[GRASS-dev] GRASS 7.2RC2 problem
Yesterday I compiled GRASS 7.2 RC2 with no errors. Today I tried to test it before posting and got the following error:
GRASS 7.2.0RC2 (Global_latlon):~ > Traceback (most recent call last):
File “/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py”, line 158, in
sys.exit(main())
File “/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py”, line 145, in main
app = GMApp(workspaceFile)
File “/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py”, line 48, in init
wx.App.init(self, False)
File “/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py”, line 7981, in init
self._BootstrapApp()
File “/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py”, line 7555, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py”, line 92, in OnInit
workspace=self.workspaceFile)
File “/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py”, line 129, in init
self._menuTreeBuilder = LayerManagerMenuData()
File “/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py”, line 42, in init
self, filename, expandAddons=expandAddons)
File “/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py”, line 65, in init
xmlTree = etree.parse(filename)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 1182, in parse
tree.parse(source, parser)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 657, in parse
self._root = parser.close()
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 1654, in close
self._raiseerror(v)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 1506, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Any idea what this is?
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Just a reminder.
GRASS 7.2RC2 does not run on the Mac.
Other versions, include recent 7.3 (I have not tried to compile since September) do work fine. No errors compiling, but I get the error below when I try to run it. Any advice would be helpful.
Michael
C. Michael Barton
sys.exit(main())
self._raiseerror(v)
raise err
Michael
C. Michael Barton
On Mon, Dec 5, 2016 at 1:24 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Just a reminder.
I've just compiled it on Mac and it ran just fine. Since the error
comes from the addon toolboxes, what kind of addons do you have
installed? I suggest to recompile and check if there are any errors in
the compilation output.
Anna
Michael
____________________
C. Michael Barton
  File "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py",
line 158, in <module>
    sys.exit(main())
line 145, in main
line 48, in __init__
    wx.App.__init__(self, False)
  File
"/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
line 7981, in __init__
  File
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
line 92, in OnInit
  File
"/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
line 129, in __init__
  File
"/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
line 42, in __init__
  File
"/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py",
line 65, in __init__
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
line 1182, in parse
  File
line 657, in parse
  File
line 1654, in close
    self._raiseerror(v)
  File
    raise err
Michael
C. Michael Barton
sorry, but is it reported as an issue on trac? It's hard to follow all
mails with all the strange subjects. Thanks, more over it looks like
an issue with the computer which you use for building. Some details
would be useful. I hope that my colleagues with Mac will help. Good
luck, Martin
2016-12-05 19:24 GMT+01:00 Michael Barton <Michael.Barton@asu.edu>:
Just a reminder.
Michael
C. Michael Barton
    sys.exit(main())
line 145, in main
  File
  File
line 92, in OnInit
  File
  File
  File
  File
line 1182, in parse
  File
line 657, in parse
  File
line 1654, in close
    self._raiseerror(v)
  File
    raise err
Michael
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
You mean addons on my local machine or something else?
Michael
C. Michael Barton
Just a reminder.
Anna
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=5qA3mt0eYGlhGT5ZLNbHEc3zjLmnesbRw6j4spKp1oY&s=fG_nZiBNPANgQlxr45MZoW7b4hsq55ZBxX9iuPaePIo&e= , Center for Social Dynamics and Complexity
   sys.exit(main())
line 145, in main
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
   self._raiseerror(v)
File
   raise err
Michael
C. Michael Barton
On Mon, Dec 5, 2016 at 1:52 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
The more I Iook at it, the addons have nothing to do with it. Just try
to compile it again, there should be some error. BTW, there is no
difference in toolboxes code in trunk and 72.
Anna
Michael
C. Michael Barton
Just a reminder.
Anna
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=5qA3mt0eYGlhGT5ZLNbHEc3zjLmnesbRw6j4spKp1oY&s=fG_nZiBNPANgQlxr45MZoW7b4hsq55ZBxX9iuPaePIo&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=5qA3mt0eYGlhGT5ZLNbHEc3zjLmnesbRw6j4spKp1oY&s=VxZo-g4_6S_iSUp9AKDAJPo7RvtgrHZ2s_mywOGLdsE&e=
   sys.exit(main())
line 145, in main
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
   self._raiseerror(v)
File
   raise err
Michael
C. Michael Barton
2016-12-05 19:52 GMT+01:00 Michael Barton <Michael.Barton@asu.edu>:
Compiled addons are always local. Ma
Just a reminder.
Anna
Michael
C. Michael Barton
   sys.exit(main())
line 145, in main
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
   self._raiseerror(v)
File
   raise err
Michael
C. Michael Barton
Martin Landa
I just did this morning. Same problem. No errors in compiling, only in running.
