[GRASS-dev] GRASS 7 r.what introduces duplicates
When I used r.what in GRASS 7 on Ubuntu 12.04 LTS (64bit) it introduced duplicates (in my two cases it duplicated the last line of output).
Can it be a problem of my installation or shall I file a ticket?
Stefan
On 20 January 2014 19:13, Blumentrath, Stefan
<Stefan.Blumentrath@nina.no> wrote:
I think it is your problem, I have no problem with GRASS7 r58751.
nc_spm_08 dataset
GRASS 7.0.svn (nc_spm_08):~ > r.what map=elevation coo=631000,228400
631000|228400||137.0444
Stefan
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi Luca,
Thanks for your reply. I investigated a bit more and suspect the problem arises from the "points" option which I used....
When I extract the coordinates from my vector map and feed them as a list to the "coordinates" option I get the correct number of lines from r.what (like you did). But when I use the same file directly in the points option the last line is duplicated (using r 58048 btw.).
Stefan
-----Original Message-----
Sent: 21. januar 2014 00:10
To: Blumentrath, Stefan
Cc: GRASS developers list (grass-dev@lists.osgeo.org)
Subject: Re: [GRASS-dev] GRASS 7 r.what introduces duplicates
On 20 January 2014 19:13, Blumentrath, Stefan <Stefan.Blumentrath@nina.no> wrote:
nc_spm_08 dataset
Stefan
ciao
Luca
www.lucadelu.org
On 21 January 2014 00:42, Blumentrath, Stefan
Hi Luca,
Hi Stefan,
Yes you are right, please open a ticket...
Stefan
ciao
Luca
www.lucadelu.org
On Tue, Jan 21, 2014 at 12:50 AM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi Luca,
Hi Stefan,
Fixed in trunk r58752.
Markus M
Stefan
ciao
Luca
www.lucadelu.org
grass-dev mailing list
Wow, fixed before I managed to open a ticket!
Thank you very much Markus!
From: Markus Metz [mailto:markus.metz.giswork@gmail.com]
Sent: 21. januar 2014 08:40
To: Luca Delucchi
Cc: Blumentrath, Stefan; GRASS developers list (grass-dev@lists.osgeo.org)
Hi Luca,
Hi Stefan,
Markus M
Stefan
ciao
Luca
www.lucadelu.org
On Tue, Jan 21, 2014 at 9:02 AM, Blumentrath, Stefan
You can open a ticket to backport the fix if it is working for you.
The fix itself is trivial.
Markus M
To: Luca Delucchi
Hi Luca,
Hi Stefan,
Markus M
Stefan
ciao
Luca
www.lucadelu.org
