[GRASS-dev] GRASS 7: cairo compilation problem
I have problems to compile cairo after a distro upgrade:
[neteler@north cairodriver]$ make
gcc -shared -o /home/neteler/grass70/dist.x86_64-unknown-linux-gnu/lib/libgrass_cairodriver.7.0.svn.so
-L/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/lib
-Wl,--no-undefined -Wl,--export-dynamic -L/usr/lib64
-Wl,-rpath-link,/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/lib
  OBJ.x86_64-unknown-linux-gnu/Box.o
OBJ.x86_64-unknown-linux-gnu/Color.o
OBJ.x86_64-unknown-linux-gnu/Draw_bitmap.o
OBJ.x86_64-unknown-linux-gnu/Draw.o
OBJ.x86_64-unknown-linux-gnu/Driver.o
OBJ.x86_64-unknown-linux-gnu/Erase.o
OBJ.x86_64-unknown-linux-gnu/Graph.o
OBJ.x86_64-unknown-linux-gnu/Line_width.o
OBJ.x86_64-unknown-linux-gnu/Raster.o
OBJ.x86_64-unknown-linux-gnu/read_bmp.o
OBJ.x86_64-unknown-linux-gnu/read.o
OBJ.x86_64-unknown-linux-gnu/read_ppm.o
OBJ.x86_64-unknown-linux-gnu/read_xid.o
OBJ.x86_64-unknown-linux-gnu/Set_window.o
OBJ.x86_64-unknown-linux-gnu/Text.o
OBJ.x86_64-unknown-linux-gnu/write_bmp.o
OBJ.x86_64-unknown-linux-gnu/write.o
OBJ.x86_64-unknown-linux-gnu/write_ppm.o
OBJ.x86_64-unknown-linux-gnu/write_xid.o -lgrass_driver.7.0.svn
-lgrass_gis.7.0.svn -lfreetype -lXrender -lcairo -lX11
-L/usr/lib64 -lSM -lICE -lX11 -lm
OBJ.x86_64-unknown-linux-gnu/Text.o: In function `fc_init':
/home/neteler/grass70/lib/cairodriver/Text.c:180: undefined reference
to `FcInit'
OBJ.x86_64-unknown-linux-gnu/Text.o: In function `set_font_fc':
/home/neteler/grass70/lib/cairodriver/Text.c:198: undefined reference
to `FcNameParse'
/home/neteler/grass70/lib/cairodriver/Text.c:199: undefined reference
to `FcDefaultSubstitute'
/home/neteler/grass70/lib/cairodriver/Text.c:200: undefined reference
to `FcConfigGetCurrent'
to `FcConfigSubstitute'
/home/neteler/grass70/lib/cairodriver/Text.c:201: undefined reference
to `FcFontMatch'
OBJ.x86_64-unknown-linux-gnu/Text.o: In function `font_list_fc':
/home/neteler/grass70/lib/cairodriver/Text.c:217: undefined reference
to `FcPatternCreate'
/home/neteler/grass70/lib/cairodriver/Text.c:218: undefined reference
to `FcObjectSetBuild'
/home/neteler/grass70/lib/cairodriver/Text.c:219: undefined reference
to `FcFontList'
/home/neteler/grass70/lib/cairodriver/Text.c:228: undefined reference
to `FcPatternGetString'
/home/neteler/grass70/lib/cairodriver/Text.c:229: undefined reference
/home/neteler/grass70/lib/cairodriver/Text.c:240: undefined reference
to `FcObjectSetDestroy'
/home/neteler/grass70/lib/cairodriver/Text.c:241: undefined reference
to `FcPatternDestroy'
/home/neteler/grass70/lib/cairodriver/Text.c:242: undefined reference
to `FcFontSetDestroy'
collect2: ld returned 1 exit status
make: *** [/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/lib/libgrass_cairodriver.7.0.svn.so]
Error 1
In Text.c, I see
#if CAIRO_HAS_FT_FONT
#include <cairo-ft.h>
#include <fontconfig/fontconfig.h>
#endif
but
[neteler@north cairodriver]$ grep CAIRO_HAS_FT_FONT ../../include/config.h
[neteler@north cairodriver]$ grep CAIRO_HAS_FT_FONT *
Text.c:#if CAIRO_HAS_FT_FONT
and
ls -l /usr/include/fontconfig/fontconfig.h
-rw-r--r-- 1 root root 23426 2010-01-18 17:58
So I wonder how this should work but I may have overseen a detail.
