[GRASS-dev] GRASS 7.0beta3 planning
as Martin stated in a recent ticket comment, beta3 should be released asap.
I would like to get first the pygrass changes backported (not
difficult including the manual improvements).
A few more things are potentially missing, too.
Opinions?
On Sun, May 25, 2014 at 5:23 PM, Markus Neteler <neteler@osgeo.org> wrote:
I backported what I think is appropriate and these (not critical) tickets
are still waiting for confirmation:
http://trac.osgeo.org/grass/ticket/2243
this needs more testing across platforms, both with wxPython 2.8 and 3, so
we might want to wait
http://trac.osgeo.org/grass/ticket/2026 (v.surf.rst window too wide)
Anna
Opinions?
grass-dev mailing list
grass-dev@lists.osgeo.org
On 25 May 2014 23:23, Markus Neteler <neteler@osgeo.org> wrote:
Today and tomorrow I would like to improve a little bit more the
pygrass manual, could you wait few days before backport these changes?
Opinions?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
On Sun, May 25, 2014 at 11:23 PM, Markus Neteler <neteler@osgeo.org> wrote:
Maybe we skip the pygrass sphinx docs for RC3?
... the OSGeoLive feature freeze for the FOSS4G Portland conf is upcoming.
But other pygrass fixes should be backported.
Anyway we mostly focus on the online documentation being up to date, right?
This would be nice.
here a list of backport candidates:
r60692 v.out.ogr
r60674 v.in.ogr
r60656 v.in.ogr
r60596 v.in.ogr
r60595 v.in.ogr
r60662 lib/python/script/raster.py
# needed for QGIS
r60590 include/defs/gis.h, lib/gis/error.c
please comment or backport,
2014-06-08 1:21 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
I went through my list of planned backports and did the job
(r60736-44). The rest I will leave for authors of mentioned commits
(hcho and annakrat).
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
I merged the v.in/out.ogr backports except r60596 because v.in.ogr in relbr7 doesn’t have the PG specific code, which I wasn’t sure can be simply copied over from trunk… Martin?
On Sun, Jun 8, 2014 at 5:07 AM, Martin Landa <landa.martin@gmail.com> wrote:
Martin
2014-06-08 12:08 GMT+02:00 Huidae Cho <grass4u@gmail.com>:
doesn't have the PG specific code, which I wasn't sure can be simply copied
over from trunk... Martin?
it's related to PG database/ogr driver, seems to be OK.
Martin
Done in r60748.
On Sun, Jun 8, 2014 at 6:40 AM, Martin Landa <landa.martin@gmail.com> wrote:
it’s related to PG database/ogr driver, seems to be OK.
Martin
what do you think about releasing beta3? The problems mentioned in this thread were fixed and fixes backported except for r60590 which is safe for GRASS by itself and thus can be safely backported now.
Vaclav
r60590
Add G_fatal_longjmp() (needed for QGIS)
glynn
http://trac.osgeo.org/grass/changeset/60590
There is a lot of things in the tracker but they can be postponed I think:
long-term problem for non-ascii languages
http://trac.osgeo.org/grass/ticket/1681
remove ffmpeg from libogsf and configure.in
let’s do it in trunk first, it does not have to be in beta
http://trac.osgeo.org/grass/ticket/2017
wxGUI vector digitizer passing unescaped text to database
security issue but not a real issue for most of the users I guess
http://trac.osgeo.org/grass/ticket/2252
missing documentation
bad but does not stop beta release
http://trac.osgeo.org/grass/ticket/2259
inconsistent random number generation
long-term problem, beta can live with it
http://trac.osgeo.org/grass/ticket/2272
insufficient error message when addons are mixed on MS Windows
To be honest, I’m not sure why this is a blocker
http://trac.osgeo.org/grass/ticket/2283
rename some imagery modules
should be done before release but not needed for beta
http://trac.osgeo.org/grass/ticket/2340
I’m not really familiar with these
http://trac.osgeo.org/grass/ticket/995
http://trac.osgeo.org/grass/ticket/1891
Python and MS Windows
there is a solution in 7.0 and some advances were made also in trunk
http://trac.osgeo.org/grass/ticket/580
http://trac.osgeo.org/grass/ticket/1871
http://trac.osgeo.org/grass/ticket/2150
have look in
http://lists.osgeo.org/pipermail/grass-dev/2014-July/069983.html
"[GRASS-dev] GRASS 7: g.gui.rlisetup
Backport of r60219 is needed.
http://trac.osgeo.org/grass/changeset/60219&quot;
g.gui.rlisetup isn't starting in winGRASS7.0
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-7-0beta3-planning-tp5142434p5151655.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
have look in
Done in r61304.
Please test tomorrow's binary snapshot.
On Fri, Jul 18, 2014 at 12:22 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Yes and no: it is time to do it but without the current blocker.
r60590
glynn
... if so, please do (someone) that.
It is important to make real issues either blocker or at least
critical to avoid that it slips through.
... I think we need to shift this listing either to a Wiki or to trac
bugs. It is not efficient to do it via email (let's use that for the
ping'ing).
Concerning the BAT file support, is that now in relbr7?
There is currently 10 blockers for 7.0 and 7.1, 3-5 are duplicates of
Python issue.
In addition to that. The g.list, g.mlist, g.remove and g.mremove chnages
are in fact blockers since they are changing API.
ping'ing).
The query on Trac seems appropriate. We can add it to reports (as what?)
or you can put a query result to a page. Some pages are using it.
== List of tickets ==
[[TicketQuery(component=wxGUI&keywords=wxiclass&order=priority)]]
http://trac.osgeo.org/grass/wiki/wxGUIDevelopment/wxIClass#Listoftickets
http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&col=version&col=keywords&col=time&col=changetime&milestone=7.0.0&type=!enhancement
No, relbr7 is using the older workaround. And about BAT and Python in
general in trunk. I'm now confused about what was implemented and why.
Vaclav
Markus Neteler wrote
On Fri, Jul 18, 2014 at 8:39 AM, Helmut Kudrnovsky &lt;
hellik@
have look in
Done in r61304.
grass-dev@.osgeo
tested with:
GRASS Version: 7.0.0svn
GRASS SVN Revision: 61304
Erstellungsdatum: 2014-07-22
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
g.gui.rlisetup is working now; but an g.gui.rlisetup-entry in the main GUI
is missing.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-7-0beta3-planning-tp5142434p5152402.html
> hellik@
>> have look in
> Done in r61304.
> Markus
> grass-dev@.osgeo
tested with:
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
is missing.
Isn't it the 'Set up sampling and analysis framework? ' in Raster ->
Landscape patch analysis?
Anna
best regards
Helmut
GUI
is missing.
Anna
ah, yes, you're right, sorry for the noise.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-7-0beta3-planning-tp5142434p5152495.html
On Mon, May 26, 2014 at 11:03 AM, Luca Delucchi <lucadeluge@gmail.com> wrote:
all:
I guess we are completely out of sync concerning the PyGRASS docs.
(Un)related to beta3, how should we handle that? Backport it after beta3?
On 22 July 2014 22:36, Markus Neteler <neteler@osgeo.org> wrote:
all:
I think it is better...we could move PyGRASS, WXGUI and Python script
documentation for the next beta or for the first RC.
ciao
Luca
www.lucadelu.org
