Hi
I just received the news, that the new homebrew recipe for GRASS 7.0
does install on El Capitan with SIP enabled!
This is thanks to Larry Shaffer.
See
https://github.com/OSGeo/homebrew-osgeo4mac/issues/118#issuecomment-200278686
The recipe is part of the Homebrew-osgeo4mac tap, see
for info on how to use them.
I will see that I can port the changes to my grass-71 formula as well -
will keep you posted when it works.
Thanks a lot Larry,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
I just tested the new brew recipe and it compiles fine. I had to set these to get wxgui working:
export GRASS_PYTHON=/usr/local/bin/pythonw
export PYTHONPATH=/usr/local/lib/python2.7/site-packages:$PYTHONPATH
Carlos
On Wed, Mar 23, 2016 at 8:06 AM, Rainer M Krug <Rainer@krugs.de> wrote:
Hi
See
Thanks a lot Larry,
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
grass-user mailing list
grass-user@lists.osgeo.org
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
