Markus:
> Interestingly it works today. Perhaps I had set
> $PYTHONPATH indeed to the swig/python/ directory as
> suggested in the examples:
Glynn:
Right; that will cause the problem which you reported.
The only GRASS-related directory which should be added to
PYTHONPATH is $GISBASE/etc/python.
fwiw, this fix was committed to 6.4 and 6.5 svns 2 days ago:
http://trac.osgeo.org/grass/changeset/37641
Hamish
