They both have 0 bytes. This is the same problem we had many months back. I had a clunky workaround but it has not been necessary for some time now.
Michael
____________________
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 6, 2016, at 4:36 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
There is indeed no error in the log. I can see:
/usr/bin/install -c -m 644 xml/menudata.xml
/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/menudata.xml
/usr/bin/install -c -m 644 xml/module_tree_menudata.xml
/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/module_tree_menudata.xmlso the xml files are on the right places. Could you verify that? Are
these files correct? Then when you make install, are these files in
the grass7 app?Anna
On Tue, Dec 6, 2016 at 5:49 PM, Martin Landa <landa.martin@gmail.com> wrote:
2016-12-06 23:45 GMT+01:00 Michael Barton <Michael.Barton@asu.edu>:
It is. We don't know what the problem is. I have a guess on this though. It
may be a problem with generating the xml code for the addons menu. We had
this problem awhile back.without full log (run make distclean before configure && make) we
cannot move from this point (this issue has been reported 7 days ago).
Thanks, MaOn Nov 29, 2016 10:13 PM, "Michael Barton" <Michael.Barton@asu.edu> wrote:
Yesterday I compiled GRASS 7.2 RC2 with no errors. Today I tried to test
it before posting and got the following error:GRASS 7.2.0RC2 (Global_latlon):~ > Traceback (most recent call last):
File "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py",
line 158, in <module>
sys.exit(main())
line 145, in main
app = GMApp(workspaceFile)
line 48, in __init__
wx.App.__init__(self, False)
File
"/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
line 7981, in __init__
self._BootstrapApp()
File
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
line 92, in OnInit
workspace=self.workspaceFile)
File
"/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
line 129, in __init__
self._menuTreeBuilder = LayerManagerMenuData()
File
"/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
line 42, in __init__
self, filename, expandAddons=expandAddons)
File
"/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py",
line 65, in __init__
xmlTree = etree.parse(filename)
File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
line 1182, in parse
tree.parse(source, parser)
File
line 657, in parse
self._root = parser.close()
File
line 1654, in close
self._raiseerror(v)
File
line 1506, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0Any idea what this is?
Is this yet a showstopper for the final release?
grass-dev mailing list
grass-dev@lists.osgeo.org
grass-dev Info Page--
Martin Landa
Ing. Martin Landa, Ph.D. – GeoWikiCZ
Martin Landa - GISMentors
grass-dev Info Page
