fails:
[neteler@localhost Vlib]$ make
gcc -shared -o /home/neteler/grass65/dist.x86_64-unknown-linux-gnu/lib/libgrass_vect.6.5.svn.so
-L/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/lib
-Wl,--no-undefined -Wl,--export-dynamic -L/usr/lib64
-Wl,-rpath-link,/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/lib
   OBJ.x86_64-unknown-linux-gnu/area.o
OBJ.x86_64-unknown-linux-gnu/array.o
OBJ.x86_64-unknown-linux-gnu/box.o
OBJ.x86_64-unknown-linux-gnu/break_lines.o
OBJ.x86_64-unknown-linux-gnu/break_polygons.o
OBJ.x86_64-unknown-linux-gnu/bridges.o
OBJ.x86_64-unknown-linux-gnu/buffer2.o
OBJ.x86_64-unknown-linux-gnu/buffer.o
OBJ.x86_64-unknown-linux-gnu/build.o
OBJ.x86_64-unknown-linux-gnu/build_nat.o
OBJ.x86_64-unknown-linux-gnu/build_ogr.o
OBJ.x86_64-unknown-linux-gnu/cats.o
OBJ.x86_64-unknown-linux-gnu/cindex.o
OBJ.x86_64-unknown-linux-gnu/clean_nodes.o
OBJ.x86_64-unknown-linux-gnu/close.o
OBJ.x86_64-unknown-linux-gnu/close_nat.o
OBJ.x86_64-unknown-linux-gnu/close_ogr.o
OBJ.x86_64-unknown-linux-gnu/constraint.o
OBJ.x86_64-unknown-linux-gnu/dangles.o
OBJ.x86_64-unknown-linux-gnu/dbcolumns.o
OBJ.x86_64-unknown-linux-gnu/dgraph.o
OBJ.x86_64-unknown-linux-gnu/e_intersect.o
OBJ.x86_64-unknown-linux-gnu/error.o
OBJ.x86_64-unknown-linux-gnu/field.o
OBJ.x86_64-unknown-linux-gnu/find.o
OBJ.x86_64-unknown-linux-gnu/geos.o
OBJ.x86_64-unknown-linux-gnu/graph.o
OBJ.x86_64-unknown-linux-gnu/header.o
OBJ.x86_64-unknown-linux-gnu/hist.o
OBJ.x86_64-unknown-linux-gnu/init_head.o
OBJ.x86_64-unknown-linux-gnu/intersect.o
OBJ.x86_64-unknown-linux-gnu/legal_vname.o
OBJ.x86_64-unknown-linux-gnu/level.o
OBJ.x86_64-unknown-linux-gnu/level_two.o
OBJ.x86_64-unknown-linux-gnu/line.o
OBJ.x86_64-unknown-linux-gnu/list.o OBJ.x86_64-unknown-linux-gnu/map.o
OBJ.x86_64-unknown-linux-gnu/net.o OBJ.x86_64-unknown-linux-gnu/open.o
OBJ.x86_64-unknown-linux-gnu/open_nat.o
OBJ.x86_64-unknown-linux-gnu/open_ogr.o
OBJ.x86_64-unknown-linux-gnu/overlap.o
OBJ.x86_64-unknown-linux-gnu/overlay.o
OBJ.x86_64-unknown-linux-gnu/poly.o
OBJ.x86_64-unknown-linux-gnu/read.o
OBJ.x86_64-unknown-linux-gnu/read_nat.o
OBJ.x86_64-unknown-linux-gnu/read_ogr.o
OBJ.x86_64-unknown-linux-gnu/remove_areas.o
OBJ.x86_64-unknown-linux-gnu/remove_duplicates.o
OBJ.x86_64-unknown-linux-gnu/rewind.o
OBJ.x86_64-unknown-linux-gnu/rewind_nat.o
OBJ.x86_64-unknown-linux-gnu/rewind_ogr.o
OBJ.x86_64-unknown-linux-gnu/select.o
OBJ.x86_64-unknown-linux-gnu/sindex.o
OBJ.x86_64-unknown-linux-gnu/snap.o OBJ.x86_64-unknown-linux-gnu/tin.o
OBJ.x86_64-unknown-linux-gnu/type.o
OBJ.x86_64-unknown-linux-gnu/window.o
OBJ.x86_64-unknown-linux-gnu/write.o
OBJ.x86_64-unknown-linux-gnu/write_nat.o -lgrass_gis -lgrass_datetime
-lz -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz
-lgrass_rtree -lgrass_dgl -lgrass_rtree -lgrass_linkm
-lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz
   -lgrass_gis -lgrass_datetime -lz -lgrass_dbmibase -lgrass_gis
-lgrass_datetime -lz -L/usr/local/lib -lgdal -lm -L/usr/lib64
-lgeos && \
        (cd /home/neteler/grass65/dist.x86_64-unknown-linux-gnu/lib;
ln -f -s libgrass_vect.6.5.svn.so
/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/lib/libgrass_vect.so)
/usr/bin/ld: Dwarf Error: Offset (1083) greater than or equal to
.debug_str size (314).
