grass70
with new wxgui i selected location wizard on the startup screen
- select coordinate system
- choose projection — ll(lat/long)
- select ellipsoid ---- everst56
- Summary
after the location wizard when i click finish
a message window appears with
Do you want to set the default region extents and resolution now?
if yes button was clicked…
another message window displays
Error invlaid region
and a window appears
when grass is restarted with new loacation created error apperas with
title : Error in g.region execution
message : Unable to get current geographic extent. Force quiting wxGUI. Please run manually g.region to fix the problem
when run g.region at command line
as g.region -p
error appers as
segmentation fault
But no problem reports for other types such as xy location, georeferenced files etc…
On Tue, Mar 3, 2009 at 7:31 PM, Mohammed Rashad <rashadkm@gmail.com> wrote:
grass70
1. select coordinate system
2. choose projection --- ll(lat/long)
3. select ellipsoid ---- everst56
4. Summary
`Do you want to set the default region extents and resolution now?`
if yes button was clicked..
`Error invlaid region`
as g.region -p
error appers as
segmentation fault
files etc..
- when did you download GRASS? there have been modifications recently
in this part
- which operating system are you using?
- if Linux, what does
ldd `which g.region`
say?
grass70
- Summary
as g.region -p
error appers as
segmentation fault
files etc…
in this part
ldd which g.region
say?
I had downloaded grass from svn on February 10 and i am using ubuntu 8.10
GRASS 7.0.svn (loc11):~ > ldd which g.region
linux-gate.so.1 => (0xb7f5e000)
libgrass_vect.so => /usr/local/grass-7.0.svn/lib/libgrass_vect.so (0xb7f06000)
libgrass_dbmibase.so => /usr/local/grass-7.0.svn/lib/libgrass_dbmibase.so (0xb7ef6000)
libgrass_gis.so => /usr/local/grass-7.0.svn/lib/libgrass_gis.so (0xb7ea8000)
libgrass_datetime.so => /usr/local/grass-7.0.svn/lib/libgrass_datetime.so (0xb7e9f000)
libz.so.1 => /usr/lib/libz.so.1 (0xb7e77000)
libgrass_dbmiclient.so => /usr/local/grass-7.0.svn/lib/libgrass_dbmiclient.so (0xb7e6d000)
libgrass_dgl.so => /usr/local/grass-7.0.svn/lib/libgrass_dgl.so (0xb7e55000)
libgrass_dig2.so => /usr/local/grass-7.0.svn/lib/libgrass_dig2.so (0xb7e40000)
libgrass_rtree.so => /usr/local/grass-7.0.svn/lib/libgrass_rtree.so (0xb7e39000)
libgrass_linkm.so => /usr/local/grass-7.0.svn/lib/libgrass_linkm.so (0xb7e36000)
libgdal1.5.0.so.1 => /usr/lib/libgdal1.5.0.so.1 (0xb78c2000)
libgrass_g3d.so => /usr/local/grass-7.0.svn/lib/libgrass_g3d.so (0xb78a4000)
libgrass_gproj.so => /usr/local/grass-7.0.svn/lib/libgrass_gproj.so (0xb789a000)
libproj.so.0 => /usr/lib/libproj.so.0 (0xb7868000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7842000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb76e4000)
libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0xb76e0000)
libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0xb76cf000)
libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0xb765f000)
libodbc.so.1 => /usr/lib/libodbc.so.1 (0xb75f8000)
libodbcinst.so.1 => /usr/lib/libodbcinst.so.1 (0xb75eb000)
libexpat.so.1 => /usr/lib/libexpat.so.1 (0xb75c4000)
libxerces-c.so.28 => /usr/lib/libxerces-c.so.28 (0xb720a000)
libjasper.so.1 => /usr/lib/libjasper.so.1 (0xb71bb000)
libhdf5-1.6.6.so.0 => /usr/lib/libhdf5-1.6.6.so.0 (0xb7089000)
libmfhdf.so.4 => /usr/lib/libmfhdf.so.4 (0xb7064000)
libdf.so.4 => /usr/lib/libdf.so.4 (0xb6fbd000)
libogdi.so.3.2 => /usr/lib/libogdi.so.3.2 (0xb6f9f000)
libgif.so.4 => /usr/lib/libgif.so.4 (0xb6f97000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb6f76000)
libtiff.so.4 => /usr/lib/libtiff.so.4 (0xb6f21000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb6efb000)
libnetcdf.so.4 => /usr/lib/libnetcdf.so.4 (0xb6eca000)
libpq.so.5 => /usr/lib/libpq.so.5 (0xb6ea9000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0xb6e90000)
librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0xb6e86000)
libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4 (0xb6e4b000)
libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15 (0xb6c68000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb6b79000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb6b6a000)
/lib/ld-linux.so.2 (0xb7f44000)
libgeos-3.0.0.so => /usr/lib/libgeos-3.0.0.so (0xb6a3f000)
libltdl.so.7 => /usr/lib/libltdl.so.7 (0xb6a36000)
libicuuc.so.38 => /usr/lib/libicuuc.so.38 (0xb690e000)
libicudata.so.38 => /usr/lib/libicudata.so.38 (0xb5e37000)
libssl.so.0.9.8 => /usr/lib/i686/cmov/libssl.so.0.9.8 (0xb5df1000)
libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xb5ca5000)
libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0xb5c13000)
libcom_err.so.2 => /lib/libcom_err.so.2 (0xb5c0f000)
libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0xb5be5000)
libcrypt.so.1 => /lib/tls/i686/cmov/libcrypt.so.1 (0xb5bb3000)
libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2 (0xb5b70000)
libidn.so.11 => /usr/lib/libidn.so.11 (0xb5b3e000)
libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0xb5b1a000)
libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0xb5a7d000)
libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0xb5a6b000)
libgcrypt.so.11 => /lib/libgcrypt.so.11 (0xb5a02000)
libnsl.so.1 => /lib/tls/i686/cmov/libnsl.so.1 (0xb59e8000)
libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0xb59df000)
libkeyutils.so.1 => /lib/libkeyutils.so.1 (0xb59db000)
libresolv.so.2 => /lib/tls/i686/cmov/libresolv.so.2 (0xb59c7000)
liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0xb59b9000)
libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0xb59a0000)
libgpg-error.so.0 => /lib/libgpg-error.so.0 (0xb599c000)
On Wed, Mar 4, 2009 at 3:51 PM, Mohammed Rashad <rashadkm@gmail.com> wrote:
> grass70
> 4. Summary
> as g.region -p
> error appers as
> segmentation fault
> georeferenced
> files etc..
in this part
say?
Two things
- please update from svn with
svn up
- consider to update GDAL on ubuntu 8.10 which was causing troubles
https://bugs.launchpad.net/ubuntu/+source/gdal/+bug/271670
"libgdal1-1.5.0_1.5.2 couse Segmentation fault in any in depend
app like mapserver qgis"
(so also GRASS):
GRASS 7.0.svn (loc11):~ > ldd `which g.region`
(0xb7f06000)
libgdal1\.5\.0\.so\.1 => /usr/lib/libgdal1\.5\.0\.so\.1 \(0xb78c2000\)