Michael
C. Michael Barton
Anna
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=1Q8NyOaJG6sOJwStQUePXvYtAPCxEk3JLrhBoC7Ezso&s=xt9rzbPn-6JhkZOF0oRZ4xAytf77ans2GhLJoux9rvw&e= , Center for Social Dynamics and Complexity
Just a reminder.
Anna
Michael
C. Michael Barton
  sys.exit(main())
line 145, in main
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
  self._raiseerror(v)
File
  raise err
Michael
C. Michael Barton
On Mon, Dec 5, 2016 at 2:00 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
g
Have you checked carefully the gui part of the compilation output?
It's long and the errors are easy to overlook, so I want to make sure.
What files do you have in GRASS-7.2/Contents/MacOS/gui/wxpython/xml ?
Is any of them empty?
Michael
C. Michael Barton
Anna
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=1Q8NyOaJG6sOJwStQUePXvYtAPCxEk3JLrhBoC7Ezso&s=xt9rzbPn-6JhkZOF0oRZ4xAytf77ans2GhLJoux9rvw&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=1Q8NyOaJG6sOJwStQUePXvYtAPCxEk3JLrhBoC7Ezso&s=B0867aqcIFuHWb3i8Cjf90d0V3_4w2hGp_ANetJlZHk&e=
Just a reminder.
Anna
Michael
C. Michael Barton
  sys.exit(main())
line 145, in main
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
  self._raiseerror(v)
File
  raise err
Michael
C. Michael Barton
No errors at all in the compiler log (attached).
The only thing in GRASS-7.2/Contents/MacOS/gui/wxpython/xml/ is
grass-interface.dtd
Michael
C. Michael Barton
On Dec 5, 2016, at 12:08 PM, Anna Petrášová kratochanna@gmail.com wrote:
g
It’s long and the errors are easy to overlook, so I want to make sure.
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=bBpzPDoS_3Ggj3kC_b9oXWPv1lSAOrSn-2Hm0wfY1jc&s=WOVKug_u69HERAVcBaXjQoUJWB8TmnLwAapaz0X8qug&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=bBpzPDoS_3Ggj3kC_b9oXWPv1lSAOrSn-2Hm0wfY1jc&s=BurW7at-ZQccpdBaiz13Wq-XTDW5dcwAy5FMysM2hVs&e=
Anna
Michael
C. Michael Barton
On Dec 5, 2016, at 11:49 AM, Anna Petrášová kratochanna@gmail.com wrote:
On Mon, Dec 5, 2016 at 1:24 PM, Michael Barton Michael.Barton@asu.edu wrote:
Just a reminder.
I’ve just compiled it on Mac and it ran just fine. Since the error
Anna
Michael
C. Michael Barton
line 158, in
sys.exit(main())
line 145, in main
line 48, in init
File
line 7981, in init
File
line 92, in OnInit
File
line 129, in init
File
line 42, in init
File
line 65, in init
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
self._raiseerror(v)
File
raise err
Michael
C. Michael Barton
(attachments)
error.log (241 Bytes)
On Mon, Dec 5, 2016 at 2:28 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
that's just the end of it
grass-interface.dtd
that's obviously the problem. Please send me the full compilation log,
I hope I could find something there.
Michael
C. Michael Barton
running.
g
Michael
C. Michael Barton
www:
Anna
Michael
C. Michael Barton
www:
Just a reminder.
below when
Anna
Michael
C. Michael Barton
www:
test it
File
sys.exit(main())
File
line 145, in main
File
File
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
self._raiseerror(v)
File
raise err
Michael
C. Michael Barton
www:
That's the the whole thing. IIRC, I can get a longer log with a switch to make but I can't remember off hand. If you tell me I'll run it while I head to class.
Michael
C. Michael Barton
grass-interface.dtd
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=trfWM24eHCIJuv-5HtnHbYhrw_DhjOl8tklxdwinP9Y&s=F33_k7g8oQHVwvmSEgNha12WYpAbCgNlO0pygNnY5CA&e= , Center for Social Dynamics and Complexity
running.
g
Michael
C. Michael Barton
www:
Anna
Michael
C. Michael Barton
www:
Just a reminder.
below when
Anna
Michael
C. Michael Barton
www:
test it
File
sys.exit(main())
File
line 145, in main
File
File
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
self._raiseerror(v)
File
raise err
Michael
C. Michael Barton
www:
2016-12-05 22:41 GMT+01:00 Michael Barton <Michael.Barton@asu.edu>:
no, it's not the whole thing.
make distclean
./configure...