OBJ.x86_64-unknown-linux-gnu/geos.o: In function
`Vect_read_area_geos':
/home/neteler/grass65/lib/vector/Vlib/geos.c:90: undefined reference
to `GEOSGeom_createLinearRing'
/home/neteler/grass65/lib/vector/Vlib/geos.c:104: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:110: undefined reference
to `GEOSGeom_createPolygon'
OBJ.x86_64-unknown-linux-gnu/geos.o: In function `Vect_line_to_geos':
/home/neteler/grass65/lib/vector/Vlib/geos.c:155: undefined reference
to `GEOSCoordSeq_create'
/home/neteler/grass65/lib/vector/Vlib/geos.c:158: undefined reference
to `GEOSCoordSeq_setX'
/home/neteler/grass65/lib/vector/Vlib/geos.c:159: undefined reference
to `GEOSCoordSeq_setY'
/home/neteler/grass65/lib/vector/Vlib/geos.c:161: undefined reference
to `GEOSCoordSeq_setZ'
/home/neteler/grass65/lib/vector/Vlib/geos.c:165: undefined reference
to `GEOSGeom_createPoint'
/home/neteler/grass65/lib/vector/Vlib/geos.c:167: undefined reference
to `GEOSGeom_createLineString'
/home/neteler/grass65/lib/vector/Vlib/geos.c:169: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:170: undefined reference
to `GEOSisRing'
/home/neteler/grass65/lib/vector/Vlib/geos.c:172: undefined reference
`Vect__read_line_geos':
/home/neteler/grass65/lib/vector/Vlib/geos.c:208: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:212: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:215: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:216: undefined reference
to `GEOSisRing'
/home/neteler/grass65/lib/vector/Vlib/geos.c:218: undefined reference
OBJ.x86_64-unknown-linux-gnu/geos.o: In function `V1_read_line_geos':
/home/neteler/grass65/lib/vector/Vlib/geos.c:302: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:314: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:348: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:370: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:371: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:373: undefined reference
`read_polygon_points':
/home/neteler/grass65/lib/vector/Vlib/geos.c:474: undefined reference
to `GEOSCoordSeq_getSize'
/home/neteler/grass65/lib/vector/Vlib/geos.c:480: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:483: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:486: undefined reference
to `GEOSCoordSeq_getX'
/home/neteler/grass65/lib/vector/Vlib/geos.c:487: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:489: undefined reference
to `GEOSCoordSeq_getY'
/home/neteler/grass65/lib/vector/Vlib/geos.c:490: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:493: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:494: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:500: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:501: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:503: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:504: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:507: undefined reference
/home/neteler/grass65/lib/vector/Vlib/geos.c:508: undefined reference
collect2: ld returned 1 exit status
make: *** [/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/lib/libgrass_vect.6.5.svn.so]
Error 1
I am using
lib64geos3-3.0.3-1mdv2009.1
lib64geos_c1-3.0.3-1mdv2009.1
lib64geos-devel-3.0.3-1mdv2009.1
On 25/07/09 16:30, Markus Neteler wrote:
hi,
What did you feed configure ? It should be something like this:
--with-geos=/usr/bin/geos-config
This works for me with libgeos-3.0.0.
Moritz
Ah. With geos-2.2.3, the configure checks pass, but the build fails.
The GEOS configure checks should actually do some checking. Apart from
the version issue, there's no LOC_CHECK_LIBS or similar, so the checks
will pass even if the library is entirely absent.
LOC_CHECK_LIBS checks for a specific symbol, so it should be
straightforward to check for a symbol which is only present in 3.x.
On Tue, Jul 28, 2009 at 5:18 PM, Glynn Clements<glynn@gclements.plus.com> wrote:
Something like this?
