Hei,
I just tried to run r.threshold in GRASS 7. Unfortunately I got an error message, so I looked into the python code and found that the module uses GRASS 6 syntax for r.stats (namely fs instead of separator) in line 41 (see: http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.threshold/r.threshold.py).
If this is changed it works fine…
Stefan
On Tue, Feb 11, 2014 at 2:40 PM, Blumentrath, Stefan <
Stefan.Blumentrath@nina.no> wrote:
Hei,
(see:
If this is changed it works fine...
It should be fixed. Thanks for reporting this issue!
Anna
Stefan
grass-dev mailing list
grass-dev@lists.osgeo.org