make 2>&1 > make.log
Sent created `make.log`. Ma
grass-interface.dtd
Michael
C. Michael Barton
www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=trfWM24eHCIJuv-5HtnHbYhrw_DhjOl8tklxdwinP9Y&s=F33_k7g8oQHVwvmSEgNha12WYpAbCgNlO0pygNnY5CA&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=trfWM24eHCIJuv-5HtnHbYhrw_DhjOl8tklxdwinP9Y&s=3mWLR_h5YLzv1JXuZuo7xzFQbPMRSe76s3H0FHvouNE&e=
running.
g
Michael
C. Michael Barton
www:
Anna
Michael
C. Michael Barton
www:
Just a reminder.
below when
Anna
Michael
C. Michael Barton
www:
test it
File
sys.exit(main())
File
line 145, in main
File
File
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
self._raiseerror(v)
File
raise err
Michael
C. Michael Barton
www:
Martin Landa
That's what I need to create a longer long. Thanks
C. Michael Barton
make distclean
./configure...
grass-interface.dtd
Michael
C. Michael Barton
running.
g
Michael
C. Michael Barton
www:
Anna
Michael
C. Michael Barton
www:
Just a reminder.
below when
Anna
Michael
C. Michael Barton
www:
test it
File
sys.exit(main())
File
line 145, in main
File
File
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
self._raiseerror(v)
File
raise err
Michael
C. Michael Barton
www:
grass-dev Info Page
Martin Landa
Ing. Martin Landa, Ph.D. – GeoWikiCZ
Martin Landa - GISMentors
Anna and others. I’m attaching the make log I just ran. It might get bumped from the list but you’ll get it.
Michael
C. Michael Barton
On Dec 5, 2016, at 1:36 PM, Anna Petrášová kratochanna@gmail.com wrote:
that’s just the end of it
grass-interface.dtd
that’s obviously the problem. Please send me the full compilation log,
Michael
C. Michael Barton
running.
g
Michael
C. Michael Barton
www:
Anna
Michael
C. Michael Barton
www:
Just a reminder.
below when
Anna
Michael
C. Michael Barton
www:
test it
File
line 158, in
sys.exit(main())
File
line 145, in main
File
line 48, in init
File
line 7981, in init
File
File
line 92, in OnInit
File
line 129, in init
File
line 42, in init
File
line 65, in init
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
self._raiseerror(v)
File
raise err
Michael
C. Michael Barton
www:
(attachments)
make.log (350 KB)
sys.exit(main())
self._raiseerror(v)
raise err
Is this yet a showstopper for the final release?
On Tue, Dec 6, 2016 at 5:32 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Anna and others. I'm attaching the make log I just ran. It might get bumped
from the list but you'll get it.
Please first make distclean and then run make.
Thank you,
Anna
Michael
C. Michael Barton
grass-interface.dtd
Michael
C. Michael Barton
www:
running.
g
Michael
C. Michael Barton
www:
Anna
Michael
C. Michael Barton
www:
Just a reminder.
since
below when
in
Anna
Michael
C. Michael Barton
Change
www:
test it
last):
File
sys.exit(main())
File
line 145, in main
File
File
File
File
line 92, in OnInit
File
File
File
File
line 1182, in parse
File
line 657, in parse
File
line 1654, in close
self._raiseerror(v)
File
raise err
0
Michael
C. Michael Barton
Change
www:
It is. We don’t know what the problem is. I have a guess on this though. It may be a problem with generating the xml code for the addons menu. We had this problem awhile back.
Michael
C. Michael Barton
sys.exit(main())
self._raiseerror(v)
raise err
2016-12-06 23:45 GMT+01:00 Michael Barton <Michael.Barton@asu.edu>:
It is. We don't know what the problem is. I have a guess on this though. It
without full log (run make distclean before configure && make) we
cannot move from this point (this issue has been reported 7 days ago).
Thanks, Ma
    sys.exit(main())
line 145, in main
  File
  File
line 92, in OnInit
  File
  File
  File
  File
line 1182, in parse
  File
line 657, in parse
  File
line 1654, in close
    self._raiseerror(v)
  File
    raise err
Martin Landa
There is indeed no error in the log. I can see:
/usr/bin/install -c -m 644 xml/menudata.xml
/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/menudata.xml
/usr/bin/install -c -m 644 xml/module_tree_menudata.xml
/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/module_tree_menudata.xml
so the xml files are on the right places. Could you verify that? Are
these files correct? Then when you make install, are these files in
the grass7 app?
Anna
Thanks, Ma
    sys.exit(main())
line 145, in main
  File
  File
line 92, in OnInit
  File
  File
  File
  File
line 1182, in parse
  File
line 657, in parse
  File
line 1654, in close
    self._raiseerror(v)
  File
    raise err
Martin Landa
