In GRASS 7 in the d.vect GUI the layer option is only recognised if typed in manually (not from the dropdown-list). When changing to other tabs, it is lost again. The result is that the layer is not displayed when where option is used.
option is used.
I am working on Ubuntu 12.04 LTS 64bit.
typed in manually (not from the dropdown- list). When changing to
used.
On Thu, Jul 4, 2013 at 12:23 PM, Blumentrath, Stefan
used.
used.