[neteler@localhost grass70]$ svn diff configure.in
Index: configure.in
--- configure.in (revision 38604)
+++ configure.in (working copy)
@@ -761,7 +761,7 @@
   fi
   LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
+ LOC_CHECK_LIBS(geos,GEOSGeom_createLinearRing,GEOS,$GEOS_CFLAGS,$GEOS_LIBS,)
   AC_DEFINE(HAVE_GEOS)
fi
It generates:
cat config.log
configure:7637: checking whether to use GEOS
configure:7654: checking for geos-config
configure:7702: checking for geos_c.h
configure:7710: gcc -E -I/usr/include conftest.c >/dev/null 2>conftest.out
configure:7745: checking for GEOSGeom_createLinearRing in -lgeos
configure:7762: gcc -o conftest -g -Wall
-Werror-implicit-function-declaration -fno-common -mtune=nocona -m64
-minline-all-stringops -I/usr/include -Wl,--no-undefined
-Wl,--export-dynamic -L/usr/lib64 conftest.c -lgeos 1>&5
/home/neteler/tmp/cckqk93a.o: In function `main':
/home/neteler/grass70/configure:7758: undefined reference to
(still no solution to the original problem:
perhaps my much liked "-Werror-implicit-function-declaration" is the problem?)
Probably:
  LOC_CHECK_LIBS(geos,GEOSGeom_createLinearRing,GEOS,$GEOS_LIBS,GEOS_LIBS)
Your original problem appears to be that you don't have a compatible
version of GEOS installed. It's compiling okay, so it looks like the
headers are compatible but the library isn't. Maybe a problem with
32-bit and 64-bit libraries?
On Mon, Aug 3, 2009 at 8:19 PM, Glynn Clements<glynn@gclements.plus.com> wrote:
Probably:
   LOC\_CHECK\_LIBS\(geos,GEOSGeom\_createLinearRing,GEOS,$GEOS\_LIBS,GEOS\_LIBS\)
Ok but same effect.
[neteler@localhost grass70]$ /usr/bin/geos-config --libs
-L/usr/lib64 -lgeos
[neteler@localhost grass70]$ ldd /usr/lib64/libgeos.so
        linux-vdso.so.1 => (0x00007fff2e1fe000)
        libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007ff225a52000)
        libm.so.6 => /lib64/libm.so.6 (0x00007ff2257ce000)
        libc.so.6 => /lib64/libc.so.6 (0x00007ff22546b000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007ff225255000)
        /lib64/ld-linux-x86-64.so.2 (0x00007ff2260ca000)
[neteler@localhost grass70]$ file /usr/lib64/libgeos.so
/usr/lib64/libgeos.so: symbolic link to `libgeos-3.0.3.so'
[neteler@localhost grass70]$ file /usr/lib64/libgeos-3.0.3.so
/usr/lib64/libgeos-3.0.3.so: ELF 64-bit LSB shared object, x86-64,
version 1 (SYSV), dynamically linked, stripped
The RPM looks ok but I'll recompile it from the source tarball.
Probably:
I have submitted that.
Locally it fails for me, according to config.log the following line is missing:
#include <geos_c.h>
If I extract the test manually, it find the function GEOSGeom_createLinearRing()
but complains about:
gcc -o conftest -g -Wall -Werror-implicit-function-declaration
-fno-common -mtune=nocona -m64 -minline-all-stringops
-L/usr/local/lib -lgeos -Wl,--no-undefined -Wl,--export-dynamic
conftest.c:7: error: conflicting types for ‘GEOSGeom_createLinearRing’
/usr/local/include/geos_c.h:237: error: previous declaration of
‘GEOSGeom_createLinearRing’ was here
In /usr/local/include/geos_c.h it is
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
but in conftest.c it is:
char GEOSGeom_createLinearRing();
No idea how to fix the test in configure.in.
> Probably:
#include <geos_c.h>
That line isn't supposed to be there.
conftest.c:7: error: conflicting types for �GEOSGeom_createLinearRing�
�GEOSGeom_createLinearRing� was here
Library checks merely check that the function is exported by the
library. The declaration doesn't need to have the correct type, as the
linker doesn't perform any type checking.
Note that the library checks only work with exported functions. They
won't work with macros or inline functions, as those don't exist in
the library.
2009/8/8 Markus Neteler <neteler@osgeo.org>:
hopefully fixed in r38867.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
No. Broken in r38867; fixed (i.e. reverted) in r38872.
GRASS needs GEOS 3.x; the check is supposed to fail on older versions.
2009/8/26 Glynn Clements <glynn@gclements.plus.com>:
Sorry, on my computer is broken now...
geos-config --version
3.1.0
checking for geos-config... /usr/local/bin/geos-config
checking for geos_c.h... yes
checking for GEOSGeom_createLinearRing in -lgeos... no
configure: error: *** Unable to locate GEOS library.
Martin
2009/8/26 Martin Landa <landa.martin@gmail.com>:
as I mentioned earlier it should check geos_c (i.e. GEOS C API) not geos.
Martin