You did run "make distclean" then re-configure, right?
to `FcInit'
Fc = Fontconfig.
In Text.c, I see
#endif
but
and
If cairo was built with Fontconfig support, CAIRO_HAS_FT_FONT will be
defined in cairo-features.h. Also, "pkg-config --libs cairo-ft" will
typically output something like "-lcairo -lfreetype -lfontconfig".
The fact that -lfontconfig isn't appearing in the link command
suggests that "pkg-config --libs cairo-ft" isn't mentioning it. But
the undefined symbol errors suggest that CAIRO_HAS_FT_FONT is defined
IOW, cairo can't make up its mind whether it was built with fontconfig
support or not. Is it possible that you have more than one version,
and it's using the headers from one version and libraries (and
pkg-config data) from another.
Either that, or configure hasn't been re-run and Platform.make still
has the old linker flags for a non-fontconfig version of cairo.
On Fri, Aug 27, 2010 at 7:47 PM, Glynn Clements
Yes.
to `FcInit'
Fc = Fontconfig.
In Text.c, I see
#endif
but
and
Yes:
grep FT /usr/include/cairo/cairo-features.h
#define CAIRO_HAS_FT_FONT 1
I only get
-lcairo -lfreetype
So some mess here.
rpm -qa | grep 'cairo\|fontconf' | sort
fontconfig-2.8.0-2mdv2010.1
lib64cairo2-1.9.6-3mdv2010.1
lib64cairo-devel-1.9.6-3mdv2010.1
lib64cairomm1.0_1-1.8.4-1mdv2010.1
lib64fontconfig1-2.8.0-2mdv2010.1
lib64fontconfig-devel-2.8.0-2mdv2010.1
libcairo2-1.9.6-3mdv2010.1
libfontconfig1-2.8.0-2mdv2010.1
python-cairo-1.8.8-1mdv2010.1
This looks normal.
ldd /usr/lib64/libcairo.so | grep font
        libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1 (0x00007f41a3f36000)
If I add -lfontconfig in include/Make/Platform.make here:
#cairo
CAIROINC = -I/usr/include/cairo
-I/usr/include/pixman-1 -I/usr/include/freetype2
-I/usr/include/libpng12
CAIROLIB = -lfreetype -lXrender -lcairo -lX11 -lfontconfig
USE_CAIRO = 1
CAIRO_HAS_XRENDER = 1
CAIRO_HAS_XRENDER_SURFACE = 1
then it compiles ok.
As I understand, the pkg-config output here is wrong since it is used:
configure.in:CAIROLIB=`pkg-config --libs $cairo`
Is it possible that one of these has FreeType support and the other
doesn't?
Yes.
Also, because of issues with pkg-config (e.g. not existing on
platforms other than Linux), configure also has:
  --with-cairo-includes=DIRS
                          cairo include files are in DIRS
  --with-cairo-libs=DIRS cairo library files are in DIRS
  --with-cairo-ldflags=FLAGS
                          cairo needs FLAGS when linking
So --with-cairo-ldflags=-lfontconfig may be able to work around this.
On Sat, Aug 28, 2010 at 3:06 PM, Glynn Clements
doesn't?
Both appear to have support:
[neteler@north ~]$ rpm -qil lib64cairo2-1.9.6-3mdv2010.1 | grep 'so.'
/usr/lib64/libcairo-script-interpreter.so.2
/usr/lib64/libcairo-script-interpreter.so.2.10906.0
/usr/lib64/libcairo.so.2
/usr/lib64/libcairo.so.2.10906.0
[neteler@north ~]$ ldd /usr/lib64/libcairo.so.2 | grep 'free\|fontc'
        libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1 (0x00007f3be8b80000)
        libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00007f3be88f8000)
[neteler@north ~]$ rpm -qil libcairo2-1.9.6-3mdv2010.1 | grep 'so.'
/usr/lib/libcairo-script-interpreter.so.2
/usr/lib/libcairo-script-interpreter.so.2.10906.0
/usr/lib/libcairo.so.2
/usr/lib/libcairo.so.2.10906.0
[neteler@north ~]$ ldd /usr/lib/libcairo.so.2 | grep 'free\|fontc'
        libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0xf75e7000)
        libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xf7563000)
Yes.
I have opened a bug report in the Mandriva tracker.
Yes, this works as workaround, thanks.
